IPRA 4 Door LX
1672 replies to this topic
#926 eyepeeler
eyepeeler
  • 1,959 posts
Posted 22 November 2014 - 08:02 PM
can you use the cast manifolds or do you want hi po ones?
Hey Greg, don't plan on using the cast manifold, just had them handy and thought I would cut them up to get an idea of what I'm up for when I make my own manifold.
Was so surprised when the passenger side bolted in with no problem uncut.
Next week I hope to make a start on the fab work.
#927 _greg2240_
_greg2240_
Posted 22 November 2014 - 09:07 PM
nice, I hope to see this beast going at the track soon, so please let us know when you debut it.
#928 eyepeeler
eyepeeler
  • 1,959 posts
Posted 27 November 2014 - 08:56 PM
Ordered and received the first bits to make the headers. Now comes the head scratching, LOL.
Went for 2" off the manifold, 2.5" after 1st "Y" and 3" to muffler.
Got 1 bit in, don't know how it will go???
Will be tight as a nuns proverbial.
#929 _mumbo_
_mumbo_
Posted 27 November 2014 - 09:32 PM
Are you aload to take the lip of the chassis rail ?
If you are do it makes a huge differance ( pipes & plugs )
#930 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 27 November 2014 - 09:53 PM
And you need to get 4 pipes through that^^^ gap. Correct?
#931 eyepeeler
eyepeeler
  • 1,959 posts
Posted 27 November 2014 - 11:35 PM
Hey Kev, not sure if it's ok to do that rule wise?? Wouldn't think so but I do agree with you, extra room would be handy.
Not sure that will happen, 4 pipes may be asking a little to much. Might have to get the first "Y" up above the steering column.
#932 Jay#2
Jay#2
  • 94 posts
  • Car:1976 LX 4 door
Posted 28 November 2014 - 06:29 AM
I'll be watching how you get on with the headers as I'll be doing that at some point. Could you trim the end of the steering column back closer to the bulkhead?
#933 myss427
myss427
  • 1,636 posts
Posted 28 November 2014 - 07:38 AM
I've buit a few sets of 4 into 1's for LS1's into Toranas, best for two pipes to go in front of starter and then under, and two down the side as you have started. And it helps heaps if you take the outer cover off the column up to the fire wall, gives you more wiggle room.
#934 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 November 2014 - 08:19 PM
Used the idea of cutting back the steering column outer. Was careful to cut it straight so the bush and bearing went back in cleanly. 72a0cd88a4b9af8bd83f24a01223dbdc.jpg
Went back in easily enough. Hooked up the steering again.
#935 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 November 2014 - 08:24 PM
This gave me a heap more room. Got a path for 2 pipes to go now. 56d9958fb0621564a7edb5f4ddb9c67a.jpg
Doing this, welding a shirt ring in the bend to seat it properly in the flange.
The path for the first 2 pipes.
#936 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 November 2014 - 08:28 PM
Got the Motec dash today. Car Porn.
#937 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 November 2014 - 02:19 PM
Thought it would be best if I put in the spark plug leads as well, don't need a problem with them fouling with the pipes.
It did change the angle which I had the pipes in at last night.
#938 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 November 2014 - 02:24 PM
So gave put in a small offset in the pipe closest to the firewall to get the angle back, and run the next one around the steering column,
Next was to change direction of that pipe to get along the same line as the first pipe.
#939 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 November 2014 - 03:21 PM
I'm done for the day!!
Got this tacked up. Pretty happy for a first attempt at exhaust headers.
#940 _greg2240_
_greg2240_
Posted 29 November 2014 - 05:12 PM
Gee your a patient man, that would do my head in, do the front 2 pipes come out under the starter and are the back 2 the hardest or should I say tightest fit?
#941 eyepeeler
eyepeeler
  • 1,959 posts
Posted 30 November 2014 - 11:23 AM
Front 2 pipes I hope to head around and past the top arms.
I have room only just for 2 of the 2 1/2" pipes down past the starter motor and sub frame.
Edited by eyepeeler, 30 November 2014 - 11:23 AM.
#942 N/A-PWR
  • 9,654 posts
Posted 30 November 2014 - 11:41 AM
Nice Job Craig,
Every inch counts.
A like Button for You.
#943 TUF 308
TUF 308
  • 169 posts
Posted 02 December 2014 - 02:12 PM
Now for the other 2 pipes :)
#944 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 December 2014 - 07:12 PM
The reason I don't get onto my car is work gets in the way.
Bought a second hand collar maker, pulled it apart and gave it a good clean and splash of paint and reassemble.
#945 _greg2240_
_greg2240_
Posted 03 December 2014 - 07:21 PM
forgive my ignorance but what does that thing actually do? I know what you mean about work though!!! cheers greg
#946 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 December 2014 - 09:17 PM
That machine makes the metal collar that you see on the sides of sheetmetal airconditioning duct, the collar is used to duct tape flexible duct to, which goes out to the diffuser.
#947 _The Baron_
_The Baron_
Posted 03 December 2014 - 09:46 PM
Hey Craig, you might want to replace the cotter pin nylock nuts with two nuts locked together. The heat may affect the locking action.
#948 eyepeeler
eyepeeler
  • 1,959 posts
Posted 03 December 2014 - 10:08 PM
Do you think a crush nut would be ok Darky? Your right though, nylocs would turn to jelly being that close to the header pipes.
#949 _The Baron_
_The Baron_
Posted 04 December 2014 - 04:46 PM
Yes if the cotter pin thread is hardened properly, otherwise the thread may gal up. Two nuts are always better than one. :)
That is if you have the room!
#950 _Agent 34_
_Agent 34_
Posted 04 December 2014 - 06:33 PM
Craig,
just keep in mind the engine torque on the gaps. pretty sure it's drivers side first then back off passenger side.- 6 pack
thats some tally ho paper clearance. the exzorst is tricky with thoes clearance.
whilst it's not the same my car carby ( battery tray) and exhaust ( top control arm) were rubbing in de acceleration. three cents.
big effort on this car man.
