Berro's Rusty UC to A9X HATCH
#526
Posted 17 November 2014 - 09:20 PM
Burty
#527
_A9X UC_
Posted 17 November 2014 - 10:34 PM
Let me know how you go
The below pic is from CRS on T5s
_berro59_
Posted 18 November 2014 - 09:43 AM
Edited by berro59, 18 November 2014 - 09:46 AM.
#529
_LHSL308_
Posted 18 November 2014 - 01:52 PM
Not sure whether the UC heater box is the same as the LH ones. I can vouch that it's a prick of a job removing the heater box and putting it back in. I never want to do that job again.
#530
_A9X UC_
Posted 19 November 2014 - 09:34 AM
I can imagine that it would be fairly hard even with a carby and dizzy in the way
Looking for simpathy here coz i have a bunch of bannans in the way... Dam it !!!' 😡
#531
_LHSL308_
Posted 19 November 2014 - 10:19 AM
#532
_berro59_
Posted 19 November 2014 - 09:51 PM
I've done the whole dash graft so its identical to LX now.
#533
_A9X UC_
Posted 20 November 2014 - 10:53 AM
#534
_LHSL308_
Posted 20 November 2014 - 05:56 PM
#535
Posted 21 November 2014 - 07:59 PM
Hmm any difference with a VS V8 T5? Please let the cat out of the bag I have both EL 6cly T5 and VS V8 T5 gearboxs
The moment of truth.
Trying to fit the VN Commodore T5 Manual Gearbox............
After a long while wading through threads and social media comments... Hearing that it cant be done and you need the Ford T5 Box.
I can officially say the Commodore T5 gearbox fits perfectly the UC Torana with out modifying the tunnel or interfering with the mid tunnel strengthening rail. 20- 25mm of gap between the tunnel strengthening rail.
I will try and get more pics soon.
Engine should go in next week. Yay!
#536
_berro59_
Posted 24 November 2014 - 10:29 PM
Sorry Neil,
I have no idea. I would imagine they would be the same.
#537
_greg2240_
Posted 07 January 2015 - 09:42 PM
any updates Berro?
#538
_berro59_
Posted 13 January 2015 - 06:33 PM
Ok here goes.......
Holden T5 will fit the tunnel ok (photo attached) but the tunnel needs to be cut through parts of chair strengthening plate and boxed out. (possible engineering required). This is due to shifter position being too far back.
The holden T5 box is approx 810mm long from bellhousing to shifter. (picture attached)
I was still using the commodore engine mounts and not HQ. (commodore left HQ right)
I was also still trying to use the commodore sump and oil pick up instead of HQ ! (yellow one is HQ, dumb me)
So back to the drawing board I bought a EA 6 cylinder manual box approx 797mm long (167mm imput shaft) with a dellows conversion belhousing. This brings the shifter forward. The EA box is the one to get as it has better ratios.
Also needed to get a different spigot bush as the centre hole needed to be larger.
And in she went. Happy man!
Headers are a bitch to fit!!! Had to remove starter motor and fit from below passager side. Drivers side jack one side of engine up remove engine mount and steering knuckle, also fit from below! Also heat painted them black.
Fitted CRS crossmember and this left lots of room for exhaust.
I also had to adjust the radiator down as it was sitting too high.
_mick74lh_
Posted 13 January 2015 - 09:45 PM
Shit hot! Looking good Berro. Anything else you needed to do to the EA T5 box? Are the splines on the input shaft same as an Aussie?
#540
_A9X UC_
Posted 13 January 2015 - 10:49 PM
Mick the input shafts are different from T5 to aussie 4 speed
#541
_mick74lh_
Posted 14 January 2015 - 06:44 AM
So you need to run a different clutch friction plate?
#542
_A9X UC_
Posted 14 January 2015 - 09:42 AM
Ford clutch plate
Holden pressure plate
Mine is the current setup. Give CRS a call they can give you the size of both
#543
Posted 14 January 2015 - 12:09 PM
#544
_berro59_
Posted 15 January 2015 - 02:43 PM
Thanks.
Very happy.
Got a quote on shortening Commy 2 peice the tail shaft today from final drive in perth.
They said that its best to sleve it and turn it into a single piece so you dont need to mount the centre bearings sections. Any one used a 2 peice and if so where did you mount it? I've heard you get more fliexibility with the gearbox to tailshaft angles.
#545
Posted 15 January 2015 - 02:58 PM
UC's have a mount built into the chassis for 2pce tailshafts don't they?
#546
_berro59_
Posted 15 January 2015 - 03:18 PM
Dont know I will need to have a look.
#547
Posted 15 January 2015 - 03:42 PM
Yeah had a look under floor on UC and i sware theres a mount for a two piece shaft.
#548
_j.e.d._
Posted 15 January 2015 - 04:09 PM
Check 76lxhatch's build 'SS hatch' on page 2 as he's done this on his hatchback from memoryThanks.
Very happy.
#549
Posted 15 January 2015 - 04:16 PM
Single peice is obviously cheaper due to less parts & you don't have to set another shaft angle
Personally I'd keep it simple but each to their own!
Your car looks bloody awesome by the way!
#550
Posted 15 January 2015 - 06:04 PM
I looked at doing it as I had a two piece from the donor commodore , but decided on the one piece because it was simpler.
This build is awesome.
