* * * - - 4 votes
Tuxedo Black LH SLR 5000
1365 replies to this topic
#476 hanra
  • 10,986 posts
Posted 06 May 2012 - 11:12 PM
No idea mate. This is what the auto paint shop sold me. Sika would have applied a hell of a lot easier. This said it has a shelf life of 12 mths. The MFG date was July 2011. Thats what got me thinking it was faulty...?
#477 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 07 May 2012 - 07:26 AM
Try letting the tube sit in the sun for a couple of hours.
Might make it easier to use.
#478 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 07 May 2012 - 07:34 PM
Hi Brad,
Sorry it hasn't gone well - though likely finished now I reckon Derrin's idea is a bloody good one.
Genuine question arising; given the lengths you are going re: an original resto - why use a caulking gun sealer as opposed to the brush on stuff as peviously suggested for that OEM look?
Regardless, I hope it is turning out alright and you are happy with the result despite the difficulty in applying the stuff.
Cheers, TB
#479 _Bomber Watson_
Posted 07 May 2012 - 08:19 PM
Yes tube sounds faulty.
Should be perhaps a touch thicker than windscreen sealant. A lot thicker than milk. Not as thick as dry cement.
Happens, i get brand new tubes of poly all the time that are #@$^%&.
#480 hanra
  • 10,986 posts
Posted 07 May 2012 - 08:30 PM
Yeah nah I dunno why I did what I did. Obviously forgot. Over it anyway.
#481 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 07 May 2012 - 08:58 PM
Nice job on the engine bay.
You'll have it back on the road in no time.
#482 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 07 May 2012 - 10:41 PM
Looks good what was the paint you used, looks like its sort of got a satin finish to it, bit glossier than matt.
#483 hanra
  • 10,986 posts
Posted 08 May 2012 - 06:26 AM
Its a custom satin mix. They guys at the paint shop said they couldnt get 2 pac any flatter without the paint turning to shit? Something about something? Im not sure, I dont like paint.....! Its flatter then the satin that Ive been using on other parts of the suspension and what not.
#484 Tyre biter
Tyre biter
  • 982 posts
Posted 08 May 2012 - 08:29 PM
Regardless Brad - it looks bloody good, but the most important question is; are you happy with it?
Cheers, TB
#485 hanra
  • 10,986 posts
Posted 08 May 2012 - 08:40 PM
Yeah its come up pretty good. Bit pissed I forgot to empty the water trap in between one of the coats and there is a little splatter of water in a spot that you cant see... but just shit me that I forgot to empty the trap and sure as shit a bit of water came out...
Still such a friggen long road ahead of me..... never ending the work on this bloody thing.
#486 _Bomber Watson_
Posted 08 May 2012 - 09:20 PM
Thats half true.
Yes you can only add so much flattening base to a 2k. Adding flattening base to a gloss 2k wont get you quiet as dull as a satin, adding flattening base to a satin will get you a bit shinyer than a matt, etc, what they failed to tell you (probably cause it wasnt on the shelf) is that most paint companies make a matt black.....
That said i hate matt black engine bays, it looks good how it is.
Edited by Bomber Watson, 08 May 2012 - 09:21 PM.
#487 hanra
  • 10,986 posts
Posted 08 May 2012 - 09:24 PM
Is GMH Satin Black really a Matt black????? Or is it flatter because it was an acrylic? They probably did have Matt Black in there but I went in specifically asking for GMH Satin Black. So went down the Satin road straight away I guess.
Edited by hanra, 08 May 2012 - 09:27 PM.
#488 hanra
  • 10,986 posts
Posted 10 May 2012 - 09:33 PM
#489 _Bomber Watson_
Posted 10 May 2012 - 09:42 PM
GMH Satin black would be a satin black i assume mate....I only mentioned Matts because you were bitching it wasnt dull enough :P
From what i have gathered GMH black varied a lot, they used to tip the left over color from the bodies at the end of the day in the big vat of black........
#490 _mick74lh_
_mick74lh_
Posted 10 May 2012 - 10:20 PM
Engine bay and engine look spot on! I love the paint finish. It shouldn't be too hard to keep looking clean.
#491 _AD_75_
_AD_75_
Posted 10 May 2012 - 10:30 PM
Nice work brad, might appear a little more glossy due to the 2pac finish but still a good result.
#492 hanra
  • 10,986 posts
Posted 10 May 2012 - 11:03 PM
Cheers guys. Yeah the fact its sitting directly under twin fluros probably dosnt help... Ohhhhh now the mammoth task of putting everything back together...
#493 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 11 May 2012 - 12:26 PM
Finish looks pretty spot on to me Brad, well done.
#494 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 11 May 2012 - 09:40 PM
looks fantastic brad
love the look of your trim through the windscreen as well
the fun part is putting it all back together
great job as usual
dave mc
#495 hanra
  • 10,986 posts
Posted 12 May 2012 - 10:59 PM
Thanks for the kind words guys. Yeah the easy part is pulling it apart n tidying things up... Now comes the hard part...
Got my steering coupling back together with a dattoman supplied rubber section. Not sure if ive over tightened things though? I've loctited all the nuts on.
#496 hanra
  • 10,986 posts
Posted 16 May 2012 - 10:06 PM
Nothing really major to show at this point... been doing stuff, but its just dumb small stuff like fitting all the pedals, fitted the heater box assy and blower motor. Might look at fitting the wiring loom back in soon, once thats in, I can pretty much put the dash back together.
Got the brake booster/MC and prop valve in getting overhauled, also getting new hard/soft brake lines made up. Want to put all the brakes in before the engine goes in, just so I have more room when fitting that stuff up.
#497 hanra
  • 10,986 posts
Posted 31 May 2012 - 01:02 PM
Ill be 2 pac'ing the booster shells and master cyl this weekend. Got new hard lines made up. The M/C has been re-sleaved also.
Have fitted all the wiring harness back in, fitted a new glovebox in (thats a tricky job), so nearly ready to fit all the dash back in I guess.
Im going to fit all the brakes up before I fit the motor.
Got a heap of bits from MILTON PERFORMANCE, pretty stoked!!
#498 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 31 May 2012 - 02:36 PM
Christian is a lovely and useful fellow.
#499 hanra
  • 10,986 posts
Posted 31 May 2012 - 05:12 PM
I think I want to have his babeeeeeezzzzzzzzzz
#500 hanra
  • 10,986 posts
Posted 01 June 2012 - 12:44 PM
Slowly slowly putting bits back in the bay. Wiring harness is all fitted also.
Once I figure out what Im going to do to fix my cut lower dash, then Ill fit this stock radio back in.
