gtr 10/72 brisbane car- need info please
#51
_LONA-CK_
Posted 21 January 2013 - 08:50 PM
cheers gong
#52
_Agent 34_
Posted 16 April 2013 - 07:43 PM
guys - putting the quarter windows together and i cannot remember if the fiber washer goes on the inside or the outside of the window ?
I cannot see on any other windows i have
#53
Posted 16 April 2013 - 08:03 PM
Grant
The front 1/4 window metal fittings are glued to the glass and the fibre washer goes on the inside.
#54
_Agent 34_
Posted 16 April 2013 - 08:27 PM
you sure on that Dave.
do you mean silicon
not that i doubt you on this but do you have a photo ?
correction on this above - yes i am doubting you Dave. , but i cannot see on one of my old ones any washers at all
DOH !
and no photo
Edited by Agent 34, 16 April 2013 - 08:28 PM.
#55
Posted 16 April 2013 - 09:20 PM
Yes Grant I am 100% sure of what I said. The chrome fittings are glued to the outside of the 1/4 window glass and the fibre washers go under the two pivot fitting screw heads and the latch bolt retaining nut on the interior side of the glass.
What glue they used I do not know.
I have a pivot fitting here from my original 1/4 windows and it still has remnants of the glue on it. Will see if I can get a close up shot of it when my camera battery has recharged.
#56
Posted 16 April 2013 - 11:40 PM
Remnants of the adhesive on the top pivot fitting. As you can see the adhesive has yellowed with age.
#57
_Agent 34_
Posted 17 April 2013 - 07:12 AM
Dave,
thanks for that, I did have the parts this way but changed them and now will have to re do them, it's like a PVA glue but PVA will go clear and then white with moisture.
I may try to get a thin clear plastic and cut to size and then put on.
DOH - go with first attempt and continue
Ahhh nothing like doing a job twice
#58
_grumpy 026_
Posted 17 April 2013 - 08:01 AM
I used Arildite, a two pack glue, It also ages as per photo above.
G.
#59
Posted 17 April 2013 - 08:15 AM
There is a new product on the market that I think would be ideal for the job. It's a super strong sealant/adhesive called T-REX. It comes in three colours, grey, white and clear, and the clear is so clear that between 2 pieces of glass you wouldn't know there is adhesive in there. It comes in a 300gm cartridge and costs around $15 from Reece plumbing supplies.
#60
_Agent 34_
Posted 17 April 2013 - 07:27 PM
guys,
got some of this from clark rubber today, I'm going to give it a go and see what happens, it's really a rubber petrochemical products that will act like a rubber.
otherwise will give the t rex a go
_Agent 34_
Posted 22 April 2013 - 07:45 PM
Ok - wheel nuts , rares has two different types
Acorn and other ones
which are correct for the 10/72 B car.
thanks G
photo if possible
Edited by Agent 34, 22 April 2013 - 07:46 PM.
#62
_LONA-CK_
Posted 23 April 2013 - 07:44 AM
acorn are for lc mate.
cheers gong
#63
_big jack_
Posted 24 April 2013 - 10:45 PM
cheers gong
^ And early LJ.
#64
_LONA-CK_
Posted 25 April 2013 - 07:17 AM
no ^^^^
cheers gong
#65
Posted 25 April 2013 - 09:17 AM
Grant, I can't find the 'other ones' on the Rares site, only the Acorn type that they have listed as being for LJ.
The LJ nuts should have a recessed black dot in the outer end of the chrome nut.
#67
Posted 25 April 2013 - 02:11 PM
Brad
From memory yeah they looked similar to yours. You have an LH parts catalogue don't you? What is the part no. for those wheel nuts?
#68
Posted 25 April 2013 - 02:22 PM
P/N: 2825904
#69
_Agent 34_
Posted 25 April 2013 - 04:37 PM
Brad,
are they rares ones ?
Where did you get thoes ones from.
the guy on ebay that sells the Xu1 re- made ones does not do the LJ ones.
#70
Posted 25 April 2013 - 04:42 PM
#71
_Agent 34_
Posted 25 April 2013 - 04:49 PM
funny you say that as i heard this week this is correct off another person and went onto ebay usa , to see if i can find the wheel nuts but with no luck.
you have now confirmed what i learnt this week
if you can PM me the details or company or post here and i'll chase them down.
#72
Posted 25 April 2013 - 05:16 PM
#73
Posted 25 April 2013 - 06:19 PM
Thanks Brad
As I suspected, wheel nut P/N: 2825904 is also for LJ.
Dave
#74
Posted 25 April 2013 - 06:29 PM
Well the ones that I bought were from Year One. Maybe a bit less then $150 prob closer to $100 include freight.
Hopefully this helps you out Grant!!!!!
https://www.yearone....firebird/123ras
#75
_Agent 34_
Posted 25 April 2013 - 07:51 PM
sorted guys - frash da bucket (john K) found some
thanks Brad for your help
http://www.ebay.com/...57186534&_rdc=1
