Tuxedo Black LH SLR 5000
#1151
Posted 10 July 2014 - 12:58 PM
#1152
Posted 10 July 2014 - 05:50 PM
#1153
Posted 10 July 2014 - 07:12 PM
#1154
Posted 10 July 2014 - 08:19 PM
Well if a bottle opener works to get them off, surely one of these would work to get them on.
Posted 11 July 2014 - 10:01 AM
Does that work in reverse??? Hahahaha
Its best put in park with the brake on but you can try it in neutral and let us know how you go.
#1156
Posted 11 July 2014 - 12:46 PM
They actually come off quite easily IF you know what you are doing.
#1157
Posted 12 July 2014 - 03:39 AM
Would you care to share your knowledge? I've seen a lot of people damage them trying to pry them off
#1158
Posted 12 July 2014 - 09:31 AM
All i use is a 4" paint scraper. Preferably of good quality.
There is a ridge on the underside of the mould, that's where you want to be bumping it off from ..... NOT ON THE EDGE OF THE MOULDING.
Tap the handle of the scraper with the palm of your hand just hard enough to release it, not hard enough so it bends up into a pretzel & lands on the neighbours roof. Work your way along the mould from back to front until it has seperated from the gutter.
When re-fitting, lock the corner (bend) part if first so that both 'planes' are secured at the top hook/lip, then bump on with the palm of your hand. Work along the piece & job done.
Make sure that the 'C' pillar gutter mould fits IN TO the top gutter mould first.
#1159
Posted 12 July 2014 - 10:03 AM
#1160
Posted 12 July 2014 - 10:50 AM
Can you please clarify this bit so I fully understand.
#1161
Posted 12 July 2014 - 12:50 PM
The long gutter mould fits over the short C-pillar piece.
#1162
Posted 12 July 2014 - 12:55 PM
#1163
Posted 12 July 2014 - 04:35 PM
No, you can slip it on before bumping on the last 6".
#1164
Posted 14 July 2014 - 01:23 PM
When you say drip mouuld? Do you mean the C pillar section that runs almost vertical behind the rear door?
I've got those sections, I'm chasing the ones that run up the A pillars and along the roof line. When I got my car back off the charlatan that pulled it apart, these were in the list of parts were missing.
#1165
Posted 14 July 2014 - 01:31 PM
Hey mate. Get friendly with yout local Supercheap Auto store or Mackay Rubber stockist. Purchase as many hoses as you can carry and spend some time with trial and error... Make sure you keep all your receipts so you can return all the hoses that dont fit! Thas what I had to do....
I might have it written down somewhere? Not sure.... the Supercheap Auto receipts fade to nothing after a few months... And cant be read.
Cheers,
Looks like Mackay part number CH1614 is what I'm after for the front hose. Just have to trim it to fit but the curved bit looks like it should fit well. The rear heater hose can be substituted with CH1326. Once I fit them to the car I'll confirm there suitability just in case anyone else has to replace these.
Deadly looking arrows there to!
Gotta be careful they don't pierce those hoses
#1166
Posted 14 July 2014 - 03:57 PM
#1168
Posted 14 July 2014 - 07:32 PM
Mackay were making the short hose again, I bought one about 12-18 months ago. CH942 ? Runs from thermostat housing to manifold (not to heater).
Hopefully Bursons will swap the CH1614 for a CH942. When I went to the Mackay site they didn't list this hose under Torana applications and under HQ they don't even list any heater hoses ??? but under HJ they have it listed there.
mugginz
#1169
Posted 14 July 2014 - 07:36 PM
Yep. The gutter trim that everyone seems to be chasing.... One would think RSP would re-make these? There are trims for LJ's re-made.
#1170
Posted 15 July 2014 - 05:18 PM
I get the feeling the LC/LJ series gets a little more love from the reproduction guys at the moment.
#1171
Posted 16 July 2014 - 12:52 PM
#1172
_sjp67m_
Posted 08 May 2015 - 12:08 PM
It is a shame that without flares and a chev it doesn't get the attention that it should
#1173
Posted 08 May 2015 - 07:23 PM
Use Brads thread as a great source for my build.Just read through this whole thread, what amazing work you have done
Edited by mika03au, 08 May 2015 - 07:31 PM.
#1174
Posted 09 May 2015 - 05:01 PM
Hahahahahaha. Don't forget the drop tank!
#1175
Posted 09 May 2015 - 06:17 PM
Geez first the flare bit got me, then you mentioned Chevy......please don't do that again. This car probably would get more looks at a show than the equivelant flared/cheved up version. A credit to Brad for going stock....
