lc gtr
#226
Posted 14 January 2012 - 02:43 PM
and thats after he when for a drive in a 700hp skyline and said the skyline had nothing on this
#227
_Skapinad_
Posted 14 January 2012 - 02:54 PM
#228
_Skapinad_
Posted 14 January 2012 - 03:09 PM
#229
Posted 16 January 2012 - 05:09 PM
YEA
ABOUT TIME
#230
_Liam_
Posted 16 January 2012 - 07:17 PM
#231
Posted 17 January 2012 - 07:32 AM
Has been 10 years in the makeing, and to be up front and honest it's well worth the wait.
#232
_Skapinad_
Posted 17 January 2012 - 08:15 AM
#233
Posted 17 January 2012 - 01:54 PM
#234
_Skapinad_
Posted 17 January 2012 - 01:55 PM
#235
_Big T_
Posted 17 January 2012 - 03:21 PM
Now get out there and have some fun mate.
#236
Posted 17 January 2012 - 07:46 PM
#237
_Skapinad_
Posted 17 January 2012 - 08:08 PM
#238
Posted 19 January 2012 - 07:18 PM
Was also amased that 60 lt of fuel only gave me just over half a tank too.
#239
_mick74lh_
Posted 19 January 2012 - 10:37 PM
#240
_V6 UC_
Posted 20 January 2012 - 12:12 AM
#241
Posted 20 January 2012 - 06:15 AM
Was looking under the car last knight checking how things where and noticed that the aftermarket new ball joints (top) bolts had come louse and out of the 8 bolts in total had lost 2 nuts and spring washers.???
Has anyone else had this problem???
Also the 2 rubbers that go between the chassie rail and the x'member had destroyed them self.???
I retighterned the bolts and replaced the rubbers so i could take the car down today for a wheel alinement.
Will be watching them closely as i don't want any miss haps.
#242
_Liam_
Posted 20 January 2012 - 10:56 AM
#243
Posted 21 January 2012 - 09:44 AM
Took the car out last night and all when well except for blowing 2 fueses.
Have put up a detail about it in electrical if anyone can explain why.
Edited by lcxu105, 21 January 2012 - 09:45 AM.
#244
Posted 23 January 2012 - 09:52 AM
more pics
the good side
ready for paint
blackouts first
base coat next
bit of gold
add some clear
time to come home
replace iner panels that had been cut out with alloy to keep weight down
Get the interia done and fit sound system
fit dash
Posted 23 January 2012 - 10:04 AM
fit grill and headlight surrounds
sand paint with 200 wet and dry and buff
get mod plate and rego time for cruzing
Thank you all for your imput along the way and thanks to thoses who have helped out with any questins i have asked along the way.
Thanks Dave
Posted 23 January 2012 - 03:32 PM
#248
Posted 25 January 2012 - 12:19 PM
#249
Posted 26 January 2012 - 08:24 AM
Car Lc GTR 1970
Paint is factory cameo gold met with LJ xu1 black outs and GTR-XU1 stickers fitted.(it's how i like it)
Engine single turbo RB25 NEO from 2003 skyline
stage 1 cams, head ported,
free flowing 3" exhaust with 100 cel cat and hi flow mufler
aftermarket intercooler rated for 550-600hp
bottom end std boost uped to 10psi for street and 12psi for track
Good for approxly 350-400 @ wheels
Engine x-member modified to suit and all new rubbers and joint fitted
Steering rack rebuilt
Gear box is std 5 speed turbo box from skyline
Gear box x-member custum made to alow exhaust to sit up higher
tail shaft 3" thick wall with v8 uni's
diff is a 10 bolt salisbury diff 3.36lsd VN commodore axles cut down and resplined
Brakes are WB kingswood front and VR commodore rear
XU1 brake booster and Kingswood master cylnder disk disk
Rear seat removed and sound system. 2x 6x9 200w sony explode speakers and a 600w sub
250amp kenwood amp just for the sub
kenwood CD head unit
dash changed to LJ Personal thing just like it more then LC. GTR dash facer retained and speco gages fitted.
seats are after market spors raceing seats rta aproved
Fuel tank is custom mad alloy holds approxly 90lt
fuel system consist of holly blue pump and reg set at 11lt per hour for lift pump.
bosh 044 main pump with 2lt swurl/surge tank
Drift fuel reg set at 40 psi riseing rate for turbo engine
Roll cage is custom made 8 point and is full welded and bolted to the car.
Rails have been stich welded and reinforced for extra power.
uper diff control arms are boxed for extra strength and will be doing the same to the lowers soon.
shocks are std torana re built/ ustom made to my spec's and are quite stiff
springs are lovels in the front and kings in the rear.
car corners very well and is like it is on rails when turning corners.
Wheels are currently commodore pursuit rims 15x6 with 185 50 15 front and 195 50 15 rear. (they look like 13" wheels)
currently looking at putting 17x8.5 rears and 17x7.5 front, just tring to get the off set i'm happy with.
Now for the big question how much.
Car would have to owe me around the 30k over the last 10 years so works out at $3000 per year or $57.7 per week for 10 years.
So it's all done and dusted with mod plates and rego
TIME FOR CRUZIN
Thanks all and hope you have enjoyed the read and photos of the build.
Dave
#250
Posted 27 January 2012 - 09:42 PM
I'm turbo charging my LC and I'm really interested in your intercooler setup. I have a few questions for you.
- What size is the intercooler core?
- What size is the cooler including the tanks?
- How did you mount it?
- Did you need to modify the bonnet catch or the upright support under the bonnet catch plate?
Cheers,
Brett.
