IPRA 4 Door LX
1672 replies to this topic
#626 eyepeeler
eyepeeler
  • 1,959 posts
Posted 18 April 2014 - 08:20 PM
Spent the day down at work on the car but not all of it was working on the car. Got1UR1 and Green Taxi came over to say g'day, was good to catch up with them. I also had a 2 other visitors who are into Torana's. Spent a bit of time shooting the breeze talking stuff which was nice. Green Taxi also helped me a bit with the drivers window glass which was nice.
So today I got 3 of the 4 door glass in, I only have the front passenger to fit now. It all went in ok, just have to follow a methodical order. Like I found out that fitting the window belts in the rear door after the glass has gone in isn't going to happen. So out comes the window, fit the 2 belts, put the glass in and then slide the divider down. Works easy enough if you follow steps.
In the 3rd photo I have put 2 arrows on the picture. The smaller arrow shows where I relocated the door handle to when I realized it was going to clash with the roll cage.
What I didn't think about was the window winding mechanism. As you can see below the larger arrow is the arms for the winder and they travel right across where the wire rod that connects the door handle and door catch goes. I only realized it when the window would not travel up very well and come out of the bailey channel. The wire rod wasn't a problem when the window was down but caught on the arms as the window was wound up.
When I took the door handle off and I adjusted the window winder the window now travels up and down smoothly.
Now I have to relocate the door handle to another spot.
  • Attached File  33.JPG   130.52K   5 downloads
  • Attached File  34.JPG   160.54K   4 downloads
  • Attached File  35.JPG   122.29K   4 downloads
  • Attached File  36.JPG   148.08K   3 downloads
#627 Ice
  • 15,221 posts
Posted 18 April 2014 - 09:33 PM
I want to see rubber on this thing Craig
#628 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 April 2014 - 02:27 PM
#629 Ice
  • 15,221 posts
Posted 19 April 2014 - 03:39 PM
Cool very period correct Craig
Some race livery will make that car cant wait
#630 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 April 2014 - 03:49 PM
I had to extend the wire rod as it was to short.
Fits in nicely
Glass all done now as well
#631 Racehatch
Racehatch
  • 1,028 posts
Posted 21 April 2014 - 12:35 AM
Hey Craig,
What wheel/tyre sizes are you running (sorry if I missed it earlier?)
cheers,
Sam
#632 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 April 2014 - 10:22 AM
Hey Craig,
cheers,
Sam
Hey Sam, rim size is 16x8 and fit a 225 45 tyre. Is that that you run??
#633 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 April 2014 - 12:05 PM
I have been looking at different stuff on the Summit Racing website, one of which was exhaust kits. As I am planning to build my own system I am not sure which way I want to go yet.
A bit of talk on benefits of 4-1 or 2-1 merge collectors would be good. I am leaning towards 4-1 but space could be an issue.
Let me know your thoughts.
#634 N/A-PWR
  • 9,644 posts
Posted 21 April 2014 - 01:26 PM
Here is a Read Craig:-
https://www.google.c...h-torana.com.au
http://www.gmh-toran...tition-exhaust/
#635 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 April 2014 - 06:39 PM
Thanks Dave, not a bad thread. Will have to read it a few time for it to all sink in.
All dimension and configuration ideas aside, this YouTube 6 part video is really good on how to build one.
https://m.youtube.co...h?v=ridE6PiN5H0
#636 Racehatch
Racehatch
  • 1,028 posts
Posted 21 April 2014 - 10:53 PM
Yeah cool, the tyres in your pic looked a bit bigger - I'm running the same rim (superlite) 8 inch - been running the 215/50 but will try the 225/45 (the 225 is actually 2mm narrower..lol)
Edited by Racehatch, 21 April 2014 - 10:56 PM.
#637 eyepeeler
eyepeeler
  • 1,959 posts
Posted 25 April 2014 - 08:20 PM
Another day taking it slowly, having my lad with me means I am riveting and tek screwing sheet metal together making stuff. Not really car stuff.
I fitted up the bonnet, the gaps are a bit how ya going, but will do. Fitted tail lights, painted light surrounds and painted rear bumper mounts. he2a3aza.jpgybe7aduh.jpgyqusyre7.jpgzy7u4yga.jpgnu9u6emy.jpg
#638 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 April 2014 - 09:21 PM
Only a couple of hours today, got the grille painted black, started cleaning up the trailing arms ready to paint. ga4y3emy.jpgpu6u5eja.jpge7ugedej.jpg2utepe3e.jpg
#639 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 26 April 2014 - 09:41 PM
Good work mate coming together nicely
#640 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 April 2014 - 07:24 PM
Pulled apart the steering rack to clean it up.
Pretty simple inside.
Stripped the lock nut threads getting the ball housing off. Have to fix that.
#641 dattoman
Posted 29 April 2014 - 09:11 PM
Kit31K
#642 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,428 posts
  • Name:facebook dave
Posted 29 April 2014 - 09:50 PM
looking great craig
#643 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 April 2014 - 10:36 PM
Cleaned up these bits, no problem.
#644 Ice
  • 15,221 posts
Posted 29 April 2014 - 10:39 PM
Hey craig are you going to box in the trailing arms
Or is that a no no
#645 N/A-PWR
  • 9,644 posts
Posted 30 April 2014 - 12:07 AM
Box them in I recon too,
don't get those expensive adjustable ones, the fastening Nut can come loose from twisting and then lose control of the body twist. Dave I
#646 _LS1 Hatch_
_LS1 Hatch_
Posted 30 April 2014 - 12:11 AM
Are those stencils to paint the numbers on the side of the car ? :D
#647 eyepeeler
eyepeeler
  • 1,959 posts
Posted 30 April 2014 - 01:03 AM
Hey craig are you going to box in the trailing arms Or is that a no no
Not a bad idea Gene and Dave, but rules won't allow it. Below is rule 9.10
REAR SUSPENSION COMPONENTS: Devices for the lateral location of the rear wheels on vehicles with a live axle, and any associated brackets on the body, are free. Brackets may be welded to the body. All other components which have any function in the location of the rear wheels must be retained unmodified except for bushings, which must comply with 9.3 above. Drive flanges, trunnions, hubs, stub axles and wheel bearings are free. It is permissible to add additional longitudinal rear suspension arms provided that all bushings are elastomeric and that the mounting points on the body only involve the addition of metal, save for a single hole per arm of maximum diameter 25mm.
It's the bit about all other components and being unmodified.
..Are those stencils to paint the numbers on the side of the car ? :D
Not quite Jeff, they are for work stuff. My lad Fraser laid them out as that is what they are doing in school at the moment. It's great to have him around whilst I work on that car, even though not much gets done at times.
#648 N/A-PWR
  • 9,644 posts
Posted 30 April 2014 - 11:13 PM
Rules are Rules, and they can be broken,
but it did say about longitudinal rear suspension arms ( couldn't boxed trailing arms be them ). Dave I
#649 eyepeeler
eyepeeler
  • 1,959 posts
Posted 30 April 2014 - 11:59 PM
Now your onto something Dave. I have got brackets welded onto the diff for that very reason.
I am going to make the top arm redundant by having sponge bushes, run the lower arms as original and build a 3rd link arm that will follow the line of the tail shaft.
That arm will be made from SHS.
Lateral location done by watts link.
#650 N/A-PWR
  • 9,644 posts
Posted 01 May 2014 - 12:10 AM
Wow Craig,
you have done it, well Done. Dave I
