None of the parts books I have have a sump included in a short motor replacement, so which spare parts list are you quoting from?Mike, again not a lot of sense! I am not confused with what I am saying, I am confused with what you are writing!
1. Evidence suggets block and piston kits got numbers - the original number off the car. Same evidence suggests these came stamped from Nasco for warranty replacement purposes. Original block had to be returned. I'm not even certain that it was easy to buy block and pistons kits over the counter. I do remember Young and Green in Kotara used to have short red motors all lined up for sale at the spare parts wharehouse. I don't ever recall seeing a block and piston kit. My guess is these were supplied only on firm order and with details of the car it was to go into, possibly easier for race teams.
2. 186L prefixed engines are not the same short motor as 186P. Pistons differ between low and high comp engines (same for 202). 161 and 186 differ along the way through HR-HG, cams change, lifters change, rear main seals change. They are not all the same all the way through. They are interchangeable but not the same and don't all suit one application. Manual and Auto short motors have a different part number too, and even 173 high and low compression short motors differ in part number, presuming the cam is different. HK to HK-HG have a different sump too so these are different short motors hence the different engine number prefix in road vehicles - 186A to 186P - a Nasco short motor for a HK-HG won't suit a HR as the sump is different.
No idea what you are getting at with 3 and 4, I have no confusion with any of this.
And I do know there are about three types of rear mains but these don't seem to have started as rope til 1974.
Late 186 replacements were part machined on the 173 line and remaining machining on the 202 machine line, this is why they have 202 main bearing caps machined out to early 173 and 186 journal size.
Mike
