hope you took it for a squirt around the block a few times as well??.....just to dry it out , officer
Tuxedo Black LH SLR 5000
#1201
Posted 11 October 2016 - 03:04 PM
#1202
Posted 11 October 2016 - 03:14 PM
#1203
Posted 11 October 2016 - 05:07 PM
The market seems hot at the moment. Good time to sell. Agree that it is a waste letting it sit in the garage....
#1204
_LHSL308_
Posted 11 October 2016 - 05:28 PM
My cars sit in the garage for no longer than a month and I wash them at least monthly too.
#1205
Posted 11 October 2016 - 08:23 PM
excellent example of a orignal SLR5000
#1206
_LS1 Taxi_
Posted 11 October 2016 - 08:25 PM
If you don't like driving it...perhaps someone who lives nearby can do that task for you?? I'd even consider flying up for a holiday and stretching her legs!
#1208
_BARRY JACKPOT_
Posted 12 October 2016 - 07:31 AM
#1209
Posted 12 October 2016 - 07:49 AM
You need an hour run Brad or your mufflers will rust out. You need to get them hot enough so condensation doesn't collect in them.
This car would sell today I reckon for what you originally asked or more. The money people have been paying for lesser cars than this like $55k for that 4.2L SS needing resto and over $80k for that white/blue HK GTS in Canowindra needing some resto tell me advertised right you'd get over $70k for this. With proper 2" muffler and tailpipe (replacing the peashooters) this timeframe LH-LX (with the 250hp 9.7:1 308) is probably the fastest accelerating regular production car GMH built in the 70's (especially if optioned with a 3.08 rear axle).
#1210
Posted 13 October 2016 - 07:16 PM
So the 3.08 was an option ? , thought i was dreamin when you went 355 , (a bit short for that wagon) and 278 a bit tall ?
i probly woudn't worry too much about the pea shooters mainly for period correctness , but yeah , taller diff. and get out and
dry it out a bit , surely there is a bit of a hill above little mully and a turn around spot , just watch out for bikes
#1211
Posted 18 May 2017 - 07:06 PM
I think it's pretty much just the dual outlet water pump now that incorrect? Can you think of anything else?
#1212
Posted 18 May 2017 - 08:02 PM
#1213
Posted 18 May 2017 - 08:50 PM
Hi Brad, you could strip & Tig a water pump to convert to single outlet. Did the v8 leads have the red ends or the black originally? ? Gary.
grumpy
i think that if you put some work into the water pump
and were anygood at aluminium welding
you may achieve what you want
if you frig it up
don,t give up
try again
as a mechanical fitter i can say nothing is impossible
takes perseverance
and red / pink ends on black leads
#1215
Posted 18 May 2017 - 09:01 PM
Still a stunning car any which way you look at it
#1216
Posted 18 May 2017 - 09:11 PM
Yep the ends of the leads seem to be red in them photos, good to know. Gary.
#1217
Posted 19 May 2017 - 10:17 AM
#1218
Posted 19 May 2017 - 11:54 AM
Brad, please post a pic up when you have the spark leads on.
How did you come across Lectric Limited?
#1219
Posted 19 May 2017 - 12:19 PM
Good work Brad they are the same as the set l got from them last year- they are very authentic looking and work well.
I also got some spring ring battery leads at the same time- not made for Holdens with only "spring ring" on them and had
to extend the secondary cables but look better than aftermarket leads in my opinion.
Cheers again for the alternator spacer mate.
#1220
Posted 19 May 2017 - 03:09 PM
#1221
Posted 19 May 2017 - 04:27 PM
Yeah Gary l will have to check my records but l think it was as much in freight as it was for the leads!
#1222
Posted 19 May 2017 - 04:49 PM
I did ask Lectric Linited if they could make a set of battery terminals to suit Torana but they were not interested. Shame.
#1223
Posted 19 May 2017 - 04:57 PM
Cutting one spout off and welding the hole just looks like someone cut one spout off and welded the hole.
Some people can finish repairs almost unable to pick, with the right tools, the patience that Brad obviously has (wish i had too) & a good clear photo & disassemble & reassemble a new pump, i can't see why he wouldn't do a convincing job of it honestly. But just my opinion. Gary.
#1224
Posted 19 May 2017 - 07:06 PM
I got my spring ring battery cables off Ebay.. Phil Weldon - My 409 is the seller.
