Dry sump 308 Holden exercise !
#1 _rocket_
Posted 08 May 2011 - 07:18 PM
So I have started with a standard bore VK Commodore 308 Black block, which I bought of a friend years ago as a spare. the block was bored 20 thou, decked, tunnel bored, standard caps, ARP main stud kit, I had a set of 4 bolt caps for the centre 3, but was advised not to use, no need for a 400 odd HP engine. I have used a Scat 355 cast steel crank, Scat H beams 5.7 chev journal , SRP Forged flat tops, my original L34 style heads, that needed guides and a set of Stainless steel valves, but all the port work done before by John White race engines was perfect.Block preparation was tank the block ,die grind the valley nice and smooth for the oil flow return, paint with glyptol, which is apparently an armature paint for electric motors, but anyway, it seals the porous cast iron for better oil return to the sump.Remove all the plugs that block the oil galleys, remove the oil pump drive shaft, clean all galleys, and fit new machined plugs, not missing the one behind the oil pump shaft at the front.
#2 _rocket_
Posted 08 May 2011 - 07:24 PM
#3 _Ozzie Picker_
Posted 08 May 2011 - 07:26 PM
what have you done for the dry sump this time, that you are hoping will work?or did i miss something.
why do you think they have failed before?
#4 _rocket_
Posted 08 May 2011 - 07:32 PM
#5 _nzstato_
Posted 08 May 2011 - 07:37 PM
Read this?
Priority mains oiling
#6 _rocket_
Posted 08 May 2011 - 07:38 PM
Thanks mate, me too, other wise Im up for another 10,000 in hand bags & shoes !!!hope it works for you this time,
I think the main reason was over revving, a not so good sump, and trying to cut corners to save money on builds, doesnt work, best to just spend the money once, buy good parts, and find someone that knows 308s, from group a & c days , that has learned the secrets & tricks from experience.
#7 _rocket_
Posted 08 May 2011 - 07:42 PM
That is a brilliant thread, Tony has done some awesome work on Jasons hatch, makes heaps of power, and seems to be reliable, look out for the new hatch, he has pretty much done a total rebuild on the brakes etc, will be very quick and well sorted.Interesting to see how this pans out, I've seen another block painted with that stuff, appears to work incredibly well.
Read this?
#8 _nzstato_
Posted 08 May 2011 - 07:44 PM
Read this?
I thought it was pretty cool too, definately keen to see your approach
#9 _rocket_
Posted 08 May 2011 - 07:47 PM
#10 _Ozzie Picker_
Posted 08 May 2011 - 07:52 PM
that is definatly the way to go,
sounds like you have found the right guy,
i,ve learnt to spend once with a pro aswell,they just keep on going ,when done right.
i,ll be keen to see your results.
#11 _rocket_
Posted 08 May 2011 - 07:57 PM
#12 _Bomber Watson_
Posted 08 May 2011 - 08:28 PM
#13 _rocket_
Posted 08 May 2011 - 08:48 PM
http://www.cranecams.com.au/index.php/component/content/article/100
and these are the lifters.
#14 _Bomber Watson_
Posted 08 May 2011 - 09:01 PM
#15 _rocket_
Posted 08 May 2011 - 09:03 PM
#16 _rocket_
Posted 08 May 2011 - 09:09 PM
#17 _rocket_
Posted 08 May 2011 - 09:27 PM
Hoping it doesnt leak, otherwise the engine has to come back out, because its impossible to get to now its in the car.
#18 _rocket_
Posted 08 May 2011 - 09:32 PM
Posted 09 May 2011 - 07:16 AM
Are you still using the timing chain squirter? A good timing set doesn't really need it but I've had problems with the oil pump drive gear when they are both blocked offThe bolt that holds the cam in, is a solid unit, no centre oil hole for the timing chain, apparently not needed.
Posted 10 May 2011 - 08:45 PM
VERY interested rocket to see how your engine goes, really hope it works out well for you. couple of us in W.A. are looking into it.
no 4 bolt mains? um iv had problems with a standard stroke 308 that the main caps have been moving around on, alot.
even my current motor 4 bolt mains, there has been movement on the 2 bolt frt and Rr caps.
just trying to help with info.
my car is no drag queen, targa south west it sat between 6000rpm and 7000rpm for about 2 to 3 minutes in top gear on a long stage.
#21
Posted 10 May 2011 - 08:56 PM
...if your using a standard oil pump you can block the original cam retaining bolt hole and redrill it through the side to direct oil straight onto the oil pump and cam drive gears...
That is the best way to get oil to the drive gears. I also remove the dripper and block that hole off.
#22
Posted 10 May 2011 - 09:53 PM
Well duh, sorry about the stupid comment...dry sump means no drive gear anymore
#23
Posted 11 May 2011 - 12:28 AM
#24 _rocket_
Posted 12 May 2011 - 05:56 PM
In the pics, the squirter is still there, but not sure , didnt see them assemble the engine, but Id say it still is.
#25 _rocket_
Posted 12 May 2011 - 06:04 PM
Thanks for the info Ozy, I had a set of caps to use, and he said just use a stud kit, I ll only be revving it to 6000, so hopefully no problems.He is renowned for building group a & c engines in the day,and said they were fine with 2 bolt back then, but when we look back at those days,they werent all bullet proof.if your using a standard oil pump you can block the original cam retaining bolt hole and redrill it through the side to direct oil straight onto the oil pump and cam drive gears. dry sump means no drive gear anymore so just block it up.
