IPRA 4 Door LX
1672 replies to this topic
#251 _The Baron_
_The Baron_
Posted 10 August 2013 - 10:11 PM
Not this week mate, have hurt my back and it's really slowed the movement up!
Natures reminder that you are not 18 and bullet proof anymore. Cold weather freezes my knees which you need allot when working on cars.
With regards to the front spoiler ground affects panel, you should have a look at the one someone put on mine next time you are over this way. It is such a great piece of work that I could not bring myself to go back to the original vulnerable setup. It swallows rabbits and sends them to the brake rotors to be sliced up, carves wombats in half in one deft move and has been know to menace the odd Hyundai's. It fears no furry animal.
P.S. Thanks for the chassis bushes, they look great.
#252 _The Baron_
_The Baron_
Posted 10 August 2013 - 10:17 PM
No idea what happened to my first post??
#253 eyepeeler
eyepeeler
  • 1,959 posts
Posted 10 August 2013 - 10:25 PM
No worries Darky, hope you get to use them.
Will have to have a look for sure, all creatures should fear the ferocity of a Torana with a front splitter.
Watch out skippy........
#254 _LXSS350_
_LXSS350_
Posted 10 August 2013 - 10:39 PM
That's the kit I'm looking at running Col.
That looks to be a nice bit of gear. Nothing worse than climbing under the car when its red hot and making tuning adjustments. Seeing that it can run on cable might even be able to throw it next to the cockpit sway bar adjusters next to the seat. Could be ok for for my needs.
I don't have to obey or listen to mother. :innocent:
I prefer the build rules on cars like the Peugeot 208 T16
Do you have a photo?
Edited by LXSS350, 10 August 2013 - 10:41 PM.
#255 _The Baron_
_The Baron_
Posted 10 August 2013 - 11:22 PM
I did have but a computer crash killed them. I am sure this design would not be to any real advantage like the 125 mm extended ones you speak of.
Next time I run it up on ramps and I remember I will send you a picture.
#256 _LXSS350_
_LXSS350_
Posted 11 August 2013 - 12:01 AM
:spoton:
#257 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 August 2013 - 09:00 PM
The Superlites came in today. They look tough as nails. Can't wait till I get them under the car.
I am so stoked, things going well. If only my back gets a bit better, I will get to do a bit more panel work.
Hope you like.....
Attached File  01.JPG   175.16K   8 downloads
Attached File  02.JPG   137.81K   7 downloads
#258 _Bomber Watson_
Posted 15 August 2013 - 09:12 PM
That looks frOcking SICK.
#259 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 August 2013 - 11:04 PM
I picked up the lower trailing arm bushes from Datto the other day, thanks mate. Still have to get you the measurements for the custom ones I need for the Chassis rail/ Sub Frame.
Today I picked up the front rotor hats from a mate, OzyOzy. His mate at HighSpeed Engineering knocked them up for a group of people organized by OzyOzy. A bit of work went into the design by them, and they turned out really well. Really happy with what I got.
Will put them on tomorrow for a look.......
Attached File  01.JPG   113.67K   7 downloads
Attached File  02.JPG   136.74K   6 downloads
#260 _LS1 Hatch_
_LS1 Hatch_
Posted 22 August 2013 - 02:14 AM
Pretty sweet looking...
How come custom ones versus off the shelf hats ?   (just out of curiosity, since they seem to come in lots of offsets, etc)
A multi piece rotor setup like that would be a good way to go, I had thought about it too...my front rotors are quite heavy, around 27 ? 30 pounds? each or so from memory.  :o  (but price was right at only like $160 each from Mercedes...they do a multi piece version also though, or aftermarket option of course too in my case that is)
#261 _jsher58_
_jsher58_
Posted 22 August 2013 - 07:44 PM
Those hats look very nice. cant wait to see the rotor bolted on.
#262 eyepeeler
eyepeeler
  • 1,959 posts
Posted 22 August 2013 - 07:59 PM
Hi Jeff, I went the custom ones as OzyOzy has put a huge amount of work into getting them right and he is running the same rotor size and rims as I am. The only difference is the caliper he is running compared to me. So I went with his offer to get some made along with his.
Cheers mate, the story in the next post will show them......
#263 eyepeeler
eyepeeler
  • 1,959 posts
Posted 22 August 2013 - 08:11 PM
I got some feedback from Race Products today on the diff and how it is going. Very excited to see in the photos!!
How good is this going to be....
Attached File  01.JPG   172.03K   11 downloads
Attached File  02.JPG   166.11K   12 downloads
Attached File  03.JPG   126.2K   8 downloads
Attached File  04.JPG   120.32K   8 downloads
Attached File  05.JPG   160.45K   9 downloads
I have asked about the Torque Arm or 3rd Arm I want to fabricate for the replacement of the top arms. I need to get some brackets welded onto the tube to mount something like in previous posts.
#264 eyepeeler
eyepeeler
  • 1,959 posts
Posted 22 August 2013 - 08:44 PM
Now for the Rotor Hats...........................................................................................
I can personally confirm that HQ/ Chev does NOT fit Commodore stud pattern. AAARRRRGGGHHHH   Frustration.
Back in the beginning when OzyOzy first talked to me about the idea of getting some made he gave me all the drawings etc and we ran through all the stuff that was needed.
All is good but for the machinist didn't change the PCD from 120 to 120.7mm.......
All good, OzyOzy is picking them up on the weekend and chatting to him about getting them re-made.
I knocked out the studs on the hubs to see how all the other measurements were. All good. They will be a good bit of kit.
I only put one stud back in loose to hold it
Attached File  Rotor 01.JPG   145.63K   11 downloads
Attached File  Rotor 02.JPG   151.67K   9 downloads
Tight fit!!! It is perfect, biggest rotor I could stuff under a 16" rim
Attached File  Rotor 03.JPG   128.94K   9 downloads
The Caliper may need a bit of massaging right inside the rim but this has given me confidence it will all fit inside, no problem.
Attached File  Rotor 04.JPG   142.48K   10 downloads
All in all it is heading in the right direction, just need to get new hats made with the right PCD and it will be unreal.
Edited by eyepeeler, 22 August 2013 - 08:52 PM.
#265 _LS1 Taxi_
_LS1 Taxi_
Posted 22 August 2013 - 08:50 PM
This build and thread is awesome. Yep the HQ/commo don't mix - thankfully :)
That jig for the diff is brilliant.
#266 eyepeeler
eyepeeler
  • 1,959 posts
Posted 22 August 2013 - 08:55 PM
Cheers Daz, I appreciate the comments. I have enjoyed posting all the stuff I can on what I have done so far.
#267 _LS1 Taxi_
_LS1 Taxi_
Posted 22 August 2013 - 08:56 PM
No worries, it's a kickarse build and a very entertaining thread to follow.
#268 _LS1 Hatch_
_LS1 Hatch_
Posted 23 August 2013 - 01:09 AM
Makes sense on that, and awesome looking setup on the brake package, and the diff and floater stuff looks very nice! drool5.gif  and be interesting to see how the rear suspension goes of course as well !
#269 ls2lxhatch
  • 5,335 posts
Posted 23 August 2013 - 01:21 AM
Most factory discs are centred on the hub and a loose fit over the studs. If the hat is a snug fit on the hub then the studs don't need to be a tight fit in the holes and the problem could be resolved by enlarging the holes for the studs.
Edited by ls2lxhatch, 23 August 2013 - 01:21 AM.
#270 _full_noise_
_full_noise_
Posted 23 August 2013 - 10:26 PM
The problem should be resolved by the machinist manufacturing new hats to the correct dimensions!
Not by masking a mistake with a "soft" solution
Hats need to be remade - no question about it
#271 _Viper_
_Viper_
Posted 23 August 2013 - 10:49 PM
Suspension and Diff looks awesome mate...
RE: the last two posts... Andy is right in that most discs are a loose fit over the hub and the problem should be resolved by the machinist as full noise said... but there is only 0.7mm difference between HQ and Commodore so I think it would be acceptable for the machinist to just drill the holes slightly larger.
But at the end of the day if your getting a custom part made to certain specs and they were made outside of those specs you should have the right to have them re-made I guess
#272 eyepeeler
eyepeeler
  • 1,959 posts
Posted 23 August 2013 - 11:27 PM
What I have done is ask for them to be re-made. They are brand new and not right. I hear what your saying Clint, it's only 0.7mm, but its enough for it not to fit. As Andy said, most "factory" hubs are tight on the hub but loose on the studs, I am not building a road car. It's a race car and I don't plan to take chances.
In the end it's pretty simple I asked for 120.7 PCD and that's what I should expect.
#273 bullitA9X
bullitA9X
  • 4,168 posts
Posted 23 August 2013 - 11:42 PM
Hey craig looking sweet as mate hows the back buddy??
#274 eyepeeler
eyepeeler
  • 1,959 posts
Posted 24 August 2013 - 12:00 AM
Hi Daryl, the back is not to bad at the moment, hope to get back to the panel work next week. I can't complain much though, didn't know how long or how much you have had to deal with for years!! I certainly can't complain.
Cheers for the positive comment though, bit like you with your A9X, can't wait till its done. We're just a couple of taxi builders huh, LOL.......
#275 bullitA9X
bullitA9X
  • 4,168 posts
Posted 24 August 2013 - 12:13 AM
yeah but what frOcking taxis least we will drive ours unlike some lol early days of my back injury for me were very very dark had thoughts of suicide as I could see no way out just lucky I had a loving family that I had to live for mate and that snapped me out of it thank god now I have 3 beautiful grandkids...
Edited by bullitA9X, 24 August 2013 - 12:19 AM.
