Removing Banjo LSD Axles
Posted 06 June 2011 - 12:45 PM
Posted 06 June 2011 - 12:48 PM
Posted 06 June 2011 - 12:49 PM
Or... if your strong and the car is stable on the stands
Put a drum back on... back to front... and use it as a hold to yank them out by hand
Posted 06 June 2011 - 12:53 PM
Posted 06 June 2011 - 12:55 PM
#9 _judgelj_
Posted 06 June 2011 - 01:45 PM
i second everything everyone has said, finding the backwards drum to be the best option. usually they come out easy but sometimes they are a bit of a c^nt just be persistent.
Posted 06 June 2011 - 02:25 PM
Posted 06 June 2011 - 07:24 PM
Edited by rexy, 06 June 2011 - 07:25 PM.
Posted 06 June 2011 - 07:40 PM
What model car are we talking here Hanra?
Posted 06 June 2011 - 10:40 PM
LH SL/R 5000.
Looks like its got coarse spline axles.....
Posted 06 June 2011 - 10:45 PM
Leave at least 2 nuts on to catch the little sucker as it will want to go walk about.
Posted 09 June 2011 - 10:57 PM
Sounds like you've never has a stuck one Rexy? Lucky you!
The lever method has never failed me - even the partly twisted ones have come out, albeit with a little effort.
I guess a slightly built lad or ladette may struggle a little but works fine for me.
"Give me a lever long enough and a fulcrum on which to place it, and I shall move the world."
Archimedes
#16 _thorley_
Posted 06 April 2012 - 09:29 AM
banjo LSD
they seem to go half way in, I can feel the spline key in, then hit something and stop hard.
the bearing is about half way in, something has moved in the diff.
Urgent this is my daily driver please help.
regards
Nick
Posted 06 April 2012 - 09:59 AM
Hello I can't get my axles back in!!!!
banjo LSD
regards
Nick
Has the diff been removed, recoed & refitted or have you only replaced axle bearings?
If you haven't had the diff out then nothing should have moved.
Have a look down the axle housing tubes with a good torch and see if you can see if the splines in the star gears & cones line up.
If they appear to be in alignment then it may just be the 'O' rings in the outer surface of the wheel bearings binding in the housing.
Lubricate the 'O' rings with a smear of diff oil and try again. Also make sure the axle seals are properly seated into the housing before you push the axle right in.
Worst case is remove the diff and check the star and side gear splines are aligned, if they aren't then you might need to take it to a diff repairer.
I don't know if you can realign the splines without dismantling the diff, someone more knowledgeable might.
Posted 06 April 2012 - 10:17 AM
#19 _thorley_
Posted 06 April 2012 - 10:19 AM
I found a small torch and put it on a stick and I can see the spline that I can feel with the axle and I'm absolutely sure it is not the rubber ring on the bearing.
this is a diff axle problem and I have rattled shaken, rotated and hit with hammers for hours.
sorry that I don't think I can photograph the diff through the axle housing.
Still fighting
Posted 06 April 2012 - 10:26 AM
#21
Posted 06 April 2012 - 10:35 AM
Try with the O rings removed from the bearings, if the axle/s still won't go in then it's definitely not the O rings binding.
#22 _thorley_
Posted 06 April 2012 - 10:38 AM
thanks
#23
Posted 06 April 2012 - 12:51 PM
#24
Posted 06 April 2012 - 01:54 PM
Did you take the old outer cones out of the housing ?
Banjo diff housings don't use tapered needle roller bearings so there will be no outer race left in the housing.
#25
Posted 06 April 2012 - 02:59 PM
SO what have I been fitting all these years ?
