lc gtr
467 replies to this topic
#176 _mick74lh_
_mick74lh_
Posted 28 November 2011 - 09:55 PM
That bloody awesome! I once got to drive an HQ tonner fitted with an RB30 turbo and it seemed so wierd being in an old Holden with an engine making all jap turbo sounds. That looks like alot of fun. Well done getting it all running.
#177 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 01 December 2011 - 05:27 PM
Quick update.
Was just curious about the height of my car and found out the std height for a lc gtr was 54.2"
this equates to 1376/7 mm
Even thou i have put in 25 mm spacers in the rear and 20mm in the front the height now is wait for it
You guessed it 1376mm.
So i know know that my springs are 1" lowered items.
the spaces i have fitted will not hurt the set up or the springs as they are made from 300+grade steel and i used m12 high tensile bolts and nylexs nuts to replace the ones i removed. so the bolts are larger diamiter and stronger then stock ones.
I did this as i wanted the same ride as i had before the rebuild as i was very happy with it before.
Only lifted it up to get tyre clearance more then anything as the tyres where hitting the front gaurds when turnng and the rear was bottoming out.
Edited by lcxu105, 01 December 2011 - 05:28 PM.
#178 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 13 December 2011 - 05:50 AM
Well not going to good at the moment.(verry unhappy)
Started the car last night to test the speedo after hooking it up, while i was worming it up to take it out for a drive, the exhaust cam snapped the end clean off.
I expect that it now has bent valves dammaged head and pistons and needs new cams.
Engine was was on fast idle at 1500-2000rpm when it stopped all of a sudden with a lot of grinding noise.
oil pressure was on 40 psi before stopping.
Pulled the front of the engine apart and found the problem.
as that is where oil was leaking from after stopping.
As you will see in the photo's
Edited by lcxu105, 13 December 2011 - 05:56 AM.
#179 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 13 December 2011 - 05:54 AM
you can see where it was and you can see where the cam has snapped off right at the cam gear.
Suppect that the front cut that the engine can out of had been hit hard in the front right on the cam gear.
It would explain why the engine came with out some of the caseing and no crank sencer.
found everdance of this when i pulled it apart to find out what had happened.
So on the hunt for a new engine now
#180 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 13 December 2011 - 07:26 AM
Bad luck, front cuts can be a bit surprise bag.
Pull the head & check for damage, it could be less than you think.
#181 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 13 December 2011 - 12:22 PM
  • Yer spoke with an engine builder today and he said if i drop it off on Monday next week he will have it all done for x'mass.
  • He said it would be bent valves and a new cam so should reco the head while it's off to make sure everything is a ok and wack in a set of new aftermarket cams will do the trick.
  • as much as i would like to rebuild the engine to what i want rb30/25 spool rods forge pistons and stage 2 cams with port work,
  • i can't afford it right now so i will just have to stick with std engine but still good for around the 350hp at the treads with the set up i'm running.
  • Looking at 650 to reco the head 200 for valve springs 90 for timeing belt and 850 for cams.
  • might offer him 2000 cash with port work done.?????? can only try
#182 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 14 December 2011 - 01:13 PM
engine is out and off to the engine builders tomorrow arvo.
yeh
#183 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 15 December 2011 - 06:44 AM
good luck man, tough break! hopefully not too much of a hit on the wallet.
#184 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 15 December 2011 - 12:29 PM
i hope it pulls up at 2k otherwise i wont be able to fix it
#185 _LHSL308_
_LHSL308_
Posted 15 December 2011 - 04:17 PM
Good luck Dave got my fingers crossed for ya mate.
#186 _mick74lh_
_mick74lh_
Posted 15 December 2011 - 10:24 PM
Bloody bad luck. Hopefully it works out for a reasonable price. Such a disapointment when you're so pumped about something.
#187 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 16 December 2011 - 05:36 AM
thanks all should find out today hopefully if not will be on monday.
Hope it's not toooooo bad and just bent the valves,
so i will replace the cams with stage 1 cams as i can't afford to up grade the ecu atm, heavy duty valve springs to suit. reco the head and maybe some port work, see what the budget alows for.
Going to replace the sump and pick up while the engine is out and repaint the engine bay aswell.
Due to the fact that when i was haveing all the dramers with the brakes i split a metal line and didn't notice it and fried the paint on the drivers side iner gard.
so a busy week ahead of me with the car and an extra busy week ahead of me at work too (dam it).been doing 16 hour days this week to get the car done and all my work at work done too.
So tied atm.
well i will keep you all updated with all findings.
Dave
#188 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 19 December 2011 - 05:15 PM
well i whent to the engine builders today to see how bad it is.
well it goes like this.
number 6 exhaust valves hit the piston just hard enough to leave a mark on the piston.
as you would expect they are bent and so is anouther 2
so all up 4 exhaust valves bent 2 inlet valves bent.
2 valve guides need to be replaced.
so all up to get the head recoed, replace the valves, new cams and springs. new timeing belt kit including idler pully and tenchener pully, small port work new head gasket and manifold gaskets and labour.
$2200 cash price.
#189 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 21 December 2011 - 03:27 PM
Just a quick up date
Went to the engine builders this arvo.
He has ported the head and got the new cams in.
He said i should get about a 20-30% incress in power.
so i started with from factory 206kw uped the boost added a 3" exhaust and after market inter cooler good for around anouther 30kw
so this gives me around 236-240 kw
now with the new cams and port work good for around another 50kw
Giveing me around 290-300 kw
Now remember nissan rate their engines at the wheels not the flywheel like holden and ford do
So i should be able to put it on the dyno and turn out around a genuine 400 hp at the wheels
not bad for a 2.5lt 6 pot with a std bottom end.
#190 _Liam_
_Liam_
Posted 21 December 2011 - 06:42 PM
That is going to be awesome Dave. When did the builder say it'll be done?
#191 Ice
  • 15,200 posts
Posted 22 December 2011 - 11:05 PM
Put some slicks on it dave and have some fun you know you want to :3gears:
#192 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 23 December 2011 - 08:49 AM
i will be takeing it down the qrt for some fun to see how it goes
#193 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 23 December 2011 - 06:54 PM
Well i have my engine back its now sitting on the cross member ready to be put back in the car.
Hopeing to fit it in the morning if i can find someone to help me do it.
I enjoyed watching the engine builder bolt it back together today.
Will enjoy it more when i start it in the car.
Edited by lcxu105, 23 December 2011 - 06:56 PM.
#194 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 23 December 2011 - 10:13 PM
time for christmas skids dave!!
#195 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 25 December 2011 - 09:40 AM
Well i got the engine in and started it.
Just need to set the tappets propley and away i go.
sounds alot tougher now with the bigger cams. can't wait till tuesday when the engine builder comes
over and sets the tappets propley as he had run short of time when he put the head on the other day.
#196 _stretchlc_
_stretchlc_
Posted 25 December 2011 - 09:46 AM
One word!.....................VIDEO!!!
#197 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 26 December 2011 - 09:53 AM
i will when the engine is running right for all to see
#198 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 27 December 2011 - 03:34 PM
engine builder is unable to come today as he is at the hospital with his son after his son broke his wrist and needs an op to fix it.
Pulled the tappet cover off the exhaust cam and found that one of the buckets had jumped out on start up and that is what was causeing the noise.
has screwwed the bucket and chipped a small piece off the side of the loube, not enough to worrie about as it is right on the edge of the lobe, not in the centre where the cam hits the valve stem, so lucky.
have measured the lift on the lobe and comes in the same as all others. .618 thou lift.
i don't think it will hurt the cam as they are not hardend i don't think so anyway. if they are it will need to be replaced. but an easy fix as it can be done in the car at the engine builders expence NOT MINE
#199 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 01 January 2012 - 10:07 AM
well i bolted the bonnet back on yesterday and started to finish the interia (just a few miner touch up) so all back on track now to have at the Australia day show at Rocklea (if not raining)
Not willing to drive it in the rain as it has more then enough grunt to light them up in the dry.
Edited by lcxu105, 01 January 2012 - 10:07 AM.
#200 _2ELCS_
_2ELCS_
Posted 01 January 2012 - 10:21 AM
Not much point in driving them in the rain , if you don't have to, thats what the family hack is for ?
