Fuel filters....
Posted 18 June 2011 - 09:32 AM
Whats everyone running??
Old paper cartrige type
http://www.summitrac...arts/SUM-G1507/
Or the nice shiny new steel screen type ones
http://www.summitrac...rts/SUM-230100/
From what i have seen the inline type ones seem to flow more than the canister type ones, but the canister type ones tend to have a slightly finer filter. Being a paper filter over a stainless screen i think it might take longer to clog up to??
I already have one of the canister type ones, just wondering if its worth upgrading to an inline type one....At the end of the day i have a 140gph fuel pump and a fuel filter that only flows 75...
_LS1 Hatch_
Posted 18 June 2011 - 09:34 AM
http://www.summitrac...arts/AEI-12301/
And one of these...
http://www.summitrac...arts/AEI-12304/
Posted 18 June 2011 - 09:59 AM
I was looking at the aeromotive ones, just when i felt like making the thread i found the summit ones first hehe.
_oldjohnno_
Posted 18 June 2011 - 10:13 AM
Posted 18 June 2011 - 10:22 AM
Thanks for that Oldjohnno. Like i said already have a paper canister type one and it already fits in the engine bay....So its looking like i might stick with that
Edited by Bomber Watson, 18 June 2011 - 10:26 AM.
Posted 18 June 2011 - 10:58 AM
Thoughts on aluminum line for fuel line??
http://www.summitrac...arts/SUM-G2538/
So cheap and easy to work with...
_LS1 Hatch_
Posted 18 June 2011 - 11:17 AM
Oh, and I use -8AN aluminum supply line and -6AN aluminum return line. (aside from the flexable braided bits of course)
And no...I don't like to think what I spent on my fuel system
Posted 18 June 2011 - 11:33 AM
3/8 feed and return will do me fine, if i set up some kind of a turboed engine or similar in the future i'll be putting a fairly big (like 4lt) surge tank up the front of the car, so all the feed and return im setting up now will be doing is feeding and returning the surge tank....
And for the current engine it will suffice quiet well i think....
So alloy fuel line is common in the states with no issues???
Not sure if its legal here or not but oh well....
Edited by Bomber Watson, 18 June 2011 - 11:34 AM.
_LS1 Hatch_
Posted 18 June 2011 - 11:57 AM
As for being legal...can't say there....don't have to worry about that sort of stuff here.
Oh, and on the line size...when I was mapping out of the fuel system, I did it large enough to support forced induction I figure if I ever down the track went that route.
I also use the Aeromotive fuel pump controller...so the pump slows down at lower rpm. Keep the fuel cooler and saves the pump some as well. It is totally adjustable too.. I just have it set to go full flow at 2500 rpm at the moment.
Posted 18 June 2011 - 12:10 PM
Sounds like the goods.
Yeah i have the flaring tool type thing here to, although i think its 45 degree.....Might have to look into that.
Im only playing with a carbie fed 202 at the moment remember so yeah as i said 3/8 should be fine
Posted 18 June 2011 - 12:14 PM
http://www.summitrac...parts/OTC-4503/
Looks like now i gotta buy this one as well
http://www.summitrac...rts/SUM-900311/
*mutters*
_WYLDLC6_
Posted 18 June 2011 - 12:21 PM
Cheers Chris.
_LS1 Hatch_
Posted 18 June 2011 - 12:27 PM
Yep, just checked, i have this one
http://www.summitracing.com/parts/OTC-4503/
http://www.summitracing.com/parts/SUM-900311/
*mutters*
Reminds me of a drawer in my tool box..
Posted 18 June 2011 - 12:35 PM
_LS1 Hatch_
Posted 18 June 2011 - 12:43 PM
Just used a -10AN o-ringed union fitting and screwed the filter right into the pump.
_nemo355v8_
Posted 18 June 2011 - 08:35 PM
ya im a cheap bastard lol
Posted 18 June 2011 - 09:22 PM
Posted 18 June 2011 - 09:45 PM
The outboard mechanic told me that they restricted the flow on outboard engines over 200HP, the big problem was the screw in fitting you attach your fuel line to had to small of inside diameter and therefore restricted flow at W.O.T.
He put me onto another brand which I can't think of the name of at the moment, similar style, clear bottom bowl with a water drain but the inlet/outlet took a much larger screw in or hose adapter fitting.
Just something to be aware of when choosing this style of filter as your flow is governed by the smallest diameter in your fuel system.
Posted 18 June 2011 - 09:52 PM
Edited by Bomber Watson, 18 June 2011 - 09:55 PM.
