IPRA 4 Door LX
1672 replies to this topic
#376 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 02 October 2013 - 11:07 PM
coffee, mars bars, toranas,
sounds like a plan
#377 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2013 - 09:12 PM
I finished doing all the little brackets to mount the dash again. Even got the glove box working on a piano hinge!!
Attached File  01.JPG   165.4K   6 downloads
Attached File  02.JPG   176.19K   5 downloads
#378 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2013 - 09:25 PM
Time to fit the sub frame with engine and gearbox fitted. I want to get the gearbox support made up.
Using the hoist is a massive help when doing this!! Just waiting for the comments from Welby........ :ph34r:
As tight as the Jerico is, the width of it is to wide for the trans tunnel. I have marked the tunnel up to cut some more out of it.
I will try again tomorrow.
Attached File  03.JPG   196.91K   6 downloads
Attached File  04.JPG   130.58K   4 downloads
you can see how tight it is.
Attached File  05.JPG   161.7K   4 downloads
Took this just for fun, to see what the engine looked like in it's spot.
Attached File  06.JPG   144.01K   5 downloads
Edited by eyepeeler, 04 October 2013 - 09:26 PM.
#379 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2013 - 09:33 PM
Race Products have got the diff ready to be powder coated All the brackets are welded on and I'm stoked with how it looks.
Should be about 2 weeks and it will be ready to ship over to me.
Attached File  07.JPG   133.32K   7 downloads
Attached File  08.JPG   204.44K   7 downloads
#380 _Viper_
_Viper_
Posted 04 October 2013 - 09:41 PM
Wow that looks impressive :D
#381 eyepeeler
eyepeeler
  • 1,959 posts
Posted 05 October 2013 - 09:39 PM
Got the engine all mounted up. Welby dropped over and it was good timing as he was able to help with the ratchet strap I am using to support the gearbox.
The engine sit right up on the firewall, so I got the set back right. The angle of the engine is more than I expected, it's putting a bit of pressure on the mount but I will be able to look at that later.
Attached File  01.JPG   132.43K   8 downloads
With the strap holding the gearbox I used the ratchet to get the height or the angle of the gearbox to where I wanted it.
The first idea for the support was to use flat plate and a bit of 50x25 RHS as shown in the picture.
Attached File  02.JPG   107.69K   6 downloads
Didn't like it at all, the RHS is way to low. I need it up higher cause the exhaust will go under it. This support will also be used to the mount top of the 3rd link.
I folded the flat plate and cut down the RHS and the result was better, much happier with that.
Attached File  03.JPG   117.83K   6 downloads
I used small cut sections of the RHS and some flat plate to fabricate the bracket to the gearbox.
Attached File  04.JPG   101.65K   6 downloads
Attached File  05.JPG   114.52K   6 downloads
From there I put a fire blanket over all the bit that I didn't want weld spatter to get into and tacked it all up.
Took it off and fully welded it on the bench.
Got1UR1 came over at that point and we had a good catch up. Good timing as well, needed time for the welds to cool!!!
After he left I have to take out the Warping the welding had set into the RHS.
Attached File  06.JPG   116.91K   8 downloads
All done and back in unpainted. Will do that later. I am planning to put a couple of gussets in the support for strength.
Attached File  07.JPG   82.57K   7 downloads
#382 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 05 October 2013 - 10:05 PM
bugger , missed Paul.
lookin good mate.
#383 dattoman
Posted 05 October 2013 - 10:21 PM
Seems I missed everyone , mars bars , and the invite
#384 _Got1UR1_
_Got1UR1_
Posted 05 October 2013 - 10:24 PM
Catch up with you later this week Mark?  Craig is doing terrific work on the car. That big diff with all its brackets etc will be fun to install......... :clappin:
#385 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 06 October 2013 - 10:59 AM
How tuff are jericos, just a staunch lookin box.
#386 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 October 2013 - 11:39 AM
I don't think the invite actually went out Datto.
i called past while i was out on errands. Didn't even bring a mars bar :blink:
#387 eyepeeler
eyepeeler
  • 1,959 posts
Posted 06 October 2013 - 07:32 PM
Just for fun I put a wheel on and a flare to get an idea of how it will look. I'm excited, with the paint scheme I'm going for it will look tough!!!
Attached File  07.JPG   107.67K   5 downloads
Attached File  08.JPG   104.11K   5 downloads
The rotors take up some room huh!!!
Attached File  09.jpeg   66.45K   7 downloads
#388 eyepeeler
eyepeeler
  • 1,959 posts
Posted 06 October 2013 - 07:43 PM
I spent today getting my head around the trans tunnel. The Jerico is pretty wide compare to a standard Torana box. You can see how much was need to be cu out for the linkages on the side.
Attached File  01.JPG   111.57K   5 downloads
I made a start by making a replacement out of light guage galv just to get an idea of how it would work. I had to spot weld in bits to fill gaps etc!!
It turned out pretty much as I had hoped.
Attached File  02.JPG   95.73K   8 downloads
Wit the zinc anneal I made a start with the basics. The galv one was the same at the beginning.
Attached File  03.JPG   106.03K   6 downloads
Lots of trimming, back and forth heaps of times taking little by little out till I was happy. Getting the rolled sections was the hardest to get right.
Attached File  04.JPG   104.34K   6 downloads
I have tacked it in place now. That is as far as I have gone today.
Tomorrow I will take the engine and gearbox out and begin to finish off the tunnel.
I am going to mark out the edges of the new tunnel on the car and cut the old one out.
Attached File  05.JPG   106.11K   7 downloads
Attached File  06.JPG   101.16K   7 downloads
#389 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 06 October 2013 - 08:17 PM
glad i left.
You would never had got that far with me in your ear
#390 eyepeeler
eyepeeler
  • 1,959 posts
Posted 06 October 2013 - 08:29 PM
glad i left.
Thanks for the help with the fun stuff, fitting flares wheel, pictures looked great.
#391 dattoman
Posted 06 October 2013 - 10:12 PM
I drove past today but didn't stop
Seemed to get myself busy and miss all the fun stuff
#392 eyepeeler
eyepeeler
  • 1,959 posts
Posted 06 October 2013 - 10:18 PM
Maybe next time Neil.
Let me know when you want to swing by.
#393 eyepeeler
eyepeeler
  • 1,959 posts
Posted 07 October 2013 - 09:14 PM
After work today I snuck in another couple of hours. It's been really great to get some continuity in progress and the time to work on it. I am thoroughly enjoying it.
With the trans tunnel I made yesterday, I marked out the shape and removed it, dropped the engine, gearbox and sub frame out and took to the old tunnel with the grinder and cutting blade.
Attached File  01.JPG   110.99K   7 downloads
Quite a hole!!!!!
Attached File  02.JPG   122.69K   6 downloads
As you can see, I am shaping some of the original metal to suit the new tunnel.
This is as far as I got tonight. I will have another go tomorrow and I hope to get it all tacked back in.
Attached File  03.JPG   105.99K   5 downloads
#394 Ice
  • 15,213 posts
Posted 07 October 2013 - 10:02 PM
Its really starting to take shape now would love to see your car one day craig keep up the good work
gene
#395 bullitA9X
bullitA9X
  • 4,168 posts
Posted 07 October 2013 - 10:07 PM
great work craig looking awesome mate this thing will be fun to drive....
#396 eyepeeler
eyepeeler
  • 1,959 posts
Posted 07 October 2013 - 10:27 PM
gene
Cheers Gene, you low I was thinking the same thing. With the drive train all sorted and the fab work well underway it could come together early next year? Touch wood!!
hope to catch up on the forum run.
Thanks Daryl, over powered and under tyre'd is a massive recipe for fun to drive!!
#397 Ice
  • 15,213 posts
Posted 07 October 2013 - 10:33 PM
Cool make sure you come this time would be good to have a chat
#398 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 October 2013 - 09:48 PM
Another afternoon spent on the trans tunnel. I have now welded it in and have the job of finishing off the gap at the rear and the underside.
I was planning to weld it in doing a lap joint but was not happy at all with how it was going. So I marked up the sides and cut them down and I went with a butt joint along the sides and a lap joint at the top of the tunnel.
I tacked it all together and the top of tunnel looked like this underneath.
Attached File  01.JPG   96.9K   7 downloads
I used the oxy like I did the wheel arch and heated it up and hammered over the edge. Came up really well.
Attached File  02.JPG   110.84K   5 downloads
Here it is all welded up. Prick of a spot to be welding!!! Burnt my arm a few times through the welding jacket.
Attached File  03.JPG   117.91K   5 downloads
Filling all the gaps and stuff underneath now, tomorrow the rear gap inside the car.
Attached File  04.JPG   114.41K   6 downloads
#399 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 08 October 2013 - 10:16 PM
awesome work mate.
#400 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 October 2013 - 10:23 PM
awesome work mate.
Cheers Welby,
    Bing (1)
