Ill start my own thread as I think some of you guys are too caught up in your own bullshit to be able to comment on what I have posted!
Posted 04 May 2012 - 09:29 PM
Posted 05 May 2012 - 07:16 AM
Hello, anyone there??
Posted 05 May 2012 - 07:46 AM
Posted 05 May 2012 - 12:11 PM
Posted 05 May 2012 - 12:36 PM
Posted 05 May 2012 - 01:56 PM
Posted 06 May 2012 - 09:52 AM
Part Number 35603 Lobe Separation 110 Valve Lift Inlet Opens 32 B.T.D.C. Inlet Closes 68 A.B.D.C. 0.443 Exhaust Opens 72 B.B.D.C. Exhaust Closes 28 A.T.D.C. 0.443 Inlet Duration 214 at 0.050 280 Advertised Exhaust Duration 214 at 0.050 280 Advertised
Posted 06 May 2012 - 08:04 PM
Posted 13 May 2012 - 09:48 AM
Posted 14 May 2012 - 08:13 AM
Posted 14 May 2012 - 11:38 AM
Posted 14 May 2012 - 11:47 AM
Posted 14 May 2012 - 06:56 PM
Posted 15 May 2012 - 08:55 PM
Posted 15 May 2012 - 09:04 PM
Posted 15 May 2012 - 09:07 PM
Edited by CraigA, 15 May 2012 - 09:07 PM.
Posted 15 May 2012 - 09:37 PM
Mine is supposed to run 14 deg initial but I use 12 initial, 36 overall with 10.5:1 comp using a full performance ignition setup on a Crow 35803 camshaft.
No dyno but 1/4 times/weight show 210 rwhp.
Last drag meet over 7k a few times and plugs looked good but showed a little detonation on fresh BP Ultimate.
Posted 15 May 2012 - 09:57 PM
Posted 15 May 2012 - 10:16 PM
Posted 16 May 2012 - 07:44 AM
And I think the signs of detonation were the result...
I usually run 10 deg initial for normal use.
Full specs were provided to performance ignition.
What sort of timing do you think it should be running?
Posted 16 May 2012 - 08:20 AM
Posted 16 May 2012 - 08:36 AM
Posted 03 July 2012 - 07:49 AM
Posted 03 July 2012 - 10:53 AM
Posted 03 July 2012 - 12:05 PM
