IPRA 4 Door LX
1672 replies to this topic
#1076 eyepeeler
eyepeeler
  • 1,959 posts
Posted 09 March 2015 - 08:51 PM
exhaust looks great mate, but wouldn't the air going past the tip catch the edge and try and force exhaust gases back in and slow you down?
I did have a moment where I went hmmmm, I wonder if that will catch air??
Not sure to be honest? It is parallel with the car so if I had side skirts it would be flush with that. I didn't think that would to much of a problem as it common to see exhausts come out at an angle and sit flush with the line of the side skirt.
So I thought, all good, go with that. Plus it looks tough as well.
I can cut them back square if needed, there is plenty of length to do that.
#1077 eyepeeler
eyepeeler
  • 1,959 posts
Posted 10 March 2015 - 08:58 PM
Welded and clean ready for paint.
#1078 eyepeeler
eyepeeler
  • 1,959 posts
Posted 11 March 2015 - 08:40 PM
All cleaned and painted in high temp paint
#1079 Bigfella237
Posted 11 March 2015 - 10:48 PM
#1080 eyepeeler
eyepeeler
  • 1,959 posts
Posted 14 March 2015 - 12:29 PM
Machine shop guy dropped off new steering uni joint set up.
Got 3/4DD Borgeson uni's and re did the shafts.
#1081 eyepeeler
eyepeeler
  • 1,959 posts
Posted 14 March 2015 - 03:06 PM
Engine back out of the car to get headers welded up.
#1082 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2015 - 01:50 PM
All tacked and fixed to the bench to minimise movement.
#1083 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 20 March 2015 - 04:14 PM
Mate everything you have done on this car looks fantastic! Its a really well engineered car which as i can see. Its spot on great work
#1084 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2015 - 04:35 PM
Cheers Bart, appreciate that,
On with the welding....
#1085 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2015 - 06:35 PM
Looking ok....
Couple of spots that need tapping
#1086 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 March 2015 - 02:19 PM
All cleaned and hopefully ready for heat treating. Going to coat them the heat coating to minimise engine bay temps.
#1087 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 March 2015 - 02:46 PM
Other side tacked down tight, ready for welding.
#1088 Rockoz
Rockoz
  • 4,043 posts
  • Name:Rob
Posted 21 March 2015 - 02:59 PM
Whats the difference in lengths between the primaries and secondaries?
Loving the work.
#1089 davea79
davea79
  • 332 posts
  • Name:David Angel
  • Car:Never Mind
Posted 22 March 2015 - 09:53 AM
You'll be up the front mate, surely top 10... I would hope.
If not there is no hope for any of us! No pressure:)
#1090 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 March 2015 - 07:49 PM
Loving the work.
Will measure them for you later if that's ok?? Been busy with work, bit of time for the car tonight. On I march with the welding....
#1091 Rockoz
Rockoz
  • 4,043 posts
  • Name:Rob
Posted 26 March 2015 - 08:51 PM
Just wondering if you got the lengths close to equal or just made them to fit thats all.
#1092 Heath
  • 18,394 posts
Posted 26 March 2015 - 09:22 PM
Looks like fun! Nice work mate.
#1093 bullitA9X
bullitA9X
  • 4,168 posts
Posted 26 March 2015 - 11:11 PM
awesome work craig your doing a great job mate...
#1094 eyepeeler
eyepeeler
  • 1,959 posts
Posted 28 March 2015 - 03:20 PM
Fark, something moved!!! Thought I braced it well enough. Goes to show huh, heat and metal = movement.
Easy solution will be to offset that last section I haven't welded in. Good thing I decided to leave it, was for this sort of reason.
#1095 dattoman
  • 16,487 posts
Posted 28 March 2015 - 07:47 PM
Let me know who does your coating and how much
I have to get a set done soon too
#1096 Shiney005
  • 9,634 posts
Posted 29 March 2015 - 10:46 AM
When you learn the secret to welding jobs not moving make sure you let me know. I was welding on a new cutting edge to a loader bucket, and I started with 1" tacks alternating from front to rear and worked my way out from the centre. It took ages and I really thought I had it done. Then about 10 mins after I finished, as it was cooling down I heard it go BONG, and I turned around to see a massive bow in it. Arrrghhh
#1097 ozyozyozy
ozyozyozy
  • 950 posts
Posted 29 March 2015 - 04:00 PM
I saw the pics of your holding jigs and laughed, not in a bad way, just coz I thought the lengths you have to go, to build stuff.
thumbs up mate
#1098 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 March 2015 - 07:17 PM
No worries Neil, will do. Interested in helping run brake lines, at setting it up?
I know what you mean Shiney, it's a sound that gives you the shits, all seems well and then.........well, you said it best.
thumbs up mate
Hahaha Daz, my son asked me why I was putting spider legs on the engine?? He's only 6 years old.
I thought it was going to work, but obviously not.
#1099 Bigfella237
Posted 29 March 2015 - 07:49 PM
I reckon the movement happened when you cut it off the bench halfway through to flip it up and do the other side?
Once in the jig it should've stayed jigged until finished, welding one side of all the pipes then releasing the tension didn't do you any favours.
Edited by Bigfella237, 29 March 2015 - 07:52 PM.
#1100 eyepeeler
eyepeeler
  • 1,959 posts
Posted 29 March 2015 - 08:45 PM
More than likely Andrew, your probably right. Welding the whole thing in the original jig setup was to hard.
I didn't post photos of some of the work, I had to cut parts out to properly weld other parts before taking and welding it back in.
The drivers side was the worst.
