Been a while - four months or thereabouts I think.
Got the carpet and seats in a since my last.
I visited LX6LTR (CB) at the weekend and 'liberated' a number of items from him including all manner of little finishing things - not that my car is anywhere near finished mind you!
Interior grab handles, an alternator and assembly, a UC rear sway-bar, some heater control tabs, the wiring loom for the gearbox's reverse switch - that sort of thing.
Spent yesterday cleaning (wire wheel) and then re-painting the UC sway bar and then today Redslur (Gerry) kindly came over to help me tackle my list; the list was long and involved but we knocked it over.
The door opening scuff-plates went in - wasn't this a job much bigger than I thought it would be!
The previously perfectly gaped and adjusted doors didn't do so well once the carpet was trimmed and the scuff-plate installed. This required some massaging of a few different items, even moving the door cards a little - who would have thought?
This is where Gerry came into his own, his knowledge and experience got a job done which I would still be throwing spanners and my toys out of the cot over!
Also go the dash in - lower, facia and crash-pad.
Next up, the interior grab handles.
Again, I had spent yesterday cleaning them and painting them with vinyl die - came up a treat.
I think I have installed the chromed hanging hooks the wrong way around - I have the hook outwards.
Funny how the flash photo reveals the chalk marks from the motor trimmer in the headlining - you can't see them with the naked eye...
After lunch we turned our attention to the rear sway bar and things didn't go too well.
LX6LTR had kindly loaned me a Whiteline 'UC style' bar to trial fit - he had doubts the OEM UC one he gave me would fit - I should have listened.
Seems I have mixed up the terms 'UC style' bar and OEM UC bar when being given advice previously on this from a few members and deciphered this as the two being interchangeable - seems they are not.
In the end, the OEM UC bar won't fit around the 9" diff and this is where the Whiteline 'UC style' bar differs to the OEM UC bar.
You can see there is about 40mm extra length in the Whiteline bar referencing the eyelet mounts.
I have a K-MAC 'Bathurst' rear facing sway bar if anyone has a Whiteline 'UC style' forward facing unit they would like to swap???
I can only ask... You know the old saying; 'don't ask, don't get'
I was having kittens about a leak from the gearbox and frankly not looking forward to yet again having to remove it.
Turns out the weeping was a result of two issues;
1. the side cover bolts not being nipped up enough (I was afraid to turn the bolts too much and bugger the threads), and
2. the dummy yoke I had installed to measure the required tail-shaft length had a poor seal/plug.
Fingers crossed this has now all been resolved...
Also fitted the gearbox switch loom, the cotter pins in the steering knuckle, and worked out exactly what length cable I will need for the clutch set-up I am using (UC pedal arrangement).
All-in-all, a productive day.
A but disheartened about the rear sway bar but hey, I had some other wins along the way and so that is the way things go I guess.
A big thanks again to CB and Gerry - I would be lost without your help and generosity.
Cheers, TB
