IPRA 4 Door LX
#51
Posted 16 October 2011 - 10:49 AM
Glenn
#52
Posted 16 October 2011 - 01:47 PM
I know, bit dissapointed i had to do that. Live and learn as they say.from the looks of that, you might as well have made your own engine mounts!!
Glenn
#53
Posted 16 October 2011 - 01:58 PM
Thanks for the comment, could say the same about your car as well. Have been keeping up with your build thread and I bet you can't wait to get it done. Looks awsome. My daughter loves the colour, big fan of purple.awesome build mate, looking tops, love the dry sump set-up.
I've fitted a 6 speed behind mine, but not sure how the jerico box compares dimensions wise, It's looks a bit longer from the pics than the 6 speed. I ended up cutting the whole tunnel out and starting from scratch, also had to cut into the crossbrace in the floor pan, so had to find another way to brace the tunnel to keep the engineer happy. Dirtbag has some good pics of how he did the one in his brothers UC in one of his threads.
As welby said andy has done it also and is a wealth of information.
Not sure how much of the trans tunnel will have to be removed. Litre8 may know as he has a Jerico in his car. Might send him a PM later in the week.
I am sort of flying half blind in some areas, I know what I want to do but which is the best way to go. Like with the engine mounts, knowing what I know now I would have been better off making my own!!
#54
Posted 16 October 2011 - 04:03 PM
#55
Posted 19 October 2011 - 11:32 PM
When he did the roof it all worked not to bad. I was dreading how it would go. There is a slight bit of warping, didn't see it at first but did later, does anyone have suggestions as to how to fix this or do I just leave it and body fill it later?
End result. I think it is a good base to start with.
Edited by eyepeeler, 19 October 2011 - 11:36 PM.
#56
Posted 05 November 2011 - 09:53 PM
I have to cover up all holes in the cabin at some point and the rear parcel shelf will come out. It hasn't had the speaker holes cut out and looks in good nick. Anyone who wants an un-cut parcel shelf for a restoration let me know.
#57
Posted 12 November 2011 - 07:13 PM
She has known from the outset that any present to do with anything Torana is well received!! The kids are well aware of this as well. By the looks of the puzzle Brocky is just in front!
Just as side note, she gave me the puzzle so I might spend less time on the computer which means this Forum!!! Well at least until the puzzle is finished.
#58
Posted 08 December 2011 - 09:59 PM
Cage 09.jpg]
Using the rottisserie for getting a good weld on what would be an upside down weld has been a good help. Wasn't the plan from the begining to do it this way, I was chatting with a mate about how in postion welding can be a prick and he just said "why not put it on the rottisserie". Damn good idea!
This is where I got to.
#59
Posted 09 December 2011 - 05:30 PM
#60
_Viper_
Posted 09 December 2011 - 06:58 PM
#61
Posted 11 February 2012 - 09:54 PM
Anyway since I had welded the underside of the roll cage it was time to weld up the top. As I had cut holes in the floor under the mount for the Main Hoop all I had to was break the tack's of the mount and drop the Cage down so I could get to the top. Worked a treat doing it this way.
You can see the holes I cut in the floor to drop the Main Hoop down. I got the idea from the Miller welding website. Very informative read.
Not a lot of room to move!!!!
Even if I can spend a couple of hours getting something done it's getting me closer.
#62
_LXChev366_
Posted 15 February 2012 - 08:21 AM
Contact your local CAMS Car Inspector to find out what is legal with the cage in IPRA....and get him to go through what he needs to see before you get to far down the road and have to reverse things you thought was legal etc.
One thing with IPRA is try not to change the Body shell too much as it must stay unmodified in most area's.
Also log book it as an A9X so you have the freedom to have a Bonnet scoop etc...although you may not need it with it being Fuel Injected. A9X Flares, Front and Rear Spoiler are legal as these are allowed on EM cars.
If you are not already on it...check out the IPRA Forum for newbe tech idea's.
The pedal box must mount close to the original position as a guide...any Q's let me know.
Mine runs a Chev 350 (366 CI) 5 speed TKO600, Ford 9 Inch etc.
Pete
#63
Posted 15 February 2012 - 06:15 PM
I don't plan on changing the body shell other that fitting the flares, front and rear spoiler. Have you got a scoop fitted with hole in the bonnet?
Got any photo's of what you built. Would love to see how someone else went about doing it.
I have the same Forum name in the IP website as here.
Cheers,
Craig
Edited by eyepeeler, 15 February 2012 - 06:16 PM.
#64
_LXChev366_
Posted 15 February 2012 - 07:13 PM
mine is loged as an SLR5000...so no hole and no scoop. It was logged way back in early 90's, but didnt see the track until 2005.
Being logged as an SLR make no difference at all...it would be the same as calling it a Torana S...no advantage.
I have been off the track for 4 years now...have done other things...I bought a couple Hatchback LX's, turned 50 recently, I have bought some investment property's, new Girlfriend etc...so track time is on hold for now.
I basically achieved my aim with the category... I won my Class 2 years in a row (06 & 07)...so was happy with that. For the money Spent that's all I could have hoped for...
Here is some pics of it
#65
Posted 15 February 2012 - 09:18 PM
That pic is on the IPRA Forum!!! Tough looking car. Great to hear you had fun and won some races in it. Thats what my build is about, having some fun.
#66
Posted 15 February 2012 - 09:41 PM
Also good choice of engine
Edited by Dasman56, 15 February 2012 - 09:47 PM.
#67
Posted 15 February 2012 - 09:47 PM
That's great to hear. Do you get any problems from the EO about having the hole in the bonnet? Not sure how rigid the ruling is as it seems to be a can of worm's on the IP Forum as I said earlier. Which State do you run in?Both our ipra torana's have been running bonnet scoops for over 15 years now. Log booked as "Lx Torana" Then again we don't see Good old TT over our way that much.
_LXChev366_
Posted 15 February 2012 - 09:48 PM
I won my class...not any races...my best was 8th Outright.
I was up against RX7's and 2 Godzillas...not a hope in hell in winning any races...well not with what I spent.
this is what I am currently working on....has been on the burner for 2 years now..very slow...but thats ok.
78 Brock A9X Replica...
#69
Posted 16 February 2012 - 05:11 AM
At the same time.
#70
_The Baron_
Posted 16 February 2012 - 08:24 AM
We haven't had any problems with ours. But there is another LX that originally had the hole cut square to suit his air box . From memory he had to put in a filler panel with a round hole and all was ok. We have 5 toranas in SA Racing now. Just never seem to be at the same race meetings
At the same time.
The production A9X had a rectangle hole not round..........throw that into the mix.
#71
Posted 16 February 2012 - 08:51 AM
#72
_LXSS350_
Posted 16 February 2012 - 10:49 PM
Picked the engine up from SRE today. The dry sump looks trick!!
What is the depth of the ARE sump over the K-Frame/Steering rack?
#73
Posted 17 February 2012 - 12:58 PM
That's why Les parked the A9X and took over an RX7!!I was up against RX7's and 2 Godzillas...not a hope in hell in winning any races...well not with what I spent.
Grant..
#74
Posted 18 February 2012 - 09:34 PM
Because the sump pump clashes with the Tuff Mounts in original form I had to modify them as seen in an earlier post. With modifying them came the problem of location of the mount on the K Frame. As you can see in the picture I am moving them back to get the same engine locaction over the K Frame. The obvious problem with doing this is the steering rack. Will sort out that dilemma later. As I am still working on this I plan to have between 5-10mm clearance between the K Frame and Sump.
You can see where the steering rack will cause problems.
Posted 18 February 2012 - 09:40 PM
Pete, Won your class won your race. Who cares about other cars in other classes. You raced other cars in your class and won. Bloody Rippa I reckon.
