IPRA 4 Door LX
#1576
Posted 04 September 2016 - 02:04 PM
#1577
_LS2 Hatch_
Posted 04 September 2016 - 07:37 PM
Running them cooler would be against alli have read and been informed.
#1578
Posted 04 September 2016 - 08:59 PM
#1579
Posted 04 September 2016 - 11:36 PM
Some v8 supercar motors were using a straight 40w and pre heated before started.
Only time nascar run lighter than 15 is qualifying, it gets swapped out for heavier oil for the race.
There are optimal temps for oils too.
Too cold can be just as bad as too hot.
#1580
Posted 05 September 2016 - 12:50 AM
#1581
_LS2 Hatch_
Posted 05 September 2016 - 07:36 AM
Thanks for sharing your knowledge
#1582
Posted 05 September 2016 - 01:00 PM
#1583
_LS1 Hatch_
Posted 05 September 2016 - 02:05 PM
I run a 186 degree in mine, which is the OE temp for the Camaro, Corvette etc from memory. No issues at all..
By the way, great to see the video too !
#1584
Posted 05 September 2016 - 02:09 PM
#1585
_LS1 Hatch_
Posted 05 September 2016 - 02:12 PM
#1586
Posted 05 September 2016 - 02:18 PM
My water boils at 373 but I'm with Kelvin on that one
So that's almost 86 in C which agrees with what Gary said is standard for LS engines.
#1587
Posted 05 September 2016 - 02:26 PM
#1588
Posted 07 September 2016 - 06:06 PM
GrumpyXU1
#1589
Posted 07 September 2016 - 06:21 PM
Earls do some nice LS steam port adapters in -3AN & -4AN with either single or dual outlets for US$40 a pair, which would save you a couple of T-pieces and a few fittings...
They also have more of a racing application kit complete with braided stainless lines that's US$200...
See here: https://www.holley.c...ine_components/
#1590
Posted 08 September 2016 - 08:50 PM
#1591
Posted 08 September 2016 - 09:38 PM
This is just my understanding but I don't think it matters that much, these vent lines should always have some coolant flow in parallel with the top radiator hose anyway, so as long as any air/steam enters the vent ports it should be expelled into the radiator whether the line runs uphill all the way or not?
The only strange thing is that with a crossflow radiator in this configuration, any air would need to travel across the radiator core before it can be expelled by the cap, so I would expect that there would always be a tiny amount of air trapped in the hot side of the radiator above the level of the top row of fins, but there isn't much you can do about that unless you evacuate the air from the system prior to filling?
Bits and shits.
Got radiator hose and oil filter sorted.
Also got the stepper sensor in on the throttle body.
Pretty boring items, but another step closer.
#1592
_LS2 Hatch_
Posted 09 September 2016 - 06:59 AM
I know they turn on at 99 and off at 91 or 92.
That may be my mix up.
Oh well, I know mine works ok and never had issue so for now I won't be removing anytime soon.
Sorry for the partial hyjack Craig.
Car coming along fantastic, I wish I could view the videos but I can't for some reason.
Have you had a chance to re dyno and drive it yet?
#1593
Posted 09 September 2016 - 08:43 AM
Maybe I'm getting mixed up between my thermostat and when my fans turn on and off.
Not yet Grant, he has been really busy the last 2 weeks and I really haven't had much of a chance myself.
I really didn't think the thermostat would have been a issue, but it seems to be.
I ran the car yesterday in neutral to get engine temps up and at 95 degree on the display the top hose was really hot and the bottom hose cold.
I was wondering if there would be heat soak from the housing keeping it closed. The housing is pretty cold compared to water temp.
#1594
Posted 09 September 2016 - 11:52 AM
I can't see in any of your photos Craig, but are you using a bypass hose between the two heater pipes or do you have them blocked off?
If you just block them there will be no coolant flow whatsoever until the thermostat opens, that means the thermostat would need to wait for heat to be conducted along the static coolant, which means it will be significantly delayed in opening. (By which time the coolant in the cylinder heads is already boiling) You need some coolant flow (normally through the heater circuit) to activate the thermostat.
Apparently Dayco make a bypass hose that will do the job, part #87629
Dayco 87629.jpg 27.03K
3 downloads
#1595
Posted 09 September 2016 - 12:24 PM
I had the same problem Grant so I hope Craig doesn't mind but I've ported them across to Youtube, I set them to "Unlisted" so you need the URL to view them and they shouldn't show up in general population (any problems just let me know and I'll remove them)...
(you'll have to crank up the volume on this one, sorry but that's how the original was)
Edited by Bigfella237, 09 September 2016 - 12:25 PM.
#1596
Posted 09 September 2016 - 12:28 PM
And one more...
Edited by Bigfella237, 09 September 2016 - 12:28 PM.
#1597
Posted 09 September 2016 - 01:53 PM
No problem with me having it on youtube Andrew, was considering doing that later on as some were having drama's getting access to it.
I was told that blocking them off is the best option, I got told that by a couple other people who had done that to their engines.
I might grab one of those bypass tubes and see what difference it makes.
Thanks for that one mate, appreciate it.
#1598
_LS2 Hatch_
Posted 09 September 2016 - 03:59 PM
The hose will make a big difference.
I agree that you shouldn't block them, and should use a return hose to keep the flow. Well at least thats what i was told and had done.Now I have a heater connected
#1599
Posted 09 September 2016 - 07:39 PM
#1600
Posted 09 September 2016 - 08:08 PM
