Also, how do I read the date code??? Fitted to 10/75 SL/R 5000.
Box details are:
7433771
Ser #: T423745
Date: K52
Edited by hanra, 23 July 2011 - 10:34 AM.
Posted 23 July 2011 - 10:32 AM
Posted 23 July 2011 - 11:07 AM
Is it possible to determine box type without dismantling?
Box details are:
7433771
Ser #: T423745
Date: K52
Posted 23 July 2011 - 02:27 PM
Posted 23 July 2011 - 05:30 PM
Posted 23 July 2011 - 05:40 PM
Posted 23 July 2011 - 07:59 PM
Posted 23 July 2011 - 09:45 PM
Once its out of the car Ill check those things.
Looking at the date code thought would K stand for October? 5 stand for 75? And 2 stand for 2nd day?
My car has the original motor in it, Ive confirmed that. And being 10/75 build this box sounds like its about right to??
Posted 23 July 2011 - 09:48 PM
Edited by slr_v8, 23 July 2011 - 09:48 PM.
Posted 23 July 2011 - 09:56 PM
http://www.gmh-torana.com.au/forums/topic/39701-aussie-3spd4spd-date-codes-and-serial-numbers/HQSS maybe?
Posted 25 July 2011 - 07:46 PM
Posted 26 July 2011 - 06:03 AM
Box details are:
7433771
Ser #: T423745
Date: K52
With the box out of the car select 1st gear and count how many turns of the input shaft for one turn of the output shaft.
M21 will be 2.54 turns input for 1 turn output.
M20 will be 3.05 turns input for 1 turn output.
Posted 26 July 2011 - 07:39 AM
Posted 26 July 2011 - 07:43 AM
Posted 26 July 2011 - 10:05 AM
Posted 26 July 2011 - 11:58 AM
Posted 26 July 2011 - 02:03 PM
With the car raised & 1st gear selected, mark the position of the tail shaft and turn the engine over by hand whilst counting the engine turns until the tail shaft has completed 1 turn.
Turn the engine over by the harmonic balance bolt.
You will need to be accurate!
M20 = 3.05:1
M21 = 2.54:1
M22 = 3.74:1 (stump pulling 1 Tonner)
L34 = 2.32:1
Have fun!
Edited by lcxu105, 26 July 2011 - 02:07 PM.
Posted 15 January 2012 - 12:47 AM
Doesnt M21 have 2 grooves on the front shaft ?
Posted 15 January 2012 - 07:12 AM
Posted 15 January 2012 - 08:03 AM
M20 = 3.05:1
M21 = 2.54:1
L34 = 2.32:1
Have fun!
Posted 15 January 2012 - 12:23 PM
Posted 15 January 2012 - 02:29 PM
Posted 15 January 2012 - 04:14 PM
Posted 15 January 2012 - 10:39 PM
Posted 15 January 2012 - 11:44 PM
So what do the 2 digit codes painted in yellow on the casings mean?
The 4 speed from my SLR has #7433771 T692006 11C5 TH ( yellow painted code on side and top of gearbox casing)
Th other spare gearbox I have is #7433771 T?????? 19F4 HC (yellow painted code on side and top of gearbox casing)
Posted 16 January 2012 - 05:42 AM
"72 would make it a 6cyl M21 with V8 input shaft??? Is that possible to do?"
Yes, that would make it a v8 m21, not sure if it has been clarified in this thread (it is in many others) but M20/M21 only relates to the gear ratios. You can interchange the input shafts from 6cyl to 8 cyl.
Open up the inspection cover and read the part # on the cluster, that will sort the M20/M21 issue.
This will help you
http://www.monaropar.../aussie4spd.htm
