17th works for me
IPRA 4 Door LX
#1551
Posted 27 August 2016 - 12:36 PM
#1552
Posted 27 August 2016 - 08:53 PM
#1553
_LS1 Taxi_
Posted 27 August 2016 - 09:05 PM
#1554
_LS2 Hatch_
Posted 27 August 2016 - 10:12 PM
I save me going back through the thread, what's the basic rundown in the ls engine?
By memory a reco engine from SRE with dry sump setup. Don't think specs were ever noted
#1555
Posted 27 August 2016 - 10:35 PM
Yep, I bought the engine from SRE, Searle Racing Equipment.
He is no longer in that business as it was. It was bought as a brand new motor, L98 that he sold as a 550 HP at the flywheel engine.
It has a cam in it, can't remember what it is, I bought it over 5 years back lol.
It has an ARE dry sump and oil pump set up.
The only changes I have made are the Holley fuel rails and throttle body.
#1557
_LS1 Taxi_
Posted 03 September 2016 - 04:46 PM
Motor sure sounds ballsie!
My guess for that rubbing noise.....disc touching a backing plate?
#1559
Posted 03 September 2016 - 04:55 PM
Haha, awesome.
Yeah, agreed with you. The retainer thing I put in is making the noise.
#1560
Posted 03 September 2016 - 06:14 PM
Very restrained...
TITS OR RUBBER... ONE OR T'OTHER (sorry, Summernats flashback)
#1561
Posted 03 September 2016 - 06:41 PM
Very restrained...
LOL
#1562
Posted 03 September 2016 - 07:47 PM
#1563
Posted 03 September 2016 - 07:52 PM
#1564
Posted 03 September 2016 - 09:53 PM
As far as im aware, all ryco's have anti drain back, haven't seen 1 that didn't so far. The repco version doesn't. As for a air filter you could contact Cam @ psico he's on Facebook, which i don't do, but he was telling me a month ago that he's getting a new type of filter similar to k&n style made, but his are tested for filtration no just at maximum revs, i wont mention to much, but they sound like a good thing. There being done specifically for all these hipo diesel things that are now putting out ridiculous hp & torque, but he does do some ls stuff. & for the intake pipe, I'd be checking whether 1 of the thermo pastic type materials, would get less heat soak than alloy ect, as that can be a problem with the otr in commodore ect. As for oil in your ls, i personally wouldn't use any thing else appart from liquimoly 5-40 top tech I've tried others & it's years ahead & about the same price, didn't notice if you have an oil cooler fitted as you'll be doing some hard track work obviously. You must have about 2k in braid & fittings & i must say the job you are doing is brilliant. Could i trouble you to pust up your steam vent system, as i have to go down this road shortly, have just about everything for the job. I think i need to read your thread. But it will be a absolute fun weapon when you get it going mate well done, Gary.
Thanks Gary, appreciate that input. I took the Ryco filter off after the session on the dyno and replaced it with a K&N filter. Will give you the part number later if you like.
I started to look at a air box to make for cold air into the motor. I will put a few pictures up later of what I'm up to. I haven't look to hard into what intake pipe to use but I guess that the blue plastic/silicone style will be ok.
The oil I am using is a Penrite product, 15W-50 Racing 15.
Is there a reason you suggest using Liquimoly? Do you think it will be a better product?
Yeah, an oil cooler is certainly on the cards before too long. I have been told a 24 row 13 inch cooler should do.
The amount of coin in hose and fittings is quite a bit, that's for sure!! That stuff is not cheap, but it certainly does e job.
I used an aftermarket adaptor with a -4 flare male fitting to screw to the 4 seam ports on the block. I used a -4 to -6 flare reducer to -6 hose and I connected it all up with a series of tee's leading back to the radiator. I can take a few pictures for you.
Cheers Marcus, it was so cool to steer the thing even though I didn't get out of first gear, lol.Now that, is exciting. Awesome stuff!
#1565
Posted 03 September 2016 - 11:12 PM
#1566
Posted 04 September 2016 - 03:31 AM
#1567
Posted 04 September 2016 - 03:49 AM
#1568
Posted 04 September 2016 - 04:24 AM
You must not have scrolled back through the thread far enough Gary, this beast is dry sumped. It's running an ARE sump and pump with three scavenge stages and a Peterson oil tank in the boot.
Which brings oil aeration into the picture too, I've read certain oils/additives are better than others in this situation?
I finished off the oil lines and spun the oil pump up with a drill to get oil through the lines and motor.
I am using Penrite running in oil and it took 17 litres!!!!
3 1/2 of these
#1569
Posted 04 September 2016 - 04:41 AM
Which reminds me, Craig have you seen these new Spintric oil/air separators that ARE have now?
http://www.spintric.com/Spintric.htm
#1570
Posted 04 September 2016 - 12:42 PM
#1571
Posted 04 September 2016 - 12:55 PM
#1572
Posted 04 September 2016 - 01:07 PM
#1573
Posted 04 September 2016 - 01:18 PM
#1574
Posted 04 September 2016 - 01:37 PM
If you're worried that you still have air in the cooling system then maybe get yourself one of those vacuum refill kits that draw all the air from the system and vacuum test it for leaks before sucking the coolant in, that way there can't be any air trapped anywhere.
Uview Airlift is one brand, but they're also made by Snapon, Matco and a few other manufacturers.
http://www.uview.com...&productid=5120
#1575
_LS1 Taxi_
Posted 04 September 2016 - 01:53 PM
