IPRA 4 Door LX
1672 replies to this topic
#226 dattoman
  • 16,487 posts
Posted 02 August 2013 - 08:43 AM
Rear bushes shouldn't be a problem
I think they come in 3 different duro (stiffness) ratings so need to decide on hard, soft or middle of the road
As far as a bush for the front.... will need some measurements ... should be able to work something out
#227 ls2lxhatch
  • 5,332 posts
Posted 02 August 2013 - 11:27 AM
I think you will find that the SuperPro bushes can be turned down in a lathe. I have a couple of spares from an incomplete set to experiment with if you want. Personally I would just make a alloy bush for the top as well.
I am using this style of bush on the trailing arms. I have tubular trailing arms which I feel need either a soft bush or a bush that can pivot. I believe the factory arms will twist a bit under extremes of suspension movement whereas the tubular or boxed arms have no give at all and require either the bush or the mount to absorb the twisting movement.
Del-Sphere-Pivot-Joint-34-16-Right-Hand-
#228 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 02 August 2013 - 11:47 AM
Spot on Andy.
Even if using a bush that can pivot, you then introduce a differnet ype of bind whereby 3 of the trailing arms are trying to change the length of the 4th one so you still need a compliant bushing in there somewhere or you will crack something.
I plan to replace the top diff bushes with rubber when I get the hatch home even though I have the soft poly in there now and those same type of pivoting bushes in the top front of the trailing arms.
#229 _LS1 Hatch_
_LS1 Hatch_
Posted 02 August 2013 - 02:38 PM
Something like these might be another good possibilty, if you wanted to use a more standard style control arm, without needing to go with rod ends that is (and would look more stock if that mattered too..)
http://www.speedwaym...shing,9021.html
#230 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 02 August 2013 - 09:20 PM
Spot on Andy.
If the rear lower arm pivot points were moved so the lower rear arms became parrallel instead of diverging, would that help much?
#231 _LXSS350_
_LXSS350_
Posted 03 August 2013 - 12:54 AM
Also imo its definitely best to run pivot rod ends on your torque arm set-up rather than a poly bush.
Camaro-Torque-Arm-F-Body-Torque-Arm-Fire
Edited by LXSS350, 03 August 2013 - 01:03 AM.
#232 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 August 2013 - 03:15 PM
Thanks Neil, can you PM with cost of hard compound for everything rear end except the top control arms, will not need these.
I can get you the OD / ID and thickness early in the week for the sub-frame top bush.
Cheers mate.
#233 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 August 2013 - 03:40 PM
Spot on Andy.
Tie/ Pivot Rod Ends are a great idea, but can't use them. I have to keep within the rules. For anyone interested, this is a link to the rules for Improved Production.
http://docs.cams.com...29_Group_3J.pdf
The ruling for this is:
9.3 Bushes: Elastomeric bushes used at suspension pivot points (which are not otherwise specified in these regulations) may be replaced by other elastomeric bushings.
9.10 Rear suspension components: Devices for the lateral location of the rear wheels on vehicles with a live axle, and any associated brackets on the body, are free. Brackets may be welded to the body. All other components which have any function in the location of the rear wheels must be retained unmodified except for bushings, which must comply with 9.3 above. Drive flanges, trunnions, hubs, stub axles and wheel bearings are free. It is permissible to add additional longitudinal rear suspension arms provided that all bushings are elastomeric and that the mounting points on the body only involve the addition of metal, save for a single hole per arm of maximum diameter 25mm.
I can replace all rubber bushes with Superpro or nolethane as they are considered elastomeric, rod ends are not. Another point to note is that where it says: All other components which have any function in the location of the rear wheels must be retained unmodified except for bushings, means I cannot replace or modify the 4 trailing arms off the diff.
What I will be doing is making the 2 top arm virtually redundant, and going for a 3 link set up with a Torque Arm as LXSS350 posted. Although the picture he put up whilst it might be a good bit of kit, I cant use because of the Pivot Rod ends.
What I am considering using I what my mate who is building the Monaro I posted pictures of a few pages back suggested.
Attached File  Torque Arm.jpg   121.54K   9 downloads
I should note that in this picture it is only the torque arm and not the other gear in the photo I plan to copy/ use.
Good fun Huh, building a car within rules!!!!!!
Edited by eyepeeler, 03 August 2013 - 03:44 PM.
#234 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 August 2013 - 04:21 PM
I should also note that when you see me do the Watts link it will have rod ends , confused?? Well in the Rule 9.10 it says to use elastomeric bushes on Longitudinal arms (BLUE), lateral location devices are free (RED).
#235 _LXSS350_
_LXSS350_
Posted 03 August 2013 - 07:14 PM
For god sake do they want you to only wear pink jocks. :soapbox:   LOL.
You would think logic would mean that what's good for the non standard watts link would be good for the non standard torque arm.  :wtf:
Dozens of ways to build a torque arm but a torrie certainly has not got an abundance of tunnel room (especially with a big tailshaft).
#236 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 August 2013 - 07:43 PM
LOL Col, I'm hearing ya loud and clear. Fun isn't it. It's all good though, well it will be when I can get behind the wheel at Barbs and drive it.
Love your ideas though, you put some thought into things that you want to do.
#237 76lxhatch
  • 7,208 posts
Posted 03 August 2013 - 08:35 PM
How are you going to do this in a manner that won't cause bind with the third arm if you still have to use bushes? Even with limited suspension travel isn't it going to be a problem?
#238 _LXSS350_
_LXSS350_
Posted 03 August 2013 - 08:46 PM
I read the rules but I must have selective reading comprehension (i.e. If I don't like it I skip that bit - LOL)
The way the rust is going with us I image come fire-up time Barbs will be a housing estate.
The standard torana LH/LX front air dam is very ineffective. I find running a deeper diffuser style like Clarkes with an undertray similar to the Germans (green taxi) works really well for stability when coming over the hill at 240kph and into the final corner. Pretty sure you can use similar as long as its no more than 125 forward and within the 100 ground level.
#239 _LXSS350_
_LXSS350_
Posted 03 August 2013 - 08:59 PM
You get a good idea of the shape here in the pits. I have designed and am getting one made to the level of the bottom of the Kframe and using 1/4 turn locks for quick easy release. Air dam has a titanium rub strip which locates and locks in the carbon fibre undertray. The fibreglass one worked but it just flexed too much so I have Wayne doing a carbon fibre version which will hold up far better as the speed and downforce increases.
Edited by LXSS350, 03 August 2013 - 09:08 PM.
#240 eyepeeler
eyepeeler
  • 1,959 posts
I have looked at the spoiler those boys use as it would be within rules as you say, haven't thought about the under tray idea.....hmmmm. Will look into that.
Edited by eyepeeler, 03 August 2013 - 09:00 PM.
#241 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 August 2013 - 09:12 PM
This one will surprise and make you shake your head. Leanne Tander set the president from what I am told, she had the upper arms attached to the chassis in the original bracket but zip tied them up and out the way, not even connected to the diff, but the diff has to have the bracket to accept them. So that is how I plan to make them redundant. Either that or just a really spongey Wetex style bush. Lots of Elastomeric in that one.
#242 _LXSS350_
_LXSS350_
Posted 03 August 2013 - 09:23 PM
As you hit max speed over the hill is where this really works. It keeps the car far more stable so you can brake far deeper. It just stops the car getting light right before you are looking for your braking mark. I found you can carry far more speed with greater confidence as it gives the front end far more bite.
#243 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 04 August 2013 - 11:06 AM
Longer top arms and making them parallel to the bottom arms all helps but a 3 link is the only way to remove all the binding.  Packaging it in the car is then the fun bit.
The main point I was making was if using those pivotting bushes above does not mean you can then run everything else rock solid.
I have tried a few different setups over the years and have a few interresting things I can show.  I have a set of boxed upper arms here with poly bushes - I can show what happpened to the bushes after about 10K kms.
I then changed to edelbrock upper arms (which use pivotting front bushes) but didn't swap out the soft poly in the diff housing because it was too much effort at the time.  When I get my car back, I can show you some pics of the cracks in the UCA mounts - this was just from street driving and a few trips to willowbank down the 1/4.
The force applied to the top arms on the diff under hard accelleration is in the opposite direction to where they cracked so I speculate the cracks are from the binding in the suspension bushes and not enought flex.
I will be changing the upper diff bushes for rubber and obviously welding up the cracks.
Edited by Toranamat69, 04 August 2013 - 11:08 AM.
#244 _LS1 Hatch_
_LS1 Hatch_
Posted 04 August 2013 - 11:22 AM
If you were going with a torque arm setup like that, how do you decide what length to make it, optimum vs what you can package in a Torana, or ?
#245 _LXSS350_
_LXSS350_
Posted 05 August 2013 - 04:05 PM
You don't do any changes to suspension without doing your homework. Its so easy to create heartache if you don't know what you are doing. As Matt says above, the three link is the best layout for a live axle torrie but packaging it is the big party trick. That becomes even more an issue when your mother (CAMS) says you cant enter the cabin (what a bitch rules can be).
The torque arm is a way of getting around this and keeping mother happy, but its mounting and the layout for the geometry still needs to be optimised within the available room and restrictions. Its not something for guesswork or a 5min job.
As you know torque arms/watts links have been used to solve similar issues on Mustangs and F-Bodies that are suffered by torrie owners.
Edited by LXSS350, 05 August 2013 - 04:13 PM.
#246 _Race_Products_
_Race_Products_
Posted 08 August 2013 - 02:26 PM
Hi everyone,
This is Mark from Race Products, just dropped in for a look at the build so far.
We are building the diff for this car at the moment, so I will pop some pictures on as things progress.
Mark
#247 _full_noise_
_full_noise_
Posted 10 August 2013 - 06:31 PM
Any progress????
#248 eyepeeler
eyepeeler
  • 1,959 posts
Posted 10 August 2013 - 09:30 PM
Any progress????
Not this week mate, have hurt my back and it's really slowed the movement up!
Caught up with OzyOzy on Sunday last, he has got the rotor hats done though his mate at HighSpeed Engineering, they look really good.
Should be able to pick them up soon,
Nice to see Mark from Race Product on here, looking forward to seeing the diff being built.
Will catch up with Neil (Datto) this week and get bushes sorted
Hoping my back sorts itself out soon as its bugging the hell out of me!
#249 _LXSS350_
_LXSS350_
Posted 10 August 2013 - 09:53 PM
Hi everyone,
Mark
You guys look to have some quite interesting products. Might have to look closer at your Screw Adjustable Watts Linkage for one of the hatch's.
Edited by LXSS350, 10 August 2013 - 09:55 PM.
#250 eyepeeler
eyepeeler
  • 1,959 posts
Posted 10 August 2013 - 10:05 PM
That's the kit I'm looking at running Col.
