STARFIRE UC
23 replies to this topic
#1 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 04 June 2011 - 08:30 PM
I recently purchaced a 79 sunbird powered with the almighty starfire engine,has anyone ever wasted time/money on trying to get the starfire to go a bit
better than what they do.I read somewhere that you have to pull em back a gear to drive over a shadow and that they are noisy,rattly,gutless,oil leaking etc,etc
"IF" anyone was to try to get a bit more out of them what cam,exhaust/carb set up,so far as i know people rob the conrods out of em to fit to sixes and throw the rest in dump.any suggestions
#2 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 04 June 2011 - 10:47 PM
Sorry to say most people i know nick the rods out of them and dump the rest. its not hard to throw a red 6 at it.
#3 76lxhatch
  • 7,208 posts
Posted 05 June 2011 - 07:22 AM
Starfires are a great little engine and go fine for a four cylinder engine of the era (with a manual box at least). A set of twin carbs etc would probably wake it up a bit but its never going to be particularly quick and bang for buck there are better options for a car that can easily house a V8.
#4 yel327
  • 13,656 posts
Posted 05 June 2011 - 09:43 AM
I'd have to agree. I changed one once to a red 202. All that is needed is a complete red 202 inc radiator, exhaust to suit and tailshaft to suit. If it is an MC6 you'll have to make a shifter hole in the same spot as a 6cyl one, slide the crossmember back and fit a 6cyl MC6 tailshaft and patch the old shifter hole. We put in a 3.08:1 diff at the same time. From memory we bought a rusty 6cyl manual UC with good exhaust for $100 or something like that and swapped it all across.
#5 _Bomber Watson_
Posted 05 June 2011 - 11:12 AM
I recon a starfire would respond nicely to a small turbo...
#6 _stretchlc_
_stretchlc_
Posted 05 June 2011 - 11:46 AM
Blue/ Black Rods ARE Starfire Rods........Just go the 6
2 pots ripped off the back of the 6 cylinder just doesnt look/ sound or perform right to me!
#7 Heath
  • 18,393 posts
Posted 05 June 2011 - 12:49 PM
I have heard of them being hotted up a bit with some success. Give it two or four throttle-bodies, some cam timing and some normal port work and see what happens!
The only problem is that they are kinda small for a full-sized Torana, but that's only really because we're used to them being fitted with big motors haha. It's not uncommon for european or Japanese cars to weigh more than a UC Sunbird and have a motor that's that small or smaller.
#8 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 05 June 2011 - 05:26 PM
yeah the cars do have a bit of power to weight problem with less than 2L in em,have driven a lh with 202 that was fitted with webers,very responsive.
i was just thinkin that someone might have actually done some succesfull mods(but probably not admit it),sounds like they have a bad reputation.
had thought of a small turbo but the time to build an exhaust manifold to fit in there put me off a bit.I suggested to a mate of mine who builds
engines for a hoby on what could be done,this was his responce"you wanna do what to one of them you must be fkn mad,when they put starfires in toranas
they didnt bother putting a speedo or a clock in the dash,they put a calendar there instead".spose i will have to take a difrent route.Some bloke
left me with a little roots blower and was gonna toy with the idea of fitting it up,not sure of the size of blower but,he said it was an sc12 but its got
no identification marks or numbers on it,but it does fit above the fuel pump and clear the rail and other stuff.not sure of legalities of blown eng.either.
Got a lh with v8 in ,sure its nice easy power and you cant beat cubes for grunt,would like to try something difrent thats probly not everones cup of tea but i can cop the comments regardless of their nature,not a problem.
#9 _Bomber Watson_
Posted 05 June 2011 - 05:53 PM
SC12's are fitted to holden sixes with very little success, although peple still try it.
The blower is just to small.
Butttt for a Starfire it would be far more on the money.
So use that or a stock turbo off a silvia or something similar, maybe a skyline one if you want to try to get some half decnet power, and have a play.
Its all good fun, trust me.
EXH mani's dont take much to make, just make a J pipe off the stock cast iron manifold and bolt the turbo up, boost reference a small 2bbl holley and go have some grenade fun like i did on a slightly larger scale (see "battle of the hand grenades" thread.)
Or blow it with the SC12 and go shit a few V8 boys off hehehehe
Edited by Bomber Watson, 05 June 2011 - 05:55 PM.
#10 _cruiza_
_cruiza_
Posted 05 June 2011 - 06:00 PM
back in the day had a friend with the starfire, not only was his car noisy and slow it drank a lot more fuel then my 202 powered one
#11 _Bomber Watson_
Posted 05 June 2011 - 06:24 PM
Yes but back in your day you had square wheels.
Edited by Bomber Watson, 05 June 2011 - 06:26 PM.
#12 yel327
  • 13,656 posts
Posted 05 June 2011 - 06:56 PM
I'd just buy something like the heap of sh!t in the attached auction and use everything out of it:
http://www.ebay.com....=item4aab9f0236
#13 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 05 June 2011 - 07:33 PM
http://www.ebay.com.au/itm/holden-hz-hq-hx-hj-seden-factory-v8-4spd-/320706904630?pt=AU_Cars&hash=item4aab9f0236
+1
#14 _Bomber Watson_
Posted 05 June 2011 - 07:35 PM
And that would be destroying a potentially cool car.
Have you guys never done anything fun just for the sake of it???
#15 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 05 June 2011 - 07:39 PM
ahh bomber you remind me so much of me mate who puts calendars on dashes of starfire powered sunbirds or were they a torana,the jury is still out to lunch on that topic and its an extended overseas round the planet lunch break,i think the jury is lost,too much fine wine and good food.
orig cast mani. been ditched because someone talked me into makin 4 into 1 pipes so carbs would fit,the things we do.
Sounds like air pump way to go to me,fit one up see how it goes,if it turns to scrap metal start again i spose.
Fuel consumption not too foul considering low(no) power output from eng.but would probaly be better with 5spd.
shit the v8 boys off a bit might be a bit of a task but maybe get it to spin a bit harder if it dont shake everthing off be a difrent story.
#16 rodomo
  • 18,039 posts
Posted 05 June 2011 - 07:58 PM
Dinosaur Fred that went no-where: http://www.gmh-toran...ate-a-starfire/
#17 hanra
  • 10,983 posts
Posted 06 June 2011 - 07:52 AM
Would the SC14 be a bit more suitable?
#18 _sstorana_
_sstorana_
Posted 06 June 2011 - 08:45 AM
Hi Guys
I have to say that I have had some great motoring in my UC Sunbird. For me, the motor is ok as far as a four cylinder car goes. I have had it on some long Club runs and she has never missed an beat and has stayed up with the pack. It evan surprised some of the guys in the Club as to what it could do.
On one trip to Coonabarrabran, I had it sitting at 140kph for approx 45km. It didn't miss a beat. The top speed I have had it to was 150kph!
What is it's secret?? It runs a 32/36 Weber Carby. That's it!
If I had to change anything at the moment it would be the gearbox. On long trips it screams for a fifth gear!
Mick
#19 Heath
  • 18,393 posts
Posted 06 June 2011 - 10:56 AM
Yeah because it has the 3.9 diff, which would be very advantageous if you were to keep the 4cyl and install a 5spd, definitely.
Probably bolts straight up to an M76??? or a typical Toyota box swap?
:clappin: :clappin: :clappin:
#20 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 06 June 2011 - 01:15 PM
Starfire should bolt up to anything the red6 does - isn't the back the same?
The supercharger sounds like a plan. Check the compression and give it a bash.
Grant..
#21 76lxhatch
  • 7,208 posts
Posted 06 June 2011 - 01:49 PM
The ones in the VH and VK Commodores I've had were all factory M76 five speeds with Varajet carbs, they go surprisingly well - enough to maintain 100km/h up steepish hills in top gear and to hit a top speed of around 175km/h with a tail wind! Worth mucking around with for novelty value if you already have a V8.
#22 _Bomber Watson_
Posted 06 June 2011 - 05:32 PM
To small for a Holden six as well, far far to small.
Would probably also work on the starfire though, but i think it would need some cam and head work to make the use of a SC14 over a 12...
Dunno, never done it, thats just basic number crunching. Only one way to find out!!!
#23 _Woodsy_
_Woodsy_
Posted 06 June 2011 - 06:14 PM
I had a lx sunbird with a opel 1900 in it, and i didnt mind that motor. Give the starfire a tickle and see how she likes it.
#24 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 16 June 2011 - 06:43 PM
i took some advise from input,got a small cam on way,,290 adv dur.315 lift, and a mate has donated 2 40dcoe carbs.and manifold,
clean up ports, fit decent valve springs,valves same as blu motor so wont go bigger,giv it a go and see what happens
blower on bak burner,needs the drive pulley and hard to get pistons for 3.5 bore
