Monza owners
593 replies to this topic
#101 _judgelj_
_judgelj_
Posted 02 November 2012 - 08:51 AM
So would that plate have been there for that reason?
#102 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 02 November 2012 - 07:21 PM
not 100% sure if the early commodores have that plate too judgelj. Plan is to get the pwr steer rack & new lengthened 1 piece shaft in. & if no dramas there il stick a running 308 in to test to see if the bellhousing & clutch happy with there new home
#103 rodomo
  • 18,038 posts
Posted 02 November 2012 - 09:17 PM
VB Commodore
#104 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 03 November 2012 - 11:53 AM
thanks for the pic rodomo, what are ya plans for the vb? Heres a pic showing the air vent for the rear passengers to keep their strodels warm. This car will have A/C eventually, i like the compressor setup of vn/vs v8s as they are mounted low & should be opposite side of motor away from turbo
#105 rodomo
  • 18,038 posts
Posted 03 November 2012 - 09:23 PM
http://www.gmh-toran...winton-or-bust/ :3gears:
#106 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 05 November 2012 - 07:39 PM
picked up the new 3inch 1 piece tailshaft. Hurt the wallet but it fits.
#107 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 06 November 2012 - 10:21 AM
thank god the tailshaft has bolt on flanges. I had to remove the input shaft off the tailshaft (4 bolts) insert it into the back of the gearbox, then slide the tailshaft into the rear suspension tunnel/craddle thingy, then bolt back up
#108 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 06 November 2012 - 10:28 AM
Pwr steering rack out of a vh sle finally here. Had it rebuilt 2/3 years ago by pedders
#109 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 12 November 2012 - 12:56 AM
There was only a handful of Directors fitted with IRS, & this was the Opel unit as per the Monza. This is different to the later IRS in the Australian Commodores/Statesmans. I've never needed new bushes, so can't help on that one. Sorry.
hey monza1 heres a link to monza forum "TURNBRIGDE WELLS OPEL MONZA APPRECIATION SOCIETY" lol takes ya breath away abit, found the link searching through a commodore forum: http://www.twomas.co...&t=339&start=15
#110 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 15 December 2012 - 02:08 PM
ok so ive pulled me finger out recently & removed the steering column out of the monza. Once the steering box is removed there is only 3 nuts that hold it in place (remove the 2 half way down either side of column 1st, which gives u more room to the last 1 near the firewall you need 15mm socket with a legal size bara worth of extensions bars 2 get it) all the wire terminal clips disconected easy & no need 2 remove steering wheel, indicator stalk or ignition barrell
#111 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 15 December 2012 - 02:25 PM
the monza steering coupling thingy at the end of the column is rectangualish on shaft side & round spline on the box side. Early commodores have round spline intermediate shafts, none that i have found fit (hole isnt big enough). So i removed it. If i lived closer to a city i would of tried searchin for a splined yoke that might fit, but i threw it away as far as could hopefully the dog doesnt bring it back
#112 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 15 December 2012 - 02:35 PM
left is a vl comy intermediate shaft (from what ive heard vb to vn are all round spline at the column) . On the right is a vp/q intermediate shaft. With the monza coupling in the centre
#113 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 15 December 2012 - 02:44 PM
the column end of the vp/q intermediate shaft slides on to the monza column shaft perfectly.
#114 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 15 December 2012 - 03:04 PM
but the vp/q shaft wont mate up to a vb /vn pwr steer rack cause its to long . Il have to modify 2 shafts by removing the column end of the vp/q & put it on to a vk pwr steer shaft (pictured). i think this mod is reversed when they put later model (vp/vs) engine/kframe conversion into early comys?
#115 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 09 January 2013 - 09:21 AM
the vk pwr intermediate shaft was modified by putin a VP colum end onto it so i bolted it to the monza column & put the column back in, then looked in the engine bay & its about 3-4 inch's short haha.. should of measured 1st . thought VK shafts were the same length as VH
#116 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 13 January 2013 - 09:25 AM
a VC SL/E steering column showed up the other day
#117 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 13 January 2013 - 09:39 AM
i bolted it in & its about an inch & half to short .... The saga continues! Any one got a vh pwr steer intermediate shaft loitering around the shed theyd like to sell?
#118 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 11 March 2013 - 02:40 PM
shaft is in. Vk shaft with vp/q wheel end, with the rack end lengthened 75mm.
#119 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 11 March 2013 - 05:11 PM
ugly as it is at the moment, all that we did was remove brake thingy bolts that hold it to the passenger strut then bend the lines a little to clear the 308
#120 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 11 March 2013 - 05:25 PM
heres the next challenge.. The pedal end of monza clutch cable is diferent to commodore. I dont really want to put a commodore pedal assembly in (as i dont have one)
maybe i can get the monza end put on the commodore cable?
#121 _L32M20_
_L32M20_
Posted 13 March 2013 - 08:02 PM
fuel pump is on the way up homer j
#122 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 13 March 2013 - 09:01 PM
sweet!
#123 _Kevhaze_
_Kevhaze_
Posted 16 March 2013 - 03:16 PM
The styling and shape of the Monza reminds me of the Rover SD1. I will prob cop it for having a Rover I seem to from every one else lol.
#124 _L32M20_
_L32M20_
Posted 18 March 2013 - 07:36 PM
sd1 make good looking race cars.but i liked the camel filters rover sedan....tuff! they should have made a two door sd coupe.maybe another job for tim?
Edited by L32M20, 18 March 2013 - 07:38 PM.
#125 _Kevhaze_
_Kevhaze_
Posted 28 March 2013 - 03:25 PM
Yeah They are a sporty looking car. This is my one it doesn't have the front spoiler, back bumper or rear spoiler on it at that time. It would be interesting to see a 2dr version as they already have the lines for a coupe.
But Yeah similar in looks to the Monza Shape that is
