IPRA 4 Door LX
1672 replies to this topic
#1026 _LS1 Hatch_
_LS1 Hatch_
Posted 21 February 2015 - 02:46 PM
Must be cheating some how or other having equipment like that at your disposal...ha ha
#1027 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 February 2015 - 02:55 PM
Different perf inner, better or not?? Thoughts....
#1028 Bigfella237
Posted 21 February 2015 - 03:06 PM
Which direction is the flow? If it's little end to big end I wouldn't be surprised if it acted like a megaphone!
Does the exhaust have to go over the diff or are you dumping it out the (or each) side?
#1029 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 February 2015 - 03:22 PM
Side exit both sides,
Was talking to a mate and that why I am looking at the megaphone muffler.
I can go up to 95dba on the track.
#1030 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 February 2015 - 04:15 PM
May as well give it a go.....
#1031 arrimar
arrimar
  • 3,134 posts
Posted 21 February 2015 - 07:25 PM
I wouldn't use v-bands in an exhaust (they're originally for dairy and brewery tubes)
Give some thought to where the flanges end up Craig. PITA when they get caught up on the trailer loading and unloading.
#1032 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 February 2015 - 09:39 PM
Got a heads up on this thread.
http://www.gmh-toran...dryer-exhausts/
Looks like I am heading in the right direction. Took these photos directly from that thread.
Attached File  image.jpg   45.49K   6 downloads
Attached File  image.jpg   46.32K   6 downloads
Attached File  image.jpg   58.09K   5 downloads
Attached File  image.jpg   71.43K   7 downloads
#1033 LJ RB30
LJ RB30
  • 1,041 posts
  • Name:Trevor
Posted 21 February 2015 - 11:27 PM
I think your confusing v-bands with Tri clover fittings! Tri clover use a neoprene (& other types) of gasket between the flanges & are retained by a raised rib in either side of the gasket! Common to dairy & brewing!
V bands don't have gaskets & are common on most larger turbo exhaust housing outlets! Look at any truck & you will see them
#1034 arrimar
arrimar
  • 3,134 posts
Posted 22 February 2015 - 04:06 PM
Really, well there you go. They looked just like Tri clovers to me. Doing them up when misaligned is a pain.
#1035 _Bomber Watson_
Posted 22 February 2015 - 04:15 PM
Similar theory totally different.
#1036 _Yella-5000_
_Yella-5000_
Posted 22 February 2015 - 04:19 PM
Looks the goods.  We were just advised to through a hot-dog muffler in behind where the two extractors collect.
#1037 LJ RB30
LJ RB30
  • 1,041 posts
  • Name:Trevor
Posted 22 February 2015 - 10:34 PM
Yep both do not forgive misalignment!
But totally different uses!
Id be going for the 2 or 3 bolt flange over a v-band anyday on an exhaust system (other than the turbo connection) as they are more forgiving when bolting up!
Anyway Eyepeeler! Awesome job on the car!
Edited by LJ RB30, 22 February 2015 - 10:48 PM.
#1038 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 February 2015 - 08:09 PM
Mounting Motec stuff.
Really appreciate the comment, cheers.
#1039 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 February 2015 - 09:44 PM
Welded up some more of the first muffler.
#1040 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 February 2015 - 01:16 PM
#1041 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 February 2015 - 02:26 PM
#1042 ozyozyozy
ozyozyozy
  • 952 posts
Posted 28 February 2015 - 03:44 PM
ooooo using a motec PDM very nice
#1043 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 February 2015 - 04:39 PM
#1044 _mello92_
_mello92_
Posted 28 February 2015 - 08:52 PM
Ohh that does look nice! Good stuff.
#1045 _greg2240_
_greg2240_
Posted 28 February 2015 - 10:20 PM
hi eyepeeler, just a quick question, how does it muffle anything if the exhaust gas doesn't actually pass thru anything or does it? the pic appears to show it go in n out the same path or is that the way its supposed to?
#1046 _Bomber Watson_
Posted 28 February 2015 - 10:23 PM
I dont believe its supposed to muffle to much...
Will make it a bit quieter.
Edited by Bomber Watson, 28 February 2015 - 10:24 PM.
#1047 _greg2240_
_greg2240_
Posted 28 February 2015 - 10:29 PM
how? just resinating around the small holes? looks like a straight thru, though I wouldn't know the 1st thing about these things but just curious.
#1048 _Bomber Watson_
Posted 28 February 2015 - 10:36 PM
Pretty much yeah.
Lots of mufflers are set up like that.
https://www.google.c...iw=1024&bih=642
More a resonator than a muffler i suppose.
#1049 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 28 February 2015 - 10:39 PM
I always wondered that myself.
Until I worked on a V16 Cat generator. Actually about 100 of them.
The module boxes they were in had perforated metal covering glass insulation on the inside.
If you walked close to the perforated wall it felt like you were deaf in the ear closest to the wall.
The wall seemed to absorb all sound.
The inlet tract for air circulation was open and very little noise penetrated outside.
#1050 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 February 2015 - 11:27 PM
Hey Greg,
Bomber is right, the muffler won't muffle that much, but it will do a little. In the area I work in, HVAC, we use sound attenuators on large industrial fans like the one below.
Attached File  image.jpg   15.69K   10 downloads
They take the sound out as the air passes through them. I have no idea on the science of how that happens, but it does work.
I have got zero science in the build of my muffler other than the principle of what we use at work and the megaphone design of the Group C cars. I can go to 95DB in noise levels, hope it works to that level??
I does look tough though, I like it. Even if I do say so myself, LOL.
