Hydraulic Clutch Setup
#1 _gen3torrie_
Posted 12 April 2011 - 07:12 PM
well i modifyed my pedal to suit a clutch master cylinder for the box i have in the ute, but im not happy with the general design of my pedal it doesnt feel like it will last too long
what would be the best way to mount it to my pedal?
i kinda figured maybe changing the angle of the back of the pedal and welding a bracket with a big bolt and nut on it
i will get photos of both the master cylinder and the pedal later on tonight
any help will be appreciated
cheers josh
Posted 12 April 2011 - 07:14 PM
#3 _gen3torrie_
Posted 12 April 2011 - 09:32 PM
has anyone got photos of hydraulic clutch conversions in HZ kingswoods?
basically i have a VS clutch master cylinder with a remote bottle and i want to mount this into my HZ kingswood
Posted 12 April 2011 - 09:54 PM
Posted 12 April 2011 - 09:58 PM
But thats got nothing to do with Josh and the setup he's trying to do
SHow us what your trying to do Josh... your being too vague
#6 _gen3torrie_
Posted 12 April 2011 - 10:09 PM
when my camera decides to upload pictures i will post some up.
maybe it was muncie.
were would i get dellow conversion from???
Posted 12 April 2011 - 10:55 PM
#8 _gen3torrie_
Posted 12 April 2011 - 11:17 PM
#9 _gen3torrie_
Posted 12 April 2011 - 11:21 PM
Posted 13 April 2011 - 06:46 AM
This shows everything but the pics are very small and there doesn't seem to be bigger versions:
http://autospeed.com/cms/A_108912/printArticle.html
All you need is this master with a pushrod that has a rod end at the pedal and the alloy bracket at left:
http://www.dragtimes.com/parts/holden-hq-hj-hx-hz-wb-hydraulic-clutch-conversion-gts_280650392476.html
The standard pedal is used.
Yep...Thats normally
#11 _gen3torrie_
Posted 14 April 2011 - 02:11 PM
anyway i let the pictures do the talking
im so confused
this is the VS Master Cylinder with a remote bottle i have seen a fair few people use these master cylinders but havent seen how the pedals are run
and this is the pedal out of the HZ
i originally had a bracket welded onto another pedal but the way it was setup it was putting to much pressure on the rod
what should i do???
i have been told the bore sizes on the hr style cylinder will not suit the getrag
although dellows does the complete pedal conversion for hr cylinder for $300 plus postage
#12 _gen3torrie_
Posted 14 April 2011 - 02:14 PM
if i straighten the bracket it will make it sit awkwardly has anyone got an idea on what i can do
i was going to weld a bracket mid way on the pedal but realised when it pushes it pushes on an angle rather than straight the vs master cylinder is designed to push straight
#13 _gen3torrie_
Posted 14 April 2011 - 02:36 PM
cheers josh
Posted 14 April 2011 - 04:24 PM
Or mount it under the dash
#15 _gen3torrie_
Posted 14 April 2011 - 07:48 PM
hahaa i wish i could produce something this good.
its a mal wood setup took the VS slave cylinder back for a refund and i ordered one of these just gotta make one up and send it to me freight overnight
runs a BA Falcon Slave Cylinder and even comes with a fancy alloy reservoir
so thats sorted onto other news
Posted 14 April 2011 - 08:04 PM
Not slave
Slaves do the work.. and sit at the bottom beneath Masters feet
#17 _Quagmire_
Posted 14 April 2011 - 08:12 PM
Master cylinder
Not slave
i got some videos like that
#18 _Kush_
Posted 14 April 2011 - 08:24 PM
Is he still in Warwick QLD?
#19 _Quagmire_
Posted 14 April 2011 - 08:32 PM
The Mal Wood ones are fairly pricey, aren't they?
$800 odd plus frieght he told me
but "will fit straight in no probs 4 hours r+f" was mals words....well according to josh
#20 _Kush_
Posted 14 April 2011 - 09:00 PM
I'll make my own!
It doesn't look too hard.......
Edited by Kush, 14 April 2011 - 09:02 PM.
#21 _gen3torrie_
Posted 14 April 2011 - 11:22 PM
this includes the master cylinder which is what i meant in the first place...
the way it is pictured is the way you get it...
#22 _AGGRO_
Posted 18 April 2011 - 11:01 AM
#23
Posted 18 April 2011 - 11:33 AM
#24 _gen3torrie_
Posted 18 April 2011 - 09:47 PM
#25 _AGGRO_
Posted 19 April 2011 - 10:05 AM
All commodores with T5's were cable clutch from factory. They only went hydraulic in vs series 2 with the getrag box
Edited by AGGRO, 19 April 2011 - 10:09 AM.
