IPRA 4 Door LX
1672 replies to this topic
#201 eyepeeler
eyepeeler
  • 1,959 posts
Posted 25 July 2013 - 03:23 AM
Thanks for the input Vick. If I had a rim to put a tyre on that would help LOL. I ended up going with a diff width of 1495 after talking to the diff bloke.
Mount the tyre to the rim and measure the tyre sidewall to sidewall. You may wish to throw that into the equation.
As I want to get the roll cage done (rules changed as posted before) I have mounted the Sub-Frame to get and idea of how it will work in with the roll cage. I tried out the alloy bushes I had made up, happy with the result. Fitting the Sub-Frame is a prick of a job!! Any way I got it done and now I can start working on the cage.
Attached File  01.JPG   107.24K   13 downloads
Attached File  02.JPG   102.37K   10 downloads
Attached File  03.JPG   92.63K   11 downloads
#202 ls2lxhatch
  • 5,335 posts
Posted 25 July 2013 - 11:32 AM
Most k-frames have twisted a bit over the years probably due to braking. If you measure the distance between the front and rear bolts at the top of the k-frame then you will probably find the rears are closer together and the fronts are wider apart than the distance between the rails.
I jacked my k-frame back into spec and it only takes a couple of minutes to fit. You will find a few more tips on making it easier to fit the k-frame on this webpage.
http://ls2lxhatch.co...gineinstall.htm
#203 _LXSS350_
_LXSS350_
Posted 25 July 2013 - 11:42 PM
For all the size and bulk of the torrie Kframe it is very very weak. This is even more prevelant under race stress. The Kframe is basically trying to hold the front end together, but the chassis (a little folded tin plate) has the strength of a tin can of spaghetti. This is why the group c race cars plated the bottom of the Kframe with 3mm plate between the bottom arm mounts.
To gain some rigidity without changing the factory design I have in the past made 4x full profile chassis plates (3mm) that go from radiator support panel to past the gearbox mount and fully welded them in.
These photo's are similar (abit shorter) to what I used to do to help get the car to stop flexing.under hard driving. This along with plating the bottom of the Kframe helps a lot with the flex issues along with a well designed cage.
Edited by LXSS350, 25 July 2013 - 11:47 PM.
#204 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 July 2013 - 01:08 AM
That's a nice bit of work Col to do that. It would certainly help the cause, unfortunately I can do that within IP rules,
This is the ruling cut and pasted from 3J Specifications:
3.1 Strengthening: It is permitted to seam weld the bodyshell. Metal to a thickness of up to 5mm may be added to
fully sprung components to a distance of 75mm from the edge of each suspension pivot point aperture. Such
metal must follow the contour of the original metal at all times. It is not permitted to add or incorporate any
other components which contribute to the rigidity of the bodyshell, other than the safety cage structure as
described in Article 14.1, and a strut tower brace as described in article 9.7.
What I am working on is a bar from the sub-frame mount closest to the firewall to the junction of the lateral half roll bar and steering mount bar. It pretty much the same as what Clarke Hopkins did in his NZ CMC Torana except he had bars going to all four sub-frame bolts.
Andy, I will be checking the measurements when I take it out. What should it be???
#205 _LXSS350_
_LXSS350_
Posted 26 July 2013 - 01:45 AM
Rules - CAMS the spoil sports - LOL
http://www.gmh-toran...850-uc-k-frame/
Edited by LXSS350, 26 July 2013 - 01:52 AM.
#206 ls2lxhatch
  • 5,335 posts
Posted 26 July 2013 - 02:23 AM
There is a thread where several people have posted the measurements from bolt to bolt on the towers.
My crossmember rebuild
794 mm front and 792 mm rear centre to centre was the result for three k-frames and one 790 mm front and 789 mm rear.
I measured the distance between the holes in my chassis at 31.25" (794 mm). I believe the Torana was designed using imperial measurements.
My theory is that the k-frames started out as 31.25" (794 mm) between the bolts. The braking force has caused the k-frame to twist in the rubbers and move rear bolts to be closer together than the front bolts. I can not think of any other explanation as to why there is a difference between the front and rear bolt spacing.
I stretched the k-frame that was giving me trouble back to 31.25". With the amount of practice I have had installing and removing the k-frame on my hatch I can bolt the k-frame to the body in a couple of minutes.
I would measure the distance between holes the rails on you car first.
Edited by ls2lxhatch, 26 July 2013 - 02:24 AM.
#207 76lxhatch
  • 7,222 posts
Posted 26 July 2013 - 07:21 AM
I don't understand which part of that excludes the above plating idea? As long as its no more than 5mm thick and you keep it 75mm from the control arm pivot (mount), which may be touch and go at the top but doable, it should be OK?
"Metal (...) may be added to fully sprung components (...) not permitted to add or incorporate any other components"
Am I reading it wrong?
#208 Peter UC
Peter UC
  • 771 posts
Posted 26 July 2013 - 05:46 PM
But can only be added around a suspention pivot point. ie around where the wishbone is mounted on the cross member. However I thought they changed the rules so the cage can extend out the passenger compartment like the late model cars can?
#209 eyepeeler
eyepeeler
  • 1,959 posts
Posted 26 July 2013 - 08:36 PM
I'm certainly no expert on rules but the way this one reads is as follows, I can add the stated material up to 75mm from the suspension pivot point. This is the upper and lower arms not the chassis rail and where the sub-frame bolts to it. It's not permitted to strengthen the body shell in any other way. Except with the roll cage, which is the direction I am heading in as I posted earlier.
Hi Peter, yes they have changed the rules to allow the cage outside the passenger compartment. LXSS350 put up a photo of Clarke Hopkins engine bay, What I am going to do is based on this. I will be running 2 bars, not 4 as he has done though.
#210 76lxhatch
  • 7,222 posts
Posted 26 July 2013 - 11:46 PM
I could be wrong but it is my understanding that control arms are not "fully sprung", since they are attached to the unsprung components (stub axle etc). If that's true then they can't be talking about plating control arms, the body and chassis would be fully sprung.
I do see what you mean though and I guess its possible that the intention of the rules is to allow plating of control arms, even if that's not technically what it says...?
#211 eyepeeler
eyepeeler
  • 1,959 posts
Posted 27 July 2013 - 12:52 AM
 Unsprung components include rims, tyres, stub axels, brake calipers and rotors, wheel bearing, hubs, springs, shocks and the suspension links which are in this case the upper and lower control arms.
http://en.wikipedia....i/Unsprung_mass
As the rule is 75mm from pivot point on fully sprung components, this means that the sub-frame can be plated. It also means the area around the diff trailing arm mounts on the chassis can be plated.
At least that's the way I read it. Gotta love rules...... the debates are endless and lost in interpretation sometimes!! Good stuff.
#212 76lxhatch
  • 7,222 posts
Posted 27 July 2013 - 07:41 AM
Exactly, the way I read it that rule is intended to say you can strengthen existing structure a bit but you can't add additional bracing (e.g. chassis connectors etc) other than a roll cage. It would be really nice if you could plate the subframe and on the face of it that seems possible.
The only thing I'd be a little wary of is that it says "pivot point aperture" rather than just pivot point; the upper control arm pivot doesn't have a clearly defined opening like the bottom one so it could be a little open to interpretation as to how close you can get, and you want to get as close as possible.
#213 _LXSS350_
_LXSS350_
Posted 27 July 2013 - 10:17 AM
9.14 Wheel alignment facilities: The wheel alignment settings are free. It is permitted to relocate the front control arm pivot point radially by up to 45mm within the confines of the existing crossmember or body panels. No metal may be removed save that directly associated with the actual pivot point relocation. For vehicles with a live rear axle, where camber or toe vary by more than 1/2 ° from standard, the toe and camber figures are to be recorded in the vehicle logbook, and such settings shall be used exclusively in all competition. These specifications, once recorded, may only be varied upon approval by CAMS Manager - Technical Services. Rear wheel alignment on independent suspensions may be achieved by relocating suspension pivot points by no more than 20mm within the existing brackets.
9.5 Front suspension components: Steering tie rods may be replaced provided they are derived from an eligible vehicle. Stub axles, steering arms, hubs, bearings and tie rod ends are free. MacPherson strut tubes are free. In cases where the steering arms are separate components, it is permitted to fit spacers between the steering arm and stub axle assembly using extended bolts.
3.6 Front spoilers/air dams: It is permitted to fit an airdam to the front of the car, subject to the following restrictions (see diagram 1).
(i) it is to completely contained within the vertical projection of the original car, including permitted flares
(ii) no part below a horizontal plane passing through the centre of the wheel hubs at their extremities may extend further rearward than the wheelarch opening at the forward point where it intersects this plane
(iii) no part above a horizontal plane passing through the centre of the wheel hubs shall extend into the wheelarch opening
(iv) any undertray fitted to the airdam and located further than 50mm from the extremity of the airdam shall be flat, and parallel to the vehicle sills and shall be regarded as part of the front airdam.
Since you have the torque arm and watts under control, these above areas imho are the areas to concentrate on and where I think you can gain big time improvements if you think outside the regular torana box (but within the IP rules).
#214 eyepeeler
eyepeeler
  • 1,959 posts
Posted 01 August 2013 - 12:35 AM
Just started to fabricate the front bars to the sub-frame bolts. Just the initial set up at the moment, will trim and tidy up and get it ready.
Give you an indication of what I want to do anyway.
Attached File  01.JPG   153.92K   8 downloads
Attached File  02.JPG   160.79K   9 downloads
#215 eyepeeler
eyepeeler
  • 1,959 posts
Posted 01 August 2013 - 01:55 AM
Both sides mocked up. I will also be putting a bar in from the cage mount up to this bar just behind the firewall.
Attached File  03.JPG   150.47K   8 downloads
Attached File  04.JPG   148.22K   7 downloads
If you're wondering what tool I have been using to notch the tube, this is it. Made by JD2, it is an awesome bit of kit.
Attached File  05.JPG   151.78K   10 downloads
Attached File  06.JPG   197.01K   10 downloads
#216 _LS1 Hatch_
_LS1 Hatch_
Posted 01 August 2013 - 02:09 AM
Pretty awesome looking...
#217 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 01 August 2013 - 06:05 AM
Where do I get one.
#218 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 01 August 2013 - 07:49 AM
Where do I get one.
http://jd2.com.au/no...otchmaster.html
#219 _LS1 Hatch_
_LS1 Hatch_
Posted 01 August 2013 - 07:52 AM
Or way cheaper over here..
https://www.jd2.com/...otchmaster.aspx
#220 _mumbo_
_mumbo_
Posted 01 August 2013 - 09:07 AM
Is there a reason you dont go to the front K-frame mount ??
#221 ls2lxhatch
  • 5,335 posts
Posted 01 August 2013 - 11:45 AM
I suspect the rear k-frame mount would be under more load than the front k-frame mount under braking. Most of the k-frames I have measured appear to have twisted in at the rear. (rear bolts are closer together than the front)
Edited by ls2lxhatch, 01 August 2013 - 11:46 AM.
#222 eyepeeler
eyepeeler
  • 1,959 posts
Posted 01 August 2013 - 11:14 PM
The reason is a simple one, the bar wouldn't clear the wheel tub if I went to the front mount and I couldn't get the angle right. I will take the advantage that Andy has said about it being the better spot though!!!!
I have got all the trimming done and ready to weld it all up. Pretty happy with the way it looks.
Attached File  07.JPG   142.03K   6 downloads
Attached File  08.JPG   177.61K   9 downloads
Attached File  09.JPG   176.56K   6 downloads
Attached File  10.JPG   167.04K   6 downloads
#223 dattoman
Posted 02 August 2013 - 12:33 AM
Are you not allowed to run a flat plate on that area and brace the whole bit... sort of like Welbys but abit more plate ?
#224 eyepeeler
eyepeeler
  • 1,959 posts
Posted 02 August 2013 - 01:29 AM
Hi Neil, I was hoping you would look at what I was up to. I was going to get in touch with you about rear end Superpro bushes and a bush for what I am doing here. As you saw, I had the alloy bushes made up to go between the sub-frame and the chassis rail, and this set up that I have just fully welded in has the tube go down to the mount hole. What I want to ask you is can you get a nolethane bush made up to fit the ID of the tube which when the subframe is in, will squeeze and tighten up against the alloy bush underneath.
Attached File  11.JPG   168.32K   7 downloads
The reason I went this way instead of the way Welby did it, was this way I had bars going directly to the point and was part of the assembly that the sub-frame bolted to. I did look at the we he did it and I like the Hopkins Torana idea, so I went that way.
#225 _LXSS350_
_LXSS350_
Posted 02 August 2013 - 01:52 AM
Your bracing looks good and should be effective in helping to strengthen up the flex of the chassis. Your diagonal brace running by the kick panel and angle from the main cage looks very good and should help lock it all in.
