Berro's Rusty UC to A9X HATCH
662 replies to this topic
#551 76lxhatch
  • 7,205 posts
Posted 15 January 2015 - 07:02 PM
Check 76lxhatch's build 'SS hatch' on page 2 as he's done this on his hatchback from memory
Yep, this was a silver bullet for me, because the Commodore driveshaft has a proper CV centre joint so its angle doesn't matter. Allows the front and rear uni joints to be on correct cancelling angles when that would be impossible with a one piece shaft, no more vibrations!
http://www.gmh-toran...e-5#entry638425
What happened to work well for me was using the standard length VN rear shaft, and shortening the front only. I made a mount for the bearing which is welded forward to the safety loop, this holds most of the weight and is stabilised by a couple of rivet nuts through the tunnel immediately above it. Requires a second safety loop for the rear shaft which is very tight but do-able.
http://www.gmh-toran...e-8#entry757490
I have a UC parts car with a factory two piece driveshaft here but I've never got around to getting under it to take a good look. I think it has a cardan centre joint so not as useful.
#552 _mick74lh_
_mick74lh_
Posted 17 January 2015 - 06:44 PM
Yes
Ford clutch plate
Holden pressure plate
Mine is the current setup. Give CRS a call they can give you the size of both
Thanks Mike.
#553 _berro59_
_berro59_
Posted 27 January 2015 - 10:29 PM
Thanks 76lxhatch.
I will use 2 piece shaft.
I had a look under and my UC must have had a 2 piece as it had the tunnel mounts for the uni joint.
I made up a bigger plate for the uni joint and it will bolt up no problem.
I got drive shaft balancing services to shorten the bottom end of the shaft by about 20 mm and got them to replace the Uni joint as it was stuffed.
Fitted it up today. Just need to paint it up.
#554 76lxhatch
  • 7,205 posts
Posted 28 January 2015 - 05:07 AM
Nice, that made it simple. Looks like you have quite a bit of room for safety loops too.
If you haven't set your uni angles yet you may want to build in some extra room for adjustment at the centre joint, obviously you can shim it down but maybe leave a little room to go up also?
#555 _berro59_
_berro59_
Posted 30 January 2015 - 06:05 PM
Yeah. Done that.
I am a little behind on my posts and pictures. Worked a treat.
Are the safety loops more for high horsepower applications 500+?
#556 76lxhatch
  • 7,205 posts
Posted 30 January 2015 - 07:31 PM
We have to put them in as soon as the diff is replaced with something non-standard, or the engine output increases more than 30% (so pretty much on any modified car). The stupid part of the rule is that the CV joint counts so a second loop is required (even on something like a Commodore where its factory).
Would have thought your rules would be at least as difficult?
#557 _LS2 Hatch_
_LS2 Hatch_
Posted 30 January 2015 - 09:01 PM
A lot of events call for tail shaft loop. Some half some full, depends on event.
Coming along nice by the way
#558 _berro59_
_berro59_
Posted 18 February 2015 - 10:28 PM
OK all,
Let there be light!
Fitted an original wiring harness LX (i think) but has floor high beam dipper switch. Could be LH.
Anyway I cant get all the dash lights to work. I have tested all globes and connections.
The Battery and high beam lights appear but that's it. I have turned up the dash light dimmer switch but no joy.
Could the dimmer switch be faulty and how do i test before i buy a new one?
#559 Heath
  • 18,385 posts
Posted 19 February 2015 - 07:01 AM
Well you just need to locate the appropriate terminals and run a ohmeter on it as you adjust the knob? Or you could bypass the potentiometer and see if it works. Obviously make sure the lights circuit has a working earth too.
Flared LX hatchbacks with nice yellowy round headlights glowing give me a hard on hehehe
Edited by Heath, 19 February 2015 - 07:02 AM.
#560 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 19 February 2015 - 07:18 AM
My 76 hatch still has dipper on the floor.
#561 _berro59_
_berro59_
Posted 19 February 2015 - 08:39 PM
Thanks. I will give that a try.
I might keep the foot dipper for something different as my first hatch had one .
#562 Heath
  • 18,385 posts
Posted 19 February 2015 - 08:55 PM
Hmm yeah I might try and find one of those too.
#563 _berro59_
_berro59_
Posted 07 June 2015 - 11:04 AM
Hi All,
Its been a while since my last post. Bit of an update.
Had to replace the 6cl clutch pedal. Fitted 1 inch master cylinder. Fitted new Elanor mustang style rims oh and yes took it for her first drive!
Down the driveway and back, Just need to get the rest of the exhaust fitted.
Good fun!
#564 _SmartE_
_SmartE_
Posted 07 June 2015 - 01:39 PM
Yep!! the rims are doing it for me, I like em.
#565 kiwi-lilj
kiwi-lilj
  • 1,426 posts
  • Name:Blair
  • Car:LIL J
Posted 07 June 2015 - 02:39 PM
Those wheels look great, really suit it well.
#566 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 07 June 2015 - 02:51 PM
Ive always wondered what they would look like on a Torana without the knockoffs
Yeah they look awesome berro :burnout:
#567 _berro59_
_berro59_
Posted 07 June 2015 - 10:06 PM
Thanks guys. I'm going to get the rears widened.
#568 _AD_75_
_AD_75_
Posted 08 June 2015 - 04:45 AM
Cool wheels Berro. How wide are the rears?
#569 _berro59_
_berro59_
Posted 09 June 2015 - 12:32 PM
Those are 17x9.5's running 255 40 R17. I could go out to 275 40 R17.
#570 HIBERN8
HIBERN8
  • 131 posts
  • Name:Mark
  • Car:1974 LH S
Posted 10 June 2015 - 10:20 PM
Hot damn! What a ride! Looks stunning mate. Bet it felt great to get behind the wheel even if it was a short trip 😁 rims look great too.
#571 _A9X UC_
_A9X UC_
Posted 16 June 2015 - 11:14 AM
Hope to see ya soon mate. With beers in hand of course🍻🍻🍻
#572 Nightrain 554
Nightrain 554
  • 51 posts
  • Car:Torana
Posted 20 June 2015 - 11:01 PM
Berro car looks fantastic nice colour and those rims look sick
Your build is. A credit to you
#573 _berro59_
_berro59_
Posted 08 September 2015 - 10:18 PM
Hi All,
Bit of an undate on the engineering. Costs adding up!
The drivers side exhaust header was exiting on a bad angle so had to remove the header and refabricate the exit point higher. This now allows me to fit front sway bar now.
Decided to get full mandrel bent exhaust system. Running VE cat 2 inch to exhaust and 2 and a half after. twin system. Have to meet VN motor emissions.
Was having bump steer issues with the HQ callipers and stubs so notched out the upper control arm. I also added a A9X style steel bump plate to the lower control arm.
Seats are a no go because of the deleted head rest so I have swapped them out. All going well should have the sign off next week. Will get picks of the work soon.
#574 _berro59_
_berro59_
Posted 08 September 2015 - 11:17 PM
Two of my favourite pictures.
#575 _berro59_
_berro59_
Posted 19 September 2015 - 10:38 AM
5 gas emotions and noise tests passed! I was worried as 304 motor with 600 Holley. All good. VN block.
