Tuxedo Black LH SLR 5000
#701
Posted 07 September 2012 - 12:33 PM
The LH manual is ass about.
#702
Posted 07 September 2012 - 12:38 PM
#703
Posted 07 September 2012 - 01:31 PM
Maybe the hoses that connect under the guard are a little shorter than the hoses that connect to the panel.
#704
Posted 07 September 2012 - 01:51 PM
Make sure you put those tie-rod ends up the other way when you do them up tight Brad.
Dead set? So the castellated nut is on the bottom???
#705
Posted 07 September 2012 - 03:45 PM
Yeah bud, check out the taper of the holes in the steering arms.Dead set? So the castellated nut is on the bottom???
Like all good nuts-they should hang down!
LX & UC manuals were changed.
#706
Posted 07 September 2012 - 05:00 PM
#707
Posted 07 September 2012 - 09:05 PM
looks fantastic brad
mighty small calipers though!!!!
your back yay!!!!!!! haha
#708
Posted 10 September 2012 - 10:17 PM
Tried to fit the tailshaft but the diff shop have fitted the incorrect yoke to my diff.... so that needs to all come out again to get that fixed.... f*ck me....
Also the radiator is right to go. New tanks and core and correct mounting bands. $566 plus $50 for the bands..... Expensive 2 core radiator...
#709
Posted 10 September 2012 - 10:25 PM
#710
Posted 12 September 2012 - 09:40 AM
Aside from the diff centre needing to be removed and taken to the diff shop to have the correct V8 yoke fitted.
Ive now heard back from the Exhaust shop saying the disc used to make the RHS exhaust pipe from header to muffler is U/S and they cant supply that pipe. Would need a shop to make it.... Which now brings me back to the problem of finding a local shop capable and interested in doing the job, and a flat bed truck to/from the exhaust shop. F*CK ME..... Just about ready to walk away from this thing.
Edited by hanra, 12 September 2012 - 09:43 AM.
#711
Posted 12 September 2012 - 10:35 AM
Phillip
#712
Posted 12 September 2012 - 11:20 AM
ones u get ya diff back in, there is the old clamp two mufflers on the end of the Extractors trick and get a day permit and drive it to the exhaust shop.
AL
Edited by xu2308, 12 September 2012 - 11:21 AM.
#713
Posted 12 September 2012 - 11:47 AM
#714
Posted 12 September 2012 - 02:27 PM
I will make some enquiries down here-must be someone with the old patterns that can ship up to you.
#715
Posted 12 September 2012 - 02:40 PM
Yes please ring around mate.... None of the shops up have anything. And there is only possibly one shop that could make the missing pipe on the car. But it still means a very expensive trip in on a flat bed and another expensive trip home on a flat bed.....
I was still intending on buying the rest of the system minus the missing drivers side engine pipe.
if I could track down an old pipe perhaps a shop could copy it????
#716
_lx77slr5k_
Posted 12 September 2012 - 03:44 PM
#717
Posted 12 September 2012 - 04:10 PM
Long story short.
A company in Perth was going to supply me with a stock standard exhaust to suit LH Torana.
Engine pipes from exhaust manifolds to mufflers (2in diam)
Mufflers with 2in inlet and 1 5/8 outlet
Tailpipes 1 5/8 diam.
However they have advised me that they cant supply the Drivers side engine pipe from exhaust manifold to muffler......
I was intending to purchase everything else however. But Im trying to avoid having to take the car into an exhaust shop to have this one pipe custom made up..... It will be an expensive exercise as the car is not startable nor driveable.
#718
_mickss_
Posted 12 September 2012 - 04:35 PM
Did u try Jase @Tuff Muff?
#719
_lx77slr5k_
Posted 12 September 2012 - 04:39 PM
#720
Posted 12 September 2012 - 06:47 PM
#721
Posted 12 September 2012 - 07:22 PM
#722
Posted 12 September 2012 - 09:30 PM
#723
Posted 12 September 2012 - 11:11 PM
keep pluggin on bradYeah mate. I ditched the extractors and fitted stock manifolds. That way the heat pipe and auto choke work.
it,s all coming together and is my favorite build thread
davemc
#724
Posted 13 September 2012 - 07:32 AM
keep going Hanra, as they say mate, all part of the venture, you will get there, someone in OZ must make that exhaust pipe, maybe even in Tassy as we are so far behind everyone lol
#725
Posted 13 September 2012 - 07:34 AM
Do i need to ask for a particular brand , part numbers, etc.
Either post it here or text me on 0429798159 and i will see what i can find out.
Edited by Mort, 13 September 2012 - 07:36 AM.
