IPRA 4 Door LX
1672 replies to this topic
#426 eyepeeler
eyepeeler
  • 1,959 posts
Posted 13 October 2013 - 12:34 PM
I haven't approached the build with saving weight in mind. Maybe I should? The cage build was not done with any sort of weight concern crossing my mind. If another bar meant being safer, it went in.
My thoughts have been, if it weighs a bit more, then get more horsepower!
And more of both will truly stuff the small tyres used in IP.
Edited by eyepeeler, 13 October 2013 - 12:36 PM.
#427 eyepeeler
eyepeeler
  • 1,959 posts
Posted 14 October 2013 - 09:20 PM
I got another 2 hours on the car after work today.
I straightened out the battery tray that I got out on Saturday and used that to mark out a new one.
Attached File  01.JPG   104.33K   5 downloads
Cut it out and folded along the lines.
Attached File  02.JPG   80.49K   4 downloads
Fits nicely.
Attached File  03.JPG   84.24K   3 downloads
I will weld it in tomorrow through the spot weld holes I drilled out.
#428 TerrA LX
Posted 14 October 2013 - 09:29 PM
Pretty much exactly how I made mine.
#429 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 15 October 2013 - 10:57 AM
look at you go.
Craig's classic resto's , i can see it now.
#430 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 08:39 PM
LOL, Welby, you're to nice!!!
look at you go.
#431 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 08:52 PM
I got the replacement part for the battery tray welded in, had to get he cup head bolt hole drilled in and filed square, line it all up and weld it in through the holes where the spot welds were.
Attached File  04.JPG   82.33K   6 downloads
I bought this Permatex stuff from Supercrap Auto, it's to fix the cracks in the dash pad. They are pretty bad.
Attached File  05.JPG   173.64K   4 downloads
Anyone used it before???
I cleaned up the area and trimmed it back. I poured this stuff into it, it's a bit like araldite in the way it went on.
Let's see what it looks like tomorrow. The instructions say I will have to sand it back and do a top coat.
Attached File  06.JPG   125.78K   3 downloads
Other than the work on the dash pad, I will be cleaning up the chassis of the car over the next few days to primer paint it on Saturday.
#432 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 15 October 2013 - 09:47 PM
I have a couple of dash tops if you need them mate
#433 _LXSS350_
_LXSS350_
Posted 15 October 2013 - 10:02 PM
Christ almighty don't make it too pretty you know its going to get scratched. (LOL)
#434 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 10:06 PM
Cheers mate, depending on how this turns out I may need to ask that question.
#435 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 10:12 PM
Was wondering when you would pop up again!!
Yeah, the plan is not to go to far with it. With the dash, my mate who is doing the Monaro has had the dash in that sprayed with some cool stuff in black. Apparently it's what the rally boys use to cut down glare.
I don't think glare off the dash will be an issue with a Torana but it looks really cool and might be a way to seal the ends that I cut off on the dash pad.
#436 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 15 October 2013 - 10:29 PM
i have some more ally if you need it, just give me a size
#437 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 10:37 PM
Yeah that would be great, any of the bigger sizes would be brilliant.
#438 76lxhatch
  • 7,215 posts
Posted 15 October 2013 - 11:16 PM
Actually I've noticed it with mine quite a bit recently and its been quite some time since I last Armorall'd the dash, so I think it would be well worth addressing in a race car
#439 eyepeeler
eyepeeler
  • 1,959 posts
Posted 15 October 2013 - 11:25 PM
Cheers 76, it will be worth it then.
To be honest, the sun hasn't shone much in Perth over the winter and past it. I can't remember if glare was an issue last summer?? Winter has gone on forever!!!!
#440 eyepeeler
eyepeeler
  • 1,959 posts
Posted 18 October 2013 - 09:31 PM
the last few days I have been cleaning the car down to paint it in Primer Surfacer. Not much to report on cleaning!!!
I painted it today and even with some of the painting I have done earlier on the doors etc, I still have a bit to learn.
I wasn't real happy, I think I had the suction on the paint up to high and to much paint out the gun. I did 6 mixes of the paint pot!!! Seems a lot??
I got a few nasty runs and a cracker of drip!!! I passed the gun over an roll bar accidently and got a massive spray of paint on it, didn't take to long for it to run then drip!!! Dripped onto my nicely painted trans tunnel.
Oh well, more learnt from this experience.
Here it is prior to painting.
Attached File  10.JPG   118.68K   4 downloads
A couple of shots during the painting. I took these while the 2 pack was curing in the paint gun pot.
Attached File  11.JPG   116.19K   4 downloads
Attached File  12.JPG   112.33K   4 downloads
Finished product. Wont rust now.............
Attached File  13.JPG   125.95K   4 downloads
Attached File  14.JPG   121.51K   7 downloads
How do you paint guru's fit the gun into tight areas?? I had trouble with getting the tops of the bars against the roof done properly.
Also had trouble getting in behind the dash. Any ideas???
#441 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 18 October 2013 - 09:53 PM
shiny car mate !
#442 _Viper_
_Viper_
Posted 18 October 2013 - 09:55 PM
Cut the paint pot down :) altho sounds like your using a suction feed gun? so makes it abit more complicated, we have a gravity feed gun which has a pot where the lid just slips inside the pot nicely (not threaded) so we cut the pot down and use it for tighter spots, A air line swivel on the end of the gun helps too
You can also get smaller guns.
#443 eyepeeler
eyepeeler
  • 1,959 posts
Posted 18 October 2013 - 10:25 PM
Cheers Mark. Will be even better when it in white. You know they call this colour Grey-Green. I guess they couldn't decide what it was closer to......grey or green???
shiny car mate !
Hi Clint, Yeah I'm using a suction pot spray gun. I think a little less paint out the gun when I pull the trigger might help me.
#444 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 18 October 2013 - 10:44 PM
four inch brush for the main work, 1 inch for the detail stuff
Edited by A9X, 18 October 2013 - 10:44 PM.
#445 _The Baron_
_The Baron_
Posted 18 October 2013 - 11:17 PM
Don't forget to use a thread cleaning tap before you start bolting hinges etc back on. Will make the task a lot easier.
#446 _LXSS350_
_LXSS350_
Posted 18 October 2013 - 11:38 PM
Stating the bleeding obvious. LOL
Being a racecar are you seriously going to be lugging around all those extra doors???
Or you thinking about doing school run's for some cash?
It's looking good. Don't complain about a drip (run or three) as it could be far worse ........  I could be in control of the spray gun and your torrie would soon be more like a boat (swimming in paint) LOL
Edited by LXSS350, 18 October 2013 - 11:40 PM.
#447 eyepeeler
eyepeeler
  • 1,959 posts
Posted 24 October 2013 - 09:35 PM
This week has not been wasted.....just haven't got any pics to share till today. I have been on the wire wheel cleaning parts and getting them ready to prime them. I guess many of you don't need to see wire wheeled parts!!!
Race Products have got the diff finished and they email a couple of pics for me and damn..... I am so looking forward to getting it!!! It is going to be shit hot.
If any of you want a diff made, talk to Mark at Race Products and you won't regret it.
Attached File  01.JPG   95.65K   4 downloads
Attached File  02.JPG   87K   5 downloads
Attached File  03.JPG   94.95K   7 downloads
Attached File  04.JPG   98.46K   6 downloads
Attached File  05.JPG   101.48K   7 downloads
Attached File  06.JPG   80.46K   7 downloads
Attached File  07.JPG   96.27K   6 downloads
I plan to prime the parts I am wire wheeling this weekend on Saturday. Sunday I have got a club car cruise, getting the L34 out for a run, weather looks good.
#448 _Bomber Watson_
Posted 24 October 2013 - 09:52 PM
Diff looks sick.
Re the paint, yes you have to much fluid. Depending on yoru tip size and how much thinner your running, a general starting point is 2 1/2 turns out from fully in.
As far as tight areas with a pot type gun, rip the pot off, get a fitting to screw on where the pot goes from the paint shop with a bit of line, and run the line to the pot remotely, hold one in each hand....Its a talent but its worth learning :P
#449 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 24 October 2013 - 10:28 PM
diff looks fully shick mate.
can't wait to see that baby here.
#450 _Viper_
_Viper_
Posted 24 October 2013 - 11:18 PM
Wow that diff looks tuff... Dont forget to run the orbital over the parts you have wire wheeled with around 60 grit... The wire wheel will polish the metal too much and depending on the primer it wont stick too well.
