LJ accelerator pedal linkage clip
11 replies to this topic
#1 dublin
dublin
  • 150 posts
  • Car:Replica LJ XU1,barn find LJ GTR
Posted 22 July 2011 - 05:24 PM
Hi,
I am after the small clips that hold the linkage in place from the accelerator pedal up to the rod that passes through the firewall, on the inside of the cabin. The original clip has '4-L' stamped onto it.
Im sure this clip would be common to many model Holdens, but dont know which ones?
I couldn't find the clip on the rare spares website in the LJ Torana section but did find the clip set, part number CP 1035 in the HQ parts. This set of 4 HQ clips contains 2 identical clips, but they are the reverse or mirror image of the one I need and are stamped '4-R' and the other 2 are 'sorta' right and are not stamped with any numbers, but the hole is too small to fit over the linkage rod. I was able to drill 1 out carefully and it fits ok.
I wanted to know if rare spares make the correct 4-L clip and how can it be found on the website?
Also after the rubber bush for the top of the arm and linkage pivot in the engine bay, right behind the brake master cylinder, that pulls on the throttle linkage please.
#2 _BIGCAV_
_BIGCAV_
Posted 22 July 2011 - 05:35 PM
i dont think we currently have that exact clip, but i will be able to have a closer look on monday hopefully
the smaller clip you used is listed as a 5/32" clip, we have the 3/16" inch version in mirror image to what you need, we also have 1/4" versions in both left and right in the kit CP1042
perhaps the 1/4" versions may get you out of trouble but so far it looks like we only have the 3/16" versions in one side
its after 5:30 now and the wharehouse is all closed up so i cant double check unfortunatly but ill try it on monday, if we dont have them then ill speak with our manufacturer and see if we can get some
#3 dublin
dublin
  • 150 posts
Posted 22 July 2011 - 05:52 PM
Thanks for the quick reply!
I also grabbed the CP1042 kit but they were too big :sad:
#4 _BIGCAV_
_BIGCAV_
Posted 25 July 2011 - 12:02 PM
iv spoken to a few people and ill get back to you as soon as possible, we are awaiting a list of possible replacements but iv been told we tried getting them many moons ago and didnt have any luck back then.
as soon as i know ill let you know
#5 dublin
dublin
  • 150 posts
Posted 25 July 2011 - 05:54 PM
Thanks BIGCAV, found the other part on the website I was looking for too.
#6 _lj tory_
_lj tory_
Posted 09 November 2017 - 07:36 PM
i know this is a really old thread, but what was the outcome? did you find the right ones or similiar ones that fitted?, im now in the same situation
#7 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 09 November 2017 - 07:57 PM
This mob seem to have a few items. Just put "rod" in the search box and a few different clips come up. Haven't used them but worth a try.
#8 S pack
  • 15,710 posts
Posted 09 November 2017 - 09:17 PM
Hi Donna
This mob have the clips you are looking for.
http://scaclips.com....e-door-rod3612r
Edited by S pack, 09 November 2017 - 09:22 PM.
#9 _lj tory_
_lj tory_
Posted 10 November 2017 - 07:29 AM
yay, thanks guys, ordered and on the way!
#10 _big jack_
_big jack_
Posted 11 November 2017 - 04:25 PM
Hi Donna
Good to know
#11 _lj tory_
_lj tory_
Posted 17 November 2017 - 07:11 AM
hi again, got the clip and it was perfect , thanks for your help
#12 S pack
  • 15,710 posts
Posted 17 November 2017 - 07:47 AM
:spoton:
