IPRA 4 Door LX
1672 replies to this topic
#951 76lxhatch
  • 7,208 posts
Posted 04 December 2014 - 07:58 PM
Yes if the cotter pin thread is hardened properly
They're not usually very good in that respect. Originals had a spring washer
#952 eyepeeler
eyepeeler
  • 1,959 posts
Posted 05 December 2014 - 06:02 PM
Throttle Body arrived today. 95mm bore.
How cool does that look.
#953 eyepeeler
eyepeeler
  • 1,959 posts
Posted 06 December 2014 - 04:31 PM
Trying to thread the needle, LOL.
This is going to get interesting.
The passenger side looks like it will be a tad easier!!
#954 _prule_
_prule_
Posted 10 December 2014 - 08:59 AM
Hi mate,
Make sure you have enough room between the upper control arm and the extractors.
With a Torana running A050 tyres. you'll need 4.5 - 5.0 degrees of negative camber which moves the upper control arm a lot closer to the pipes. (Up to 6 deg with some tyres)
I can see from the pics that you have it currently set with hardly any camber.
Passenger side looks OK, hard to tell from the pics, but the driver's side might be an issue.
Probably pay to dummy it up with a lot of camber.
Paul
#955 _LS1 Hatch_
_LS1 Hatch_
Posted 10 December 2014 - 09:42 AM
If you need anyone to test it out, it would look pretty nice on my Edelbrock intake I suppose :D
#956 eyepeeler
eyepeeler
  • 1,959 posts
Posted 10 December 2014 - 10:47 PM
Hi mate,
Paul
Cheers Paul, will certainly look at that before going much further. Appreciate the tip.
How are you going? Your car going well? I watch the YouTube stuff you post off and on, keeps me motivated.
Haha Jeff, It would look super tough on your manifold.
#957 _prule_
_prule_
Posted 11 December 2014 - 08:34 AM
Hi Craig,
Going well. Just finished the worlds longest engine rebuild. Converted the Group A 304 to a 355 stroker. Will be taking it for a test run this Saturday.
Have been following your car build with interest. Looks like its getting close. Keep up the good work.
Paul
#958 eyepeeler
eyepeeler
  • 1,959 posts
Posted 17 January 2015 - 12:36 PM
Continuing the puzzle.
First 2 are tacked to flange, now for the second 2.
04818c88ca7c18a279aa66f5c41722e8.jpga5d81e93a18424399fb13c563c783dc9.jpg4f6115e7995910b09830f23a37183a65.jpg
#959 eyepeeler
eyepeeler
  • 1,959 posts
Posted 17 January 2015 - 07:35 PM
Hi mate,
Paul
Hey Paul,
Thanks for the tip. Will keep the rear of the upper arm as free as I can when snaking the pipes past there.
I see Peter is bringing his red Torana out of retirement, great news.
I really need to push this thing along and get out there myself. Been long enough, 36 bloody pages on this thread!!
#960 _Viper_
_Viper_
Posted 17 January 2015 - 11:51 PM
Not been on here for a little while, you have been busy Craig :D
Doing well with the pipes!
#961 Racehatch
Racehatch
  • 1,027 posts
Posted 19 January 2015 - 06:20 PM
Looks good Craig, watch the starter motor, you may need to make a heat shield or wrap the pipes in that area as I have had issues with mine getting hot due to heat soak. Have you worked out what you are going to do with the muffler yet?
BTW who did you end up getting the Jerico through again, I want to upgrade mine from the 4 to 5 speed...
#962 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 January 2015 - 08:42 PM
Nearly there with pipe number 3.
1 more cut and it should be ready to fully tack.
Bit hard to see in the photos now.
#963 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 January 2015 - 11:29 PM
Hey Sam, hope you had a good Christmas.
Yeah the heat from the pipes will be a massive concern, I am going to get them coated and wrap what I can to minimise the heat transfer.
The Jerico came direct from Jerico in North Carolina. I emailed and spoke to Scott, but that was a few years back, LOL.
The number I used to ring the was 0011 1 704 782 4343
I can email you the work order I filled out for them to manufacture my gearbox if you like??
I can also share the invoice if you need a point of reference for price.
#964 _LS1 Hatch_
_LS1 Hatch_
Posted 20 January 2015 - 01:41 AM
The wrap seems to help for sure from what I have noticed on mine at least..
#965 Bigfella237
Posted 20 January 2015 - 02:00 AM
Aeroflow do a neat looking heat shield for LS engine starters too...
Attached File  $_57.JPG   52.37K   5 downloads
http://www.ebay.com/...657f69a&vxp=mtr
...but I'm not sure if it'd fit your Tilton starter?
I'm sure there would be many other companies doing these too.
#966 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 20 January 2015 - 08:03 AM
HPC coating will reduce the heat transfer as well.
Dearer than tape of course
#967 Racehatch
Racehatch
  • 1,027 posts
Posted 20 January 2015 - 09:35 PM
Nice work big fella! Will have to check that out...
Re the gearbox, cheers Craug I'll get in touch with them - still recovering from getting the new helmet/hans/seat/harness I needed to upgrade for this year, so it might not be for a little while...lol
#968 _The Baron_
_The Baron_
Posted 22 January 2015 - 01:29 PM
I was all excited about LS series motors into LH/LX/UC...........................until I saw the pain in putting pipes in.
One word (sort of).......ARGHHHHHHHHHHHHHH!
#969 eyepeeler
eyepeeler
  • 1,959 posts
Posted 23 January 2015 - 05:26 PM
Pipe 3 in the clear.
#970 _LS1 Taxi_
_LS1 Taxi_
Posted 23 January 2015 - 05:59 PM
Air isn't a good conductor of heat.
Your starter will get hotter from heat soak through the block than it will from a 10mm air gap between the starter and your pipes.
I wouldn't bother with wrapping...need to show off them sexy welds ☺️
#971 eyepeeler
eyepeeler
  • 1,959 posts
Posted 23 January 2015 - 07:02 PM
Pipe 4 well on the way.
Bit easier this one.
#972 Bigfella237
Posted 23 January 2015 - 07:03 PM
Yeah but a header pipe gets ten times hotter than the block?
I meant to ask earlier eyepeeler, where did you get the extractor kit from? And would you say it had everything you needed or will you have to buy extra bends?
Also, what are your plans for getting that driver's side header in and out, will you just have to remove the two steering knuckles or will the column need to be withdrawn back into the cabin?
#973 eyepeeler
eyepeeler
  • 1,959 posts
Posted 23 January 2015 - 09:10 PM
Hi BigFella, I just went to my local exhaust shop and asked if he could sell me some mandrel bends and some pipe. I bought 180 degree and 90 degree bends.
To get the header out I will have to do as you say, remove steering knuckle and column then drop the sub frame out of the car with engine on it.
I don't think there will be room enough to get them out without dropping the sub frame out.
Cheers,
Craig
#974 Bigfella237
Posted 23 January 2015 - 10:37 PM
Thanks Craig,
That's a PITA but I hopefully it will only need to be done once!
So where did you get the flange plates that bolt to the heads, I'm assuming they must be custom made for 2" primaries?
#975 eyepeeler
eyepeeler
  • 1,959 posts
Posted 23 January 2015 - 10:53 PM
Thanks Craig,
I got that from the exhaust guy as well. They had to laser cut them for 2" pipes.
If you had the dimensions you could approach a laser cutting business directly? That's what I am going to do if I need more.
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
