Engine Bay Wiring Configuration
53 replies to this topic
#1 hanra
  • 10,968 posts
Posted 03 July 2011 - 01:27 PM
I would like all the engine related wiring to follow the original factory route.
Does anyone have a pic or diagram of where the relevant wiring should go?
Does the purple starter wire come up round the front of the motor and is the oil/temp wiring all bunched together with it? Does this wiring run across the top of the manifold? If so what side of the carb?
Is the main B+ wiring for the body harness taken from the alternator? Starter? Or battery Pos terminal?
Thanks.
#2 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 03 July 2011 - 02:26 PM
Have you downloaded the workshop manual, i would assume it has a diagram of where to run the harness, i have it on my computer but can't seem to find it at the moment.
#3 hanra
  • 10,968 posts
Posted 03 July 2011 - 03:02 PM
Yeah Ive got a few workshop manuals at home. Im currently at work. Was just keen to know now! hahaha.
#4 _Liam_
_Liam_
Posted 16 July 2011 - 07:33 PM
Download from where Mort?
#5 _torbirdie_
_torbirdie_
Posted 17 July 2011 - 12:38 AM
Thanks.
Which torry are you talking about.
As far as i know, later alternator models had the B+ wire direct to +ve of battery and +ve battery to starter
Early generator models had only one cable to +ve of battery, generator wire to live wire connection on ignition switch.
#6 _LH SLR 3300_
_LH SLR 3300_
Posted 17 July 2011 - 09:41 AM
Using a factory GHM LH Torana workshop manual as a guide, i've tried to route the engine harness on my 1974 LH with 304 V8 as close as possible to how they were originaly. The harness runs along the top rear of the engine down to the starter motor. A metal clip that bolts on with the bell housing to engine block prevents the harness from touching the L/H/S exhaust manifold. The harness continues toward the front of the engine enclosed in a plastic sheath & exits just above the L/H engine mount where it is secured with another metal clip that bolts just beneath the engine number pad. It is then routed along the top of the timing cover to the temp sensor & alternator. The alternator charge wire runs parralel with it, secured to the cylinder head by a metal clip that also serves to mount the negative battery cable. My computer skills are limited so i can't scan the factory diagram but i can post pics of my engine with the harness in place.
#7 _LH SLR 3300_
_LH SLR 3300_
Posted 17 July 2011 - 10:13 AM
This is the engine bay of my 1974 LH.
As you can see i'm still in the final process of hooking it all up. I'm running an MSD ignition, so i had to slightly modify the ignition side of the wiring but the engine harness still follows it's original route. Here a pic of where the harness runs to the starter motor & the metal clip that retains it.
Using the original plastic sheath, it runs along the L/H/S of the engine block.
I've run the harness through the engine mount, but it runs above it originally, but still held in place by the metal clip just below the engine number pad.
It then runs up along the top of the timing cover. Originaly the B- bolts to the very top outter hole on the face of the cylinder head (the basic bolt hole configuration is the same for both early & VN type heads) & also attaches a metal clip that holds the alternator charge wire, which then runs along the top of the timing cover with the engine harness. As you can see i attached it to the lower bolt hole without the metal clip.
The B+ & alternator charge wires are originaly secured to the chassis rail just rear of the battery tray by the same type of plastic clip that holds the fuel & brake line to the R/H/S chassis near the steering column. I haven't got that far with mine, but i can post a pic once it's done.
As i mentioned, i got my info from a genuine GMH manual, while my configuration isn't 100% to factory specs it is a guide & i hope it is of some help. Cheers Matt
#8 hanra
  • 10,968 posts
Posted 22 July 2011 - 05:43 PM
Thats a great help Matt! Cheers for that!!!! Mine is a 75 LH SL/R 5000 so should be pretty much like yours! Cheers.
#9 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 23 July 2011 - 09:04 PM
It's on here, someone has a download link but i can't remember who, maybe someone else knows.
#10 hanra
  • 10,968 posts
Posted 12 April 2012 - 03:15 PM
Are the metal retaining clips for the engine bay wiring harness still available???
#11 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 13 April 2012 - 12:47 PM
I've seen plenty of repro's on ebay...
http://www.ebay.com....=item256e313823
http://www.ebay.com....=item2a111ffcf3
#12 hanra
  • 10,968 posts
Posted 13 April 2012 - 03:02 PM
Yeah Ive seen them to, but I have no idea if these are correct for my application???
#13 hanra
  • 10,968 posts
Posted 04 May 2012 - 08:33 PM
Does anyone know if these clips are available any where??? Or does anyone have have a few they dont need?
They appear to have a hole in the end of them for a bolt to go through.
Edited by hanra, 04 May 2012 - 08:34 PM.
#14 hanra
  • 10,968 posts
Posted 06 May 2012 - 02:52 PM
Even if I cant get any repro's Id gladly take 2nd hand ones so I can re-zinc em.
#15 slr5640
slr5640
    XA9X
  • 798 posts
  • Name:Brian
Posted 06 May 2012 - 03:56 PM
I think mick from torana restoration parts and accessories
is going to be doing these.
from a news letter...
Some items that we are working on at the moment include;
Engine harness clips (Small and large ones) for the V8's,
Radio Bracket (small one at the back) for the LH - LX Sedans,
Accelerator cable bracket for LX 4.2lt V8's,
Edited by slr5640, 06 May 2012 - 03:59 PM.
#16 hanra
  • 10,968 posts
Posted 06 May 2012 - 04:32 PM
Oh yeah, interesting. I might shoot him an email. Thanks for the heads up mate.
#17 hanra
  • 10,968 posts
Posted 14 May 2012 - 10:13 AM
Yep Mick will be reproducing the clips but its a few months off as yet... bugger...
#18 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 14 May 2012 - 01:31 PM
Brad, similar ones are available from Monaro Muscle Parts, but are not cheap
http://www.ebay.com....=item3cc4b0419c
#19 hanra
  • 10,968 posts
Posted 14 May 2012 - 03:10 PM
Thanks mate, yeah I saw those. I almost hit the Buy It Now button on Friday.... But resisted.... bit steep...
#20 _sstorana_
_sstorana_
Posted 14 May 2012 - 05:35 PM
Hi Brad
You twisted my arm!
I have just approved the suppliers to start making these. I expect a sample in the next few weeks.
Mick
#21 hanra
  • 10,968 posts
Posted 14 May 2012 - 05:39 PM
HAHAHAHAHAHAHAHAHAHA!!!!! FARK YEAH!!!!! Put me down for a set!!!! Wooooo!
#22 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 14 May 2012 - 05:57 PM
Yeah, Mick, put me down for a set as well.
Paul.
#23 _sstorana_
_sstorana_
Posted 14 May 2012 - 06:05 PM
Paul.
No Probs!
They won't be $85 a set either...
Mick
#24 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 14 May 2012 - 06:31 PM
Thanks Mick let us know when ready.
Thanks for the fuel line clips, they arrived today.
Paul.
#25 _sstorana_
_sstorana_
Posted 14 May 2012 - 08:35 PM
Paul.
No Probs Paul!
Mick
