I like it
Posted 02 October 2011 - 06:38 AM
Posted 05 October 2011 - 05:03 PM
Posted 05 October 2011 - 06:32 PM
Posted 05 October 2011 - 07:07 PM
Posted 05 October 2011 - 07:44 PM
Posted 06 October 2011 - 06:35 AM
Posted 09 October 2011 - 04:53 PM
...stay with rubber bushes for now UC upper control arm in the higher mounting position...
Posted 09 October 2011 - 05:23 PM
Posted 09 October 2011 - 05:57 PM
Edited by Yella SLuR, 09 October 2011 - 05:58 PM.
Posted 09 October 2011 - 07:43 PM
RTS front ends have the upper control arms (or UCA as Tyre Biter calls them) 25mm lower than original, or 1". Just gives better geometry. Early LX K frames had two sets of holes, original LH/early LX and RTS. Later LX ones just had one set for RTS.
I have a K frame sitting waiting for paint if you want measurements. It is an RTS K frame.
Posted 09 October 2011 - 07:55 PM
and the arms mounted lower as Yella said...LX with RTS but was really just sway-bars
Posted 09 October 2011 - 09:14 PM
Posted 09 October 2011 - 09:40 PM
Edited by Yella SLuR, 09 October 2011 - 09:41 PM.
Posted 09 October 2011 - 09:48 PM
Mmm, not quite correct. LH SL/R's (all models), GPaks, and L34's had sway bars, maybe other models as well. It's all got to do with different tuning with the suspesion geometry. Can work it out if you want, as to how it improves it. Thinking out loud, it probably just increases the camber of the wheel more during heavy cornering or suspension travel. We are just doing the geometry for the new car, it does away with rubber bushes and has solid plastic bushings. Will probably be a noisy ride, but wont make much difference when you have a helmet on.
If you want, go talk to Pete at Canberra Steering and Suspension. He was going to change Yella for me at one stage.
Posted 10 October 2011 - 01:36 PM
Posted 10 October 2011 - 03:46 PM
Posted 10 October 2011 - 09:47 PM
Edited by Yella SLuR, 10 October 2011 - 09:49 PM.
Posted 10 October 2011 - 10:19 PM
Posted 11 October 2011 - 11:03 AM
Posted 11 October 2011 - 11:11 AM
Posted 11 October 2011 - 12:38 PM
Posted 11 October 2011 - 06:50 PM
Posted 11 October 2011 - 07:43 PM
Posted 11 October 2011 - 07:47 PM
Posted 11 October 2011 - 07:49 PM
