Tyre Biter's Hatchback - ETA unknown...
#276
_cruiza_
Posted 29 April 2012 - 07:51 PM
I call it cave time, go out into the man cave away from the noise and demands of family and just work quietly on something simple that makes sense, that and beat the &*() out of stuff with a big hammer - repairs by percussion persuasion
#277
Posted 30 April 2012 - 05:37 PM
I'm only running 3 years late on my hatch but I'm finally getting into it now.
Cheers Mick.
#278
Posted 04 June 2012 - 09:03 PM
Now to install the springs - bit hard to work out which way they go up unfortunately.
And the the 3.25 LSD centre I got from unclefestaL34 (thanks) but wouldn't you know it, the gasket I bought fits beautifully save for one hole...
I am sure I will work it out but would just love to catch a break with this car!
Cheers, TB
Edited by Tyre biter, 04 June 2012 - 09:06 PM.
#279
Posted 10 June 2012 - 11:28 AM
Does anyone have an idea how much diff oil the thing will need and any opinions on a decent oil for a 9" with (tight) LSD?
Cheers, TB
#280
_LS1 Hatch_
Posted 10 June 2012 - 11:39 AM
If you a are running a clutch type limited slip, a little bottle of the friction modifier would probably be a good idea IMO too. (don't need it with a truetrac, or gear locker style either I believe)
#281
Posted 06 July 2012 - 11:20 PM
Update: Spent the last couple of weeks beavering away at the rear axles and drum brakes. I have had to;
- sand-blast the backing plates, drums, parking brake links and levers, adjusters, etc using the small sand blasting cabinet I have - that tool has paid for itself several times over - just can be difficult to keep working well on a cold day what with all the moisture in the air - problem is, everyday is a cold day in Canberra this time of year,
- then clean everything not blasted, and repaint most things,
- replaced the axle seals - I noticed some oil on the drum backing plates and whilst the existing seals looked near new and fine, I thought it would be better to do this now whilst it was all in pieces. Those seals took some work to source given everywhere I went only had them in metric sizes which were a near but not quite a proper match,
- identify and source new brake shoes and a shoe return spring - turns out the 11" drums belong to a 1959-61 Ford Customline and so took some effort and $$$ to locate a replacement set, and
- have some speedi-sleeves pressed onto the axles Bronco/F Series 1.5" axles.
Excuse the crap everywhere in the garage - in the middle of a general tidy-up at the moment.
Will now turn my attention to the brake master cylinder and booster before plumbing the brake system - imagine there are a lot more lessons in those items me there...
Cheers, TB
#282
Posted 07 July 2012 - 08:54 AM
#283
_berro59_
Posted 07 July 2012 - 10:19 AM
#284
Posted 07 July 2012 - 07:46 PM
I spent some time on the Hotwires today. The new Hotwire comes from Neale Wheels with the centre's requiring the stickers to be attached and then trimmed around the wheel stud holes as the sticker overhangs the holes.
The stickers are bloody hard to align with the hub centre and stud holes, and the backing paper of the sticker is more strongly adhered than the sticker can adhere itself to the wheel centre meaning the sticker can be easily stretched out of round when peeling the backing off, and finally trimming the stud holes is pretty bloody easy to stuff up as I found out the hard way.
The whole process is annoying and made worse by the premium of the wheels - I expect better from such an expensive wheel - IMO they ought to come ready to go, in proper boxes, lacking water stains and with wheel nuts that are new, clean and in OEM packaging as opposed to a dirt/oil filled Glad-wrap bundle wrapped in packing tape.
Having said that, I have found the after sales service to be fantastic. I've been sent replacement stickers and friendly advice in a very timely manner, on top of which (despite the stuff-up being my fault) I am being sent revised size wheel nuts at no additional cost. Simply, I cannot fault the after-sales service but wonder if more effort was put into the manufacturing/packaging effort then these after-sales remedies would not be required.
Regardless, I would say to those looking at buying the wheels - buy them for sure. Just ask the folks at Neale's to fit the stickers or better yet, paint the centres before shipping to you.
Cheers, TB
#285
Posted 07 July 2012 - 08:05 PM
#286
_nial8r_
Posted 08 July 2012 - 04:54 PM
also glad i found this thread again, keep up the good work
#287
Posted 08 July 2012 - 07:00 PM
#288
_Yella Fella_
Posted 08 July 2012 - 07:35 PM
#289
Posted 08 July 2012 - 08:45 PM
and i must admit that is one of the best cut down 9" diff's i have seen. same size axle tubes all the way insted of steped down.
#290
Posted 09 July 2012 - 05:42 PM
Kudos for the encouragement Berro, Derrin, Lee, Gerry and Pat - much appreciated.
Dave (lcxu105) thanks also - that diff housing/axle tubes is just what came with the car - can't claim any credit for it but it is a bastard-child of components! I think I might have said; the housing is 60's-80's Bronco/F-Series, the axles are the same, the flange ends are 'Big Style' bolt spacings using a 'New Big Style' profile, and the 11" drums are 1959-61 Customline jobbies!
I've been chipping away at the steering column the last day or so - have it mostly in pieces now - hope I've taken enough photos to put it all back together.
It will need the top and bottom bearings replaced - seems the top one might be an issue having read a few threads on here! Whilst I sort that all out, I will sand blast everything in my little cabinet before painting it all up nice and ready for the re-assembly.
Cheers, TB
#291
_berro59_
Posted 11 July 2012 - 08:37 PM
Thats the way to do it.
I take photos of all parts before i pull them apart and then when i cant remember how it went back together i can look at the pics.
The mini sand blasting cabinet sound like a good idea for the small bits.
#292
_Yella Fella_
Posted 15 July 2012 - 08:45 PM
Edited by Yella Fella, 15 July 2012 - 08:47 PM.
#293
_greg2240_
Posted 01 October 2012 - 07:49 PM
#294
_L31SS HATCH_
Posted 02 October 2012 - 08:08 PM
#295
_sting_
Posted 14 November 2012 - 06:47 PM
cheers sting
#296
Posted 29 January 2013 - 07:29 PM
Yesterday I had a visit come working bee where LX6LTR, myss427 and Redslur gave up their holiday to come by and help.
Just typical of the folks in the CTC and having seen and learned their knowledge first hand - I know there was no way I'd have done this - properly or otherwise!
The car now has wiring through it, door innards are in place including glass, pinch weld, door top vinyl, door cards and new locks - all done and dusted special thanks to Craig and Gerry for this..
The Torana RPA stuff fitted and went in a treat - the RSP stuff (though appreciated) had some issues sorry to report.
All flares and front spoiler now fixed and fitted properly after my poor effort, and vinyl from b-pillar rearward is all done - thanks Brett.
A lot of other things done here and there both yesterday and previously - too many things to mention but this is merely (finally) an update but also a public thank-you to LX6LTR, myss427 and Redslur.
Cheers, TB
#297
_greenmachine215_
Posted 29 January 2013 - 07:55 PM
Love the colour too, credit to you
_Yella Fella_
Posted 29 January 2013 - 08:07 PM
#299
_Marco72_
Posted 29 January 2013 - 09:36 PM
#300
_red roar_
Posted 29 January 2013 - 09:47 PM
PS Green's nice
