Hi John
Let me first start off by saying that if there ends up being a problem with the sender we will happily exchange it for a new one and i would apologise for the inconvenience
if you wish to return it and get it checked that is fine mate but i thought id write a reply here to help you diagnose the problem if you so wish too
the senders are a very simple design and only require a basic undestanding of electronics and resistance, the electric components of these gauges is just basically a coil of resistive wire and a contact on a swing arm (float lever), as the float goes up and down the contact moves along the resistive wire, the more it moves the more/less resistive wire the electricity has to flow threw. your fuel gauges is basically a resistance gauge with fuel level decals instead of resistance/voltage decals.
as mentioned above make sure you have a good earth, with a poor earth it can cause your gauge to fluctuate and read wrong as it registers a greater resistance in the system
there is a simple way to test the gauges out of the car with a multimeter, set the multimeter to resistance and place a probe in the insulated output pin and the other probe somewhere on the body, i prefer to use aligator type clips as they allow you to move the float arm alot easier aswell as giving you a better earth then the standard probes
an lc lj should register 30ohm's full - 15ohm half - 0 ohms empty
see the images below for a sender i just checked to make sure they were fine, this sender registered 32ohms-1ohm, well within an acceptable range. the 32 ohms will mean it sits on the full mark for a fraction longer and 1 ohm will be as original, holden list 0 ohms but that is next to impossible to get, any electricity passing threw an item like a fuel sender will still pick up resistance along the pipes etc even if the contact is not in contact with the resistive wire
Like i mentioned at the start, this reply was just to try and help you out to see if it was your vehicle or the sender unit, if you choose to return it to be checked that is fine but i thought id try my best to help you out
Cavan
Edited by BIGCAV, 08 June 2011 - 11:19 AM.
