IPRA 4 Door LX
1672 replies to this topic
#876 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 27 September 2014 - 09:43 AM
There will be a couple of us southerners looking for something to do on the Saturday night.
#877 Ice
  • 15,204 posts
Posted 27 September 2014 - 10:23 AM
Im sure we can arrange something Laurie Dinner Date ??
#878 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 27 September 2014 - 10:28 AM
Sounds a bit extravagant. BBQ is more than adequate buddy.
I guess we can't be too far from Welbys shed as the cars will be left there and we may also be swagging there as well.
#879 Ice
  • 15,204 posts
Posted 27 September 2014 - 10:30 AM
BBQ sounds good
#880 eyepeeler
eyepeeler
  • 1,959 posts
Posted 02 October 2014 - 07:45 PM
Got the steering column in that Welby refurbished for me. Look brilliant. Thanks mate.
#881 eyepeeler
eyepeeler
  • 1,959 posts
Posted 02 October 2014 - 08:16 PM
Going to have a double Uni joint. Doesn't quite line up.
#882 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 October 2014 - 07:14 PM
Excuse the duct tape!!
#883 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 03 October 2014 - 07:40 PM
Are you sure you need a double?
Maybe just a dampener to lengthen the coloumn and then a single uni to join ?
#884 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 October 2014 - 07:41 PM
Coming up is the fun part of getting a set of pipes past that!! ajugena3.jpgumujy2y8.jpg4yve2ezy.jpg
#885 76lxhatch
  • 7,208 posts
Posted 03 October 2014 - 08:16 PM
I would definitely try to get the bottom uni closer to the steering rack for maximum header clearance/space if at all possible
#886 myss427
myss427
  • 1,636 posts
Posted 03 October 2014 - 10:07 PM
On the LS1 conversions I have worked on it was best to put a longer steering rod between the two knuckles, also for the rear pipe coming out of the head we shortened the outside of the column  and just let the steering shaft  untoched for more clearance. Made it much easier for extractor clearance.
Edited by myss427, 03 October 2014 - 10:08 PM.
#887 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 12:03 AM
Might try it with the extension on the column side instead of the rack side. Good point fellas.
You have any photos of what you did?
#888 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 12:05 AM
There is quite a bit of difference in the alignment of the 2 shafts. I need 2 uni's for that reason.
#889 _LS1 Hatch_
_LS1 Hatch_
Posted 04 October 2014 - 01:14 AM
I shortened the column on mine too, to try and get a little more room for bending the rear pipe around..
And make sure you use high-temp duct tape on it around the headers. :D
#890 _LS1 Taxi_
_LS1 Taxi_
Posted 04 October 2014 - 07:57 AM
Also for pipe clearance purposes, a few guys have redrilled the steering column plate which bolts onto the firewall to shift it towards the rail 10mm or so...
Sometimes it makes all the difference :)
I love this project.
#891 _greg2240_
_greg2240_
Posted 04 October 2014 - 11:38 AM
if anyone can get the pipes thru there I'm sure you can by the quality of your work so far, keep it up.Greg
#892 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 02:42 PM
Tacked on a bit extra shaft to Shift both uni's down lower to the engine mount. Provided a bit more space. Have to machine up parts now to finish it. yma2e9u8.jpgratybu4u.jpgesudu2yj.jpg
#893 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 02:47 PM
#894 ls2lxhatch
  • 5,332 posts
Posted 04 October 2014 - 03:11 PM
If you are not happy with the setup then it may be worth considering revising the engine mount design. You could unbolt and flip the lower half of the engine mount then move the mounting point on the k-frame away from the steering shaft.
Edited by ls2lxhatch, 04 October 2014 - 03:13 PM.
#895 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 03:44 PM
Got the bar which hold the Watts in right position. Will drill holes and tack it all up early next week to check fit. ygamaju7.jpgmazu5ehy.jpg
#896 eyepeeler
eyepeeler
  • 1,959 posts
Posted 04 October 2014 - 08:25 PM
Cheers Greg, looks like what I did today will help with pipes getting down and past the column and starter motor.
#897 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 October 2014 - 07:05 PM
Finished drilling all holes and welding bar. Tacked it in position between rear chassis rails and trial fit the Watts. 9eha7ymy.jpg
#898 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 October 2014 - 07:30 PM
#899 _LS1 Hatch_
_LS1 Hatch_
Posted 09 October 2014 - 02:02 AM
Sure is a trick looking setup!
And good having new wipers in case a storm moves through the shed. :D
#900 _Agent 34_
_Agent 34_
Posted 09 October 2014 - 05:35 AM
Really good to see your ingenuity with the watts link on the rear end.
Keep going
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
