Tyre Biter's Hatchback - ETA unknown...
#301
_AD_75_
Posted 30 January 2013 - 03:54 AM
#302
Posted 01 February 2013 - 11:02 AM
I've not watched my build thread in ages it seems and so missed your posts.
Thanks Greg - very kind of you.WOW. Nice job, Do you have the engine yet?
Yep I have an engine...well sort of... Slowly getting parts together. I have the 308 block that came with it (original 253 is long gone). The block had been decked, sleeved and relieved for a stroker but I've decided to stay at 308ci. Also picked up some A9L rods and B cast heads the other week. But I have to admit the engine build is a way off yet.
Thanks for the moral support Marcus - I need it at times!G'day tb , just read your thread and your doing a top job. I think it takes a bit of courage to have a crack at a resto job like that when you haven't done anything like it before. I know what it's like, I bought a hq coupe as a rolling shell and 3 or 4 boxes. It's not easy but once you get your head around it and with some help from others who have the knowledge and experience eventually it all comes together. Very satisfying feeling knowing your building the car. Keep up the good work, I noticed you haven't updated the thread for a couple of months, hope everything's all good and you can finish the torrie
Thanks Brett - see above to Greg re: engine.Hi TB how you going, hows your progress going its looking great, have you worked out what motor yet if so how far off are you keep the updates going .
cheers sting
Updates - too many little things which seem inconsequential to bother folks with hence not posting much for a while, but yes, it is coming - maybe another year left to go?
Cheers, TB
#303
Posted 01 February 2013 - 11:07 AM
Thanks.
The flares are all down to myss427 - nothing I can lay claim to - truth is he had to go back over all my efforts to date, and the result front and back is just great.
Cheers, TB
#304
Posted 25 February 2013 - 09:10 PM
Look what turned up today...
Yep, that is 120 litres of Brown Davis' finest - Pretty 'Big Kev' about this part!
Now to work out how to install it...
Very, very nervous about swinging an angle grinder on those rear tank strap brackets which need to be removed because they are so very close to my beautifully painted beaver panel - might have give 'the Renovator' tool a lash (been sitting in my cupboard several months now without use and so worst case scenario I end up ruining a tool which I don't use anyway).
Has anyone any other first-hand experience on what works well and is safe to do when removing these strap tangs?
Also, I got the whole steering column back together (third time) including the ignition this time, and now all is seemingly working perfectly - a first for me that it only took two goes but I have to admit this outcome was thanks to some help from a friend (thanks Dan).
Finally, isn't this job a PITA to work our how the glove box lid springs are aligned and work on the hinge mechanism - yet again it was Dan to the rescue - anyone have pics they would like to share of the OEM screws and nuts that hold the glovebox lid to these hinges please?
Cheers, TB
#305
_Lamo_
Posted 25 February 2013 - 09:41 PM
#306
Posted 27 February 2013 - 10:48 AM
Thanks Lamo.
Bummer - they look just like the ones I found in the bottom of a bucket and the screw is too large for the holes in the glove box lid.
Will have to enlargen the holes without marking the lid.
Now to work out how to take a slight curve/bend from the lid.
Cheers, TB
#307
_red roar_
Posted 27 February 2013 - 08:07 PM
Hi Tyre biter,
How long did you have to wait for your tank from Brown Davis? They seem to take forever.
Ps, good work with your car, looks fantastic so far.
_Lamo_
Posted 27 February 2013 - 09:14 PM
A hot hair dryer and some heavy books.
#309
Posted 28 February 2013 - 02:37 PM
Hi Tyre biter,
Got one held in stock from a local supplier and so can't help with your enquiry sorry, TB
I thought of weighting it down but wasn't sure if this would create a long-term memory of the plastic.
I like you idea with the hair dryer - might just create a more long-term memory in the plastic - thanks, TB
#310
Posted 28 February 2013 - 05:16 PM
If you succeed let us know how you did it, I've tried a few things including heating etc and no luck as yet
#311
Posted 28 February 2013 - 05:43 PM
#312
Posted 28 February 2013 - 06:01 PM
Will do.
What sort of things and heat sources have you tried to date (don't want to reinvent the wheel as it were)?
Cheers, TB
Perhaps oven on low heat??? Or just get another one off eBay.
Brad - nothing like being the guinea pig hey?
Any suggestions on temp and reasoning behind the same would be appreciated.
Cheers, TB
#313
Posted 20 August 2013 - 10:28 PM
Been a while.
Never seemed like anything important enough was done that was worth showing.
Today however I go the new tyres fitted to the Hotwires and just loving it!
285/50 R15 Yokahama on the rear.
225/40 R15 Falken on the front.
Also, engine all but completed by Gary Cheverly of Chev's Performance in Carrum Downs VIC (Melbourne) - Hope to go bring it home soon.
And yes, I know - timing cover and water pump should not have been painted...
Cheers, TB
#314
_j.e.d._
Posted 21 August 2013 - 02:58 AM
Very very nice work there Craig Feel free to post up heaps of pic all round your car mate - it's good to see some of the nice detail put into this car. Amazing
#315
Posted 21 August 2013 - 07:33 AM
#316
Posted 21 August 2013 - 09:47 AM
This car is very, very attractive. Nice work!
#317
Posted 21 August 2013 - 11:08 AM
Nice, the hotwires set it off well
(re: glovebox lid) Sorry completely missed this - I've had it sitting in the hot sun with weights on it for hours, also tried using heat gun and trying to push it back into shape. The reinforcing on the back basically holds it in the warped shape, its quite solid.
#318
Posted 22 August 2013 - 12:59 PM
Thanks guys - appreciate your comments/encouragement.
That is a bummer - that was everything I had in mind and not game to try the oven as per Hanra's advice - knowing my luck I'd bugger it.
On another note - learned something yesterday that was really helpful - was trying to get the old tint off of the rear screen (demister fitted) and was making a hash of it plus it was evident very early in the piece it was going to take hours. I rang my local Solartint place and was told to use a steamer to remove the film together with a good quality/fine steel wool (with water) to get any residual glue off. I have to say; was one of the better bits of advice I have ever gotten - works a treat! Wish I'd taken before/after photos...
Ordered carpet and a few other things from Boomfunk today - can't wait to get it into the car.
Seats are being re-covered as we speak - has anyone used those seat hinge covers from RSP?
If so - how do you rate them for fit, finish, appearance, etc?
Just that they are pretty expensive and so for that coin I want to be sure I am getting a decent product.
http://www.rarespare...x?product=H1015
Finally, it seems the complaints in a few threads here re: RSP window rubber mylar strips and locking corners has had an effect.
Been taken out of supply for remedy I was told ref: RLS540C Locking strip - front and RLS540E Locking strip rear.
Pity - I wanted to get the screens into the car ASAP.
I have some OEM corners (thanks LX6LTR) - did anyone yet work out if there is any mylar out there to be bought which is correct for both the RSP rubbers and the OEM corners?
Cheers, TB
#319
Posted 22 August 2013 - 01:37 PM
I have a set of the seat hinge covers, fit well with no issues. Look good too.
#320
Posted 22 August 2013 - 03:56 PM
Thanks Derrin - if they pass muster for you and the standard of your build then I am sure they will be fine.
Cheers, TB
#321
Posted 20 September 2013 - 08:30 PM
Look what came home today!
Cheers, TB
#322
Posted 20 September 2013 - 08:40 PM
Hi mate do you wanna swap motors
#323
Posted 20 September 2013 - 09:05 PM
so craig it should be fitted by the morning ha?Look what came home today!
Cheers, TB
#324
Posted 20 September 2013 - 09:18 PM
Wouldn't go near your motor with a ten foot pole Laurie - just way too nuts for this fella.
Have to say though, Gary Cheverly and his boys at Chevs Performance in Carrum Downs (Melbourne) have done it again.
A great workshop who are very keen to learn what you want and then weave their magic to get you there;
http://www.chevsperformance.com.au/
Chevo plays with LS motors mostly nowadays but relishes going 'old school' when the opportunity arises.
The help, care and attention on this build has been great - I sent him a basket-case including several boxes of crap not knowing or appreciating what I had and what was needed, and this came back - I hear he and his team scrounged all sorts of bits for me around the workshop and elsewhere just to get everything they needed and to help with keeping cost down - this sort of outlook is fantastic as far I am concerned.
I wish Dave!
Still need to source a few things before installation - exhaust headers, fuel pump and a few other bits and pieces.
Burned all of my coin on body and paint, wheels, the engine and a few other things, and so now I really need to find what I can here and there.
Until I can afford those things it will sit in the corner of the garage sorry to report.
Cheers, TB
#325
Posted 20 September 2013 - 11:40 PM
i also wasted a lot of good coin on a ve ssv that i have since sold offWouldn't go near your motor with a ten foot pole Laurie - just way too nuts for this fella.
I wish Dave!
Cheers, TB
feel your pain sort of!
my hatch is re licenced and driveable
ended up bying my 96 caprice back off my brother
2nd best car i've owned 456000km still going
you will get there some day
the LX hatch is the best thing ever built by holden!
keep posting updates
davemc
