* * * - - 4 votes
Tuxedo Black LH SLR 5000
1365 replies to this topic
#376 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 13 January 2012 - 08:58 PM
What were they thinking with that maroon, or should that be spelt moron, anyway enjoying the thread
and the car is looking mint-well done Brad.
#377 _Bomber Watson_
Posted 13 January 2012 - 09:10 PM
You should leave some maroon somewhere, just for sentimental purposes......
Na, scratch that, KILL IT WITH FIRE.
#378 hanra
  • 10,985 posts
Posted 14 January 2012 - 11:26 AM
I hoping that these would look ok after I stripped the black paint off...
Wrong... maroon powdercoat underneath the black paint.... They have been blasted prior to powdercoating... Ill need to get them re-plated.
#379 _Liam_
_Liam_
Posted 14 January 2012 - 01:44 PM
Goes with the mini...
#380 hanra
  • 10,985 posts
Posted 14 January 2012 - 04:03 PM
Popped the shocks n springs out last night whilst the K-Frame was still in the car.
Not sure how old these are? Monroe Gas I think?
Slipped the K-Frame and donk out this arv... Had an issue with the outrigger bolts..... They were fitted with the head of the bolt toward the centre of the car, so as the would come out they fouled on the extractors preventing them coming out... pulled the extractors off the the head but still couldnt remove them from the car..... and the bolts still fouled.... Finally got em out with some dicking around. Pretty sure the head of the bolt should be toward the outside of the car and nut is fitted on the inner part?
Edited by hanra, 14 January 2012 - 04:05 PM.
#381 hanra
  • 10,985 posts
Posted 04 February 2012 - 11:33 PM
Been pretty busy with work lately 12 hour split shifts 10am till 6:30pm then 8:30pm till 12:30pm... so havnt really had a great deal of time to get anything done... this will be the case for the next month or so pretty much....
But have stripped my calipers down... the pistons were seized badly.. not sure if the calipers/pistons can be resurrected or not...
Scored an undamaged heater box, hit it with the soda blaster to get all the crapy layers of old paint off.. white/black/orange...
Gave my inlet manifold a blast also to clean it up. Noticed a lot of corrosion around a water port blank off... Bit of a blast and I went straight through... nice little hole... Ill have to get that fixed up...
Pulled the K-Frame down today also, going to be a big job stripping all the powder coat of everything, blasting then 2 pac'ing...
Cast code off my block:
Edited by hanra, 04 February 2012 - 11:34 PM.
#382 hanra
  • 10,985 posts
Posted 11 February 2012 - 08:46 PM
Got all the bushes pressed out and lower balljoints out using the press at work. Man those lower balljoints are in there tiiiiiight!!!!
I am so sick and tired of stripping off this friggen maroon powder coat... dead set...
#383 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 February 2012 - 05:55 PM
Come on Brad not much more to go now. :lol:
#384 hanra
  • 10,985 posts
Posted 13 February 2012 - 05:58 PM
Hahahahahaha. Yeah I know..... Been doing double shifts at work day/night so havnt been living at home. So gettin nuthin done.....
All the k-frame is in bits, most of it painted. Had to get the k-frame blasted cause it's to big for our stripper tank.
Pulled a few bits off the donk to get cleaned up.
We're dual row timing chains standard??
Edited by hanra, 13 February 2012 - 06:00 PM.
#385 _2wild4u_
_2wild4u_
Posted 13 February 2012 - 11:42 PM
yes some had that as standard
#386 hanra
  • 10,985 posts
Posted 16 February 2012 - 09:26 PM
Havnt really got any good updates except the fact that the parts rooms are filing up again.... Ahhh how good is it living on your own!!!!!!!
#387 _The Baron_
_The Baron_
Posted 17 February 2012 - 03:24 PM
Please chock those back wheels on the ramps!
Also you should be able to have stainless steel liners pressed into the calipers.
Edited by The Baron, 17 February 2012 - 03:24 PM.
#388 hanra
  • 10,985 posts
Posted 17 February 2012 - 10:44 PM
Its actually back on its rear wheels now. I hope those calipers can be saved.....
#389 hanra
  • 10,985 posts
Posted 19 February 2012 - 03:17 PM
Some more stuff... blah blah blah...
Manifold/bellhusing and g/box rear snout have been blasted. They were all red before and looked crap...
Gave my reverse switch a make over also. Its been re-painted black. I dont think this is the correct type for LH SLR 5000 however??
K-Frame is now black....
Have to press in all the suspension rubbers before I paint the upper/lower arms
More black bits...
Stripped the motor down a little to get it ready for painting.
Sump/rocker covers HK Rocket Red
#390 _My74LH_
_My74LH_
Posted 19 February 2012 - 03:37 PM
Nice , do you have the paint code ?
#391 hanra
  • 10,985 posts
Posted 19 February 2012 - 03:41 PM
For the HK Rocket Red? It will be on the tin which I can look at tomorrow.
#392 _My74LH_
_My74LH_
Posted 19 February 2012 - 05:02 PM
Yeah , cant wait to see it finished .
#393 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 19 February 2012 - 05:18 PM
reverse switch looks ok to me brad
i had mine re-zinc coated but assembled it back to front
so reverse lights were on in neutral and all forward
gears
had to sacrifice one of the sidchrome 9/16,s to get the bastard out
of the tunnel so as not to drop the box
suggest you check your assembley and wiring before it goes in
in as it was a real pain in the ass to fix after
#394 hanra
  • 10,985 posts
Posted 19 February 2012 - 07:47 PM
Ah yes. I was planning on setting up the shifter and linkages whilst it's all out of the car. Yeah I'll check the switch at the same time and confirm its closed circut when in reverse.
#395 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 23 February 2012 - 10:16 AM
Looking great Brad, always enjoy seeing the updates.
#396 hanra
  • 10,985 posts
Posted 23 February 2012 - 10:44 AM
Hasnt been anywhere near as many updates as Id like.... Just nooooooooo time lately...
Hoping to have a Kingo Country order arrive before the weekend, left last week.... that should take care of the front end.
HK Rocket Red:
Gearbox to be done Red Oxide Primer:
Edited by hanra, 23 February 2012 - 10:50 AM.
#397 _LH8VD69_
_LH8VD69_
Posted 23 February 2012 - 11:00 AM
Are the motor and box already in good condition and not requiring a rebuild?
Great seeing more progress m8 :)
#398 hanra
  • 10,985 posts
Posted 23 February 2012 - 11:11 AM
Time will tell!!!!! The motor has had a full rebuild, hence being fitted with REPCO pistons. As far as I know this car has been off the rd for many years so doubt the motor has dont much work... Replacing all the gaskets and seals in the motor/box. If I had more $$$ Id do a full rebuild of them both. But things are tight enough as it is... home ownership by yourself sux....
Edited by hanra, 23 February 2012 - 11:21 AM.
#399 hanra
  • 10,985 posts
Posted 23 February 2012 - 11:07 PM
Original Red Oxide versus the spray can Red Oxide.. I think its pretty close.
A box of goodies rolled up from Kingo Country to,
And thanks to my man Dattoman, Ive now got me self an SLR Horn!!!! Pretty effin stoked about that!!!
And I can get rid of my Mallory twin point and fit the correct dizzy!!! Once again thanks to Dattoman!!!
#400 hanra
  • 10,985 posts
Posted 24 February 2012 - 10:50 PM
Gettin me horn sorted for some lovin!
