IPRA 4 Door LX
1672 replies to this topic
#676 eyepeeler
eyepeeler
  • 1,959 posts
Posted 13 May 2014 - 07:48 PM
Got the pedal box in on temporary bolts (getting dome heads for clearance), and the brake bias set up. The bias looks a bit agricultural in how it works, but time will tell if it does the job.
Painted the dash Matt Black as well. 4u8amuha.jpgubuduput.jpgpujapuga.jpge6ujutev.jpg
#677 eyepeeler
eyepeeler
  • 1,959 posts
Posted 17 May 2014 - 02:20 PM
Hoses on, not an easy job.
#678 dattoman
  • 16,487 posts
Posted 17 May 2014 - 02:52 PM
Will you be adding electric windows ?
#679 eyepeeler
eyepeeler
  • 1,959 posts
Posted 17 May 2014 - 03:55 PM
Nah Neil, sticking with the old winders.
#680 Ice
  • 15,204 posts
Posted 17 May 2014 - 04:09 PM
Im gunna come round with a white spray can and paint that mirror for ya
#681 _LS1 Taxi_
_LS1 Taxi_
Posted 17 May 2014 - 04:13 PM
Will probably need to attack them flares with a saw or grinder to get massive rubber on the front too :o
#682 eyepeeler
eyepeeler
  • 1,959 posts
Posted 17 May 2014 - 05:59 PM
You know you aren't far from being right for a different reason. I have 480mm from centre bolt to outside of rim. It's 490mm from centre of chassis rail bolt hole to inner of flare!!
You don't like the poo brown mirror???
Guess I better get it done,
#683 _LS1 Taxi_
_LS1 Taxi_
Posted 17 May 2014 - 06:12 PM
When you turn the wheel with then 225's on an 8 inch rim you'll likely catch the front edge of that flare and the inside of the rear one too.
Been through the same thing with 225's on 8" rims before although your flares don't curve down as much as mine did on the front edge. Mine were almost vertical :(
#684 _Red One_
_Red One_
Posted 19 May 2014 - 10:14 PM
Some rubber grommets around the hose going through the fire wall would really finish this off nice Mr Peeler.
#685 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 May 2014 - 11:08 PM
Hi Brad, I had thought of fitting grommets but I drilled the holes 0.5mm under OD of hose to get a tight fit. They were a bitch to thread through. Figured that would be ok.
Update on stuff, no photo's though.
Been working on some bits and shits, got the door locks on the front doors fitted, fitted the stalk for the door locks LOL.
I caught up with 355LX on the weekend, was great to catch up and shoot the breeze. Very excited to hear about the Pro Touring idea for his new project.
He also offer some used 225 45 16" rubber from his Targa days for me to use to fit up on my car. Very appreciative mate.
I have re-ordered some parts that I got wrong a few years back.
On order is:
Quicktime 6036 Bellhousing
Tilton 51-4452 168 tooth Flywheel.
ATL 80 litre foam fuel tank FIA approved.
What I will have for sale is:
Quicktime 6010 Bellhousing
Tilton 153 tooth Flywheel
Tilton Super Starter
All those parts will suit a SBC. The bellhousing mates to Saginaw, Muncie, Richmond, Tremec TKO
So if you know anyone who is building a SBC, let them know about these parts??
#686 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 May 2014 - 12:36 AM
Interesting time I'm having with the Clutch disc pack as well.
Tilton think that between manufacturers 1 1/8 and 1 5/32 Clutch input shaft diameter can be the same thing.... WTF??
The clutch input shaft on my Jerico is 26 spline by 1 1/8" or 1.125". How would a clutch disc with 26 spline by 1 5/32" fit??
Anyone know something I don't........
#687 N/A-PWR
  • 9,639 posts
Posted 21 May 2014 - 12:59 AM
Hi Craig,
not sure about the splines fitting, but this Link, shows the Nominal O.D being the same:-
http://www.powertrai... Pack 7.25.html
so maybe, they just got mixed up with one and not the other
edit,
just re-read the other bit, looks like they can both come in 26 spline, and both have the same O.D., but we would have to ask for that
Edited by TORYPOWER, 21 May 2014 - 01:03 AM.
#688 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 May 2014 - 01:11 AM
Interesting link, thanks for that Dave. Funny that they have Jerico in the line that shows both.
Maybe they can refer to either dimension and they are the same, doesn't make sense though cause there not.
#689 N/A-PWR
  • 9,639 posts
Posted 21 May 2014 - 01:15 AM
That is Strange indeed Craig,
was thinking nothing would come up, but Bingo it did.
#690 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 May 2014 - 10:03 AM
Well done Dave :clap:, the info you found is true!! Good stuff mate. :D
I have just had confirmation from Jerico that 1 1/8" and 1 5/32" are the same. Who would have guessed.
So I'm good now to go ahead and order the Clutch disc pack. :spoton:
#691 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 06:58 PM
Been doing bits and shits and boring stuff. No point taking photos of that!!
All parts I have ordered are on the way.
Bellhousing
Fuel tank
Clutch disc pack
Fly wheel 168T
Painted a few things today, bumper brackets and headlight backs. Boring, no pictures.
What is worthy of a picture is the diff. I finally got round to unpacking it! Only taken 4 months. How tough is that.8yvy8aqa.jpg
When a few things like tyres on rims, getting stings and shocks for the rear and getting bushes in the trailing arms in, I will bang it in snd get the measurement needed for the watts.
#692 _Viper_
_Viper_
Posted 31 May 2014 - 07:33 PM
Nice Diff Craig... What are the mounts for that the cradle is bolted to? Swaybar?
#693 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 07:44 PM
Hi Clint, those brackets will be part of the 3rd link arm that will be manufactured later.
#694 _Viper_
_Viper_
Posted 31 May 2014 - 09:05 PM
Oh I see... Look forward to seeing that, so the upper arm mounts wont be used or the lower?
#695 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 09:18 PM
Lower arms will be used, upper arms will be made redundant. Uppers will be installed as per rules but the bush will be sponge.
There is a bracket under the centre of the diff, the plan is to run some SHS from that bracket up to the gearbox mount. The arm will follow the length go the tail shaft. The brackets I used for the stand in the picture will be used to strengthen the arm. May not need it, not sure. I have seen one that did it that way. Easier to have the bracket and not need it than to need it and not have it.
#696 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 09:25 PM
Clint, have a look on page 10 of this thread and you will see where I am headed with the 3rd arm. Post 233 and 245 I think.
Edited by eyepeeler, 31 May 2014 - 09:26 PM.
#697 _LXSS350_
_LXSS350_
Posted 31 May 2014 - 10:19 PM
Been doing bits and shits and boring stuff so I've been eating lots of cake and avoiding doing any work or jumping on the scales. No point taking photos of that!!
What rear discs and calipers did you settle on?
Those rear wheel studs look wider then your racing taxi's rims/tyres. ...... LOL
#698 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 10:47 PM
The caliper is an AP Racing CP5200 and a CP3580 295 dia 28mm thick disc.
LOL, long studs they are.
#699 _LXSS350_
_LXSS350_
Posted 31 May 2014 - 11:24 PM
You didn't want to add adjustment to your diffs lower trailing arm mounts? That way you can fine tune your rear IC and squat. Fine tuning your f/r weight transfer gives you that drive esp out of corners. Also depending on your 3rd arm/watts set-up you can really make a live axle not so bad with the right rear IC range adj.
#700 eyepeeler
eyepeeler
  • 1,959 posts
Posted 31 May 2014 - 11:37 PM
Would love to mate, that's what I would love to be able to do. Haven't seen that before though, you built that yourself?
Unfortunately the rules of IP won't let me modify that from standard. Will have a look again as it's been a while since I looked at that part of the rules.
6 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
    Bing (1)
