IPRA 4 Door LX
1672 replies to this topic
#1376 _LS1 Hatch_
_LS1 Hatch_
Posted 20 March 2016 - 01:22 PM
Nice looking !  And good to see an update too. :D
#1377 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:06 PM
If you have a look back in the build, I was going to run with a fabricated oil tank for the dry sump up front of the car.
I have to run a 3 litre breather for that tank, which made me think about the practicality of having the tank up front. I decided to make another tank that I will put in the boot.
I decided to make the tank out of alloy and TIG weld it. I have welded everything else before, except for TIG welding alloy. This is my first go at it.
Attached File  07.JPG   164.22K   1 downloads
Attached File  08.JPG   129.06K   0 downloads
Attached File  09.JPG   190.48K   2 downloads
Attached File  10.JPG   161.93K   2 downloads
#1378 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:12 PM
The Baffles I hand made are not to any design, just what I thought would work.
Attached File  12.JPG   140.93K   1 downloads
Attached File  13.JPG   164K   1 downloads
Attached File  14.JPG   203.95K   0 downloads
Attached File  15.JPG   191.62K   0 downloads
Attached File  18.JPG   228.51K   0 downloads
#1379 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:15 PM
The tank on the right is the main oil tank, the 3 weld on fitting are 2@ -12 for the flow and return and a -6 for the breather.
The ank in the middle is the diff breather tank.
The tank on the left is the breather tank for the main oil tank.
I am yet to get the weld in fittings for the top of each tank.
Attached File  19.JPG   194.54K   1 downloads
Attached File  20.JPG   166.39K   0 downloads
Attached File  21.JPG   162.33K   0 downloads
Attached File  22.JPG   192.98K   0 downloads
Edited by eyepeeler, 20 March 2016 - 02:16 PM.
#1380 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:28 PM
The wiring loom for the car is all made. It was a mega mess to start with and took over a day to tidy up.
Attached File  02.JPG   142.92K   0 downloads
Attached File  03.JPG   213.4K   1 downloads
The boot space was the easiest to get tidy!!
Attached File  01.JPG   176.14K   1 downloads
#1381 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:32 PM
The tidy up and getting the wires sorted out. Cant tell you how many cable ties got used and cut off getting it right!!
Attached File  04.JPG   119.97K   3 downloads
Attached File  05.JPG   142.59K   2 downloads
Attached File  06.JPG   134.32K   2 downloads
Attached File  07.JPG   122.61K   2 downloads
Attached File  08.JPG   114.76K   2 downloads
#1382 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:39 PM
Wiring job done. That was a mammoth effort to sort that out.
Really happy with the look of it inside the car.
Now to get the car on the hoist and get the engine bay done.
Attached File  09.JPG   179.11K   2 downloads
Attached File  10.JPG   138.05K   1 downloads
Attached File  11.JPG   115.99K   1 downloads
Attached File  12.JPG   119.72K   1 downloads
Attached File  13.JPG   171.77K   1 downloads
#1383 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:51 PM
The 3 tanks got mounted into the boot of the car. Not a lot of room left in there either.
Attached File  01.JPG   177.21K   0 downloads
Attached File  02.JPG   170.22K   0 downloads
Attached File  02a.JPG   194.25K   0 downloads
#1384 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 March 2016 - 02:54 PM
Got all the oil pipes and hoses done underneath the car now.
Attached File  03.JPG   167.83K   1 downloads
Attached File  04.JPG   153.68K   1 downloads
Attached File  05.JPG   195.1K   1 downloads
Attached File  06.JPG   121.46K   0 downloads
Attached File  07.JPG   145.73K   1 downloads
I have to do the 4 steam port at the top of the block back to the radiator now, as well as tidy up the wiring in the engine bay.
#1385 bullitA9X
bullitA9X
  • 4,168 posts
Posted 20 March 2016 - 03:43 PM
Absolute awesome job your doing craig.....
#1386 _Agent 34_
_Agent 34_
Posted 20 March 2016 - 07:35 PM
yeah it's ridiculous.
attention to detail if top shelf.
ha - howed the header pipe wrap go - takes ages - my 6 i had to do over two days.
go man go !
#1387 _LS1 Taxi_
_LS1 Taxi_
Posted 20 March 2016 - 09:48 PM
So frOcking sweet. Awesome work!
For the steam pipes, I just routed mine into the top hose.
#1388 Ice
  • 15,204 posts
Posted 20 March 2016 - 10:59 PM
Love ya work Craig cant wait to see this on the track
#1389 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 March 2016 - 12:01 AM
Cheers Jeff, I thought I had better put something up on the forum before to long.
Cheers Daryl, appreciate it mate. It mutual though, you know I love that nice white hatch of your lads.
go man go !
Thanks Grant, the photos of the body work don't show how it really looks. All of the effort has gone into working on making it tough and reliable, not makng it look pretty.
Header pipe wrap took about 8 hours for both. I used way more than I thought I would.
Appreciate it Daz. I was considering a join in the hose to mount the steam pipes, but there is a -6 socket in the radiator I can use.
As the fittings which mount to the block are -3, I have got -3 to -4 inline flare expanders to run all 4 outlets into. -6 line into the radiator.
Cheers Gene, I can't wait to just get the engine started, let alone hit a track. LOL.
#1390 Racehatch
Racehatch
  • 1,027 posts
Posted 21 March 2016 - 03:21 PM
Good stuff, I like the round dry sump tank design better! As you have moved the tank in the boot, the hose run is now much longer, if it was me, I would consider -16 on the suction side to give you more volume to the pump - also make sure the hose is suitable for use under suction - some of the cheaper stuff has been known to collapse..
Edited by Racehatch, 21 March 2016 - 03:22 PM.
#1391 ls2lxhatch
  • 5,332 posts
Posted 21 March 2016 - 07:32 PM
Earls and Aeroflow make stainless hose support springs.
http://www.earls.com...upport-springs/
https://www.aeroflow...-support-spring
#1392 eyepeeler
eyepeeler
  • 1,959 posts
Posted 21 March 2016 - 11:58 PM
Cheers Sam, will definitely keep an eye on the supply side of it. Might look at -16 in any case. The hose I have used is Earls Proflex. It's pretty good hose.
How's your car going? would be keen to hear.
Cheers Andy, I had a look at the websites.
#1393 orangeLJ
Posted 22 March 2016 - 09:40 AM
Top work as always.
Clean tidy wiring and hose work always makes me smile. Such a small thing can make such a massive difference in overall presentation.
How's the weight distribution left to right?
Curious a to whether mounting the oil tank on the passengers side would help offset the driver in the front right at all? (Compared to where it is now) or if it's not enough weight to worry.
What do you think the whole thing will tip the scales at?
#1394 Racehatch
Racehatch
  • 1,027 posts
Posted 22 March 2016 - 11:02 AM
  No worries, good to hear you are using Earls - You will be able to use your Motec dash to log your oil pressure anyway I guess so if there are any issues you will pick it up when you start testing the car. I totally respect you building your own tank, just make sure you get the angle of the inlets/outlets right so it swirls properly, I assume you have already had a look at a Peterson tank or similar for design ideas? Even if it doesn't work right you can buy nice ex NASCAR ones of eBay for pretty cheap anyway.
Yeah mines going well, I'll update my thread shortly rather than hijack yours!
#1395 _LS1 Hatch_
_LS1 Hatch_
Posted 22 March 2016 - 11:21 AM
As said, the line work and wiring look great !
I am another person who looks to details like that too. :D
(On the steam pipe topic... I ran mine into the water pump housing, keeps the lines compact and no issues for me with how it works.)
Oh, and just out of curiosity, did you ever consider some hardlines for the oil or flex all the way made more sense ?
#1396 ozyozyozy
ozyozyozy
  • 950 posts
Posted 24 March 2016 - 07:55 PM
The motec is really cool for logging and monitoring, you can program alarms for what ever pressure and what ever point you would like.
We have a different warning for oil pressure at idle and when been reved.
Love there stuff, the good part about it, is you dont need to look at the dash when racing coz with programming, you will only look at it if there IS something wrong.
#1397 Heath
  • 18,393 posts
Posted 25 March 2016 - 08:13 AM
Love your work mate!!!
#1398 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 25 March 2016 - 10:12 AM
For anyone else contemplating such an immense project in the wiring and hose department. consider going to an electrical wholesaler and getting a roll of double sided velcro tape.
When re arranging things it save the use of a lot of cable ties, putting them on then cutting them off all the time.
Finish off with cable ties by all means.
Then do yourself a favour when cutting the tails off the cable ties.
Use a Stanley knife and cut them flush.
Saves getting opened up by sharp ends in mysterious places.
#1399 eyepeeler
eyepeeler
  • 1,959 posts
Posted 25 March 2016 - 05:11 PM
Funny you mention tank design and getting the inlet and outlet in the right spot. My mate has a Peterson tank and I did have a look at it. In the end I just barrelled into it and made it the best way I could. Your right though, if it doesn't work I grab a 2nd hand EBay NASCAR tank.
 Hey Jeff, I did look at hard lines for about 10 seconds or so. That job would have been much harder to do on my own. Running the Earls ProFlex hose is easy.
Running steam pipes now in -4 and -6.
The Motec gear is very cool. I was so excited to power it up and get things working.
Cheers Heath, appreciate it mate.
A few days late with that tip Rob, LOL. Great idea though, save a lot wasted and cut cable ties to clean up.
I haven't cut or scratched my hands yet on the cut tie ends,
#1400 eyepeeler
eyepeeler
  • 1,959 posts
Posted 25 March 2016 - 05:33 PM
Now that the wiring os all but done, it was time to power it up. Not the engine but the electrical system.
I know, I know, I cant wait for the engine start up either!!!
Flicked the switch and the Motec and on it came.
The Motec bloke went at it and started setting up the functions.
This screen is just a demo screen.
Attached File  01.JPG   113.82K   3 downloads
Attached File  02.JPG   118.24K   0 downloads
We have set up the following so far on the Keypad:
  • Fuel pumps 1 & 2
  • Ignition
  • Start
  • Warm Up, Practice & Race Screens and the sub screen within that
  • Thermo Fan
  • Indicators
  • Headlights
  • Fuel Re-set
  • Master Re-set
  • Windscreen wipers
Fuel pressure sensor, Brake sensor front & rear, Lambda L & R, Throttle position, Crank Angle, Water Temp, Oil Temp, have all been checked. Probably forgotten something as well, LOL.
Headlights on was exciting, don't they look tough from the front with the lights on.
Attached File  03.JPG   176.08K   1 downloads
Motec have the option to have an image come up when the system is turned on,
This looks very cool.
Attached File  04.JPG   120.04K   1 downloads
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
