Fibreglass
_Torana Affair_
Posted 25 May 2011 - 09:46 PM
ive been looking at what to do for new intrument cluster/dash for LX, and seeing marshalllx build , i am going to give at making one myself too.
And in all honesty ive never done any fibreglassing b4 , so apart from you tube , id thought id give all a shout and get everyones secrets , hints and tips.......
so if you have do's and donts , chuck it down...............
Cheers in advance
Posted 25 May 2011 - 10:04 PM
easy
_Torana Affair_
Posted 25 May 2011 - 10:19 PM
Posted 25 May 2011 - 11:00 PM
_robslxhatch_
Posted 25 May 2011 - 11:16 PM
_Torana Affair_
Posted 26 May 2011 - 07:29 PM
oh wait............ robslxhatch just put that in............
just really basic steps im after, tips like dont play with it to much .....
coats needed..............
im going to have a crack anyways , but thought id ask first...
Posted 26 May 2011 - 10:26 PM
Mix small batches
2% catalyst... max... or it goes off too gast
Use 400 gram matting
Buy a few good brushes and a couple of fibreglass rollers (grooved)
Lots of acetone for cleanup
Watch some youtube
Where in WOz are you ?
_Torana Affair_
Posted 27 May 2011 - 10:01 AM
Use a general purpose polyester resin
Mix small batches
Watch some youtube
okay........ cheers ........ yep i have got a few ideas of the tube.....
im in the goldfields. outside kalgoorlie...............
Posted 27 May 2011 - 10:05 AM
Can't exactly pop round and drink your beer while I watch you get covered in goop now can I
I can take a pic or 2 of my rollers.. .and tell you where to get them
And the matting etc if you don't have a local shop
Then you can see what gear I prefer to use
_Torana Affair_
Posted 27 May 2011 - 09:36 PM
your gear selection would be handy..... cheers 4 that
_Quagmire_
Posted 28 May 2011 - 12:30 AM
Well thats no bloody good then is it
so when can i have a gander then?
Posted 28 May 2011 - 12:54 AM
_Quagmire_
Posted 28 May 2011 - 12:02 PM
Posted 28 May 2011 - 03:40 PM
Page 6 onwards is what your after, i personaly like bristle rollers but ring rollers are easyier to clean. Use them for the large areas then use a smaller roller like the economy bar roller 60/10 for the corners.
Posted 28 May 2011 - 05:20 PM
I prefer mine less hairy
But it all depends on what your actually making
These are my preferred rollers
Posted 28 May 2011 - 05:39 PM
Posted 28 May 2011 - 06:19 PM
Give it time
You've seen my shed
_Torana Affair_
Posted 28 May 2011 - 06:22 PM
they have just been using brushes and the sheets........... also parts they use bog aswell..........
whats the rollers for?
Posted 28 May 2011 - 07:02 PM
Yanks do things in silly ways... thats probably why
Posted 28 May 2011 - 08:11 PM
#21
_Torana Affair_
Posted 29 May 2011 - 12:23 PM
To get the smooth finish , no doubt you give it a sand ??? do you go back over with anything after sanding?
and when painting , whats the best primer to use.......... a primer /fill ............
#22
Posted 29 May 2011 - 02:17 PM
The glass layer is the underside... as in your doing it in a mold
If your doing it the other way... then yes... lots of bog and sanding
#23
_Spark Eater_
Posted 29 May 2011 - 04:16 PM
#24
_Torana Affair_
Posted 29 May 2011 - 07:05 PM
i was planning on cutting some extra sorrounds/donuts and then raise it all up to those points..............
Make sense ?????
#25
Posted 29 May 2011 - 08:11 PM
http://www.facebook....72982.765901893
Picks on my facebook there ^, not in order sadly so a bit harder to follow how i did it hehe.
