IPRA 4 Door LX
1672 replies to this topic
#1001 eyepeeler
eyepeeler
  • 1,959 posts
Posted 08 February 2015 - 10:40 PM
Rear O2 sensors came in around Cat3 spec
You definitely won't need them on a racecar... don't even have to run cats do you ?
Don't need cats.
Pick up more parts for the exhaust on Monday.
Other than Wilkos you mentioned in a PM, you know anyone to look at my steering?
#1002 dattoman
Posted 09 February 2015 - 12:24 AM
Get ozy to have a look :)
Red Trev down the road is good with old stuff too
#1003 ozyozyozy
ozyozyozy
  • 953 posts
Posted 09 February 2015 - 09:35 PM
No cats Datto for racing😊, guess the powers at be haven't figured that out yet.
Will do craig, already made couple of changes to meet circuit regs, when the motor is back in, will get the car audited.
The ute I play with is planing on been out there too.
So more incentive for yours to be out there.
They will have someone looking after driving standards also to stop intentional buff and barge.
#1004 eyepeeler
eyepeeler
  • 1,959 posts
Posted 14 February 2015 - 11:44 PM
Different path on the passenger side, bit easier with nothing in the way.
#1005 Potta
Posted 14 February 2015 - 11:58 PM
Looking good, looks like a pr!ck of a job getting those pipes through though.
How is your to do list looking?
Must be getting pretty short now.
#1006 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 February 2015 - 07:42 PM
It's not that pretty but it will do the job.
#1007 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 February 2015 - 09:13 PM
#1008 eyepeeler
eyepeeler
  • 1,959 posts
Posted 19 February 2015 - 09:33 PM
#1009 Ice
  • 15,221 posts
Posted 19 February 2015 - 09:37 PM
Looking Good Craig
Epic job by the looks of it
#1010 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 19 February 2015 - 11:07 PM
It might not be pretty, but it looks like the job is virtually done.
#1011 Potta
Posted 19 February 2015 - 11:22 PM
Yep, up to the easy but now!
#1012 76lxhatch
  • 7,222 posts
Posted 20 February 2015 - 07:27 AM
Looks good, but I'd highly recommend ditching those flanges and getting some 3 bolt ones if you can.
Love the look of the gearbox, pure function
#1013 _Bomber Watson_
Posted 20 February 2015 - 08:10 AM
Yep, three bolt is far better.
Or i noticed summit now sells V band kits for about the same price as two three bolt flanges, a gasket and bolts now.
If i was going to make another exhaust system i would definitely use these:
http://www.summitrac.../parts/vpe-1491
Probably not so critical where you have them there, but if you put another lfange before the diff, they would be very handy, as you can rotate the two rear tailpipes slightly once its all said and done to help fit them properly :D
#1014 orangeLJ
Posted 20 February 2015 - 09:35 AM
V bands are amazing! 3 bolt flanges take up too much space.
#1015 _Bomber Watson_
Posted 20 February 2015 - 09:36 AM
And in my experience when making up mandrel bent systems, no matter how good it sits when you tack it up it always needs a slight tweak left or right once welded out, V bands will allow you to do this, 2 bolt or 3 bolt wont.
Chers.
#1016 _LS1 Hatch_
_LS1 Hatch_
Posted 20 February 2015 - 02:38 PM
Exhaust is looking good!
Those V-band clamps are a pretty cool way to go, but I just used similar 2 bolt flanges on mine as well and seems to work fine.
(PS. I still think the white floor looks too clean..lol)
#1017 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 February 2015 - 05:07 PM
Thanks for the heads up on the 3 bolt flange 76lx. Now that I have the flange and Jeff is using them, will stick with it for the moment. Money spent else where.
Cheers for that though.
#1018 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 February 2015 - 05:10 PM
Tacked the merge pipe in.
This is the perf pipe I rolled up out of flat sheet which will be the start of the muffler. Hotdog style muffler. Any ideas on the insulation to use?? Going with steel wool at this point.
#1019 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 February 2015 - 05:18 PM
Milestone reached!! The Monaro is on the boots, and man is it a tough stance.
Nice Torana in the background.
#1020 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 20 February 2015 - 06:55 PM
Might be better using fibreglass in the muffler rather than steel wool.
As it is going to spend most of its time going hard there may be enough heat and flame to ignite the steel wool.
If you dont believe it burns grab a bit and put a lighter to it. Be ready to drop it quickly.
#1021 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 February 2015 - 08:01 PM
I use fibreglass insulation all the time at work, would you use rockwool type or duct wrap style insulation?
#1022 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 20 February 2015 - 08:36 PM
The stuff Ive seen used is close to the fibreglass batt roof insulation.
#1023 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 20 February 2015 - 08:47 PM
Here's the stuff designed for mufflers.
http://trrautoparts....3372ed22e8e7676
#1024 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 21 February 2015 - 05:24 AM
Stainless steel wool not steel wool, as stated it will burn & rust in a very short space of time.
#1025 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 February 2015 - 11:39 AM
Work machines make it a bit easier to cut parts. Programmed that last night and cut it this morning.
Cleaned up parts
So far so good.
