* * * * * 1 votes
1977 LX SS Hatchback 4.2l
294 replies to this topic
#26 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 10 November 2011 - 06:24 AM
The t400 hits the tunnel as they are a lot larger the the t350 in size. When you put the box in you will see where you need to use a BFH to get more clearance arround the box as it will hit the floor.
Find someone who has a t400 in their hatch and you will know for sure but from what i have read and heard you need to make more room in the tunnel for them.
#27 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 10 November 2011 - 07:47 AM
cheers something to think about..can anyone out there confirm this 100%?
thanks for reading
jonesy
#28 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 16 November 2011 - 10:29 PM
motor paid for and on its way...f#@k yeah ...will be here mid jan.
#29 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 16 November 2011 - 10:31 PM
heres the specs.....
434P 565 HP PUMP GAS 98oct
Eagle 4340 Forged Steel
Eagle 6.0 Inch Forged H Beam
Mahle Forged
File fit plasma moly
DART Little M
COMP Hydraulic roller
GST
434 COMP hydraulic roller lifters
PBM Double row gear set & chain
Timming cover Billet polished Aluminum
Harmonic Balancer - Professional
Products
Oil Pump - Melling
Oil Pan - Moroso
Heads - 230cc Dart Pro 1 Platinum
Ported, 72cc chamber
GST
434 Head Bolts - ARP
Valves - Stainless steel 2.02 Intake 1.60
Exhaust
Springs - Dual with dampner
Rocker Studs - ARP 7/16 diameter
screw in type
Rocker Arms - COMP Aluminum Roller
Pushrods - 5/16 .080 Hardened steel
Intake Manifold - Pro Products
Valve Covers - Polished aluminum RAW
logo
QUICK FUEL 950CFM CARB
MSD PRO BILLET DIST
MARCH BILLET L/MOUNT PULLEY
KIT
CHROME 100AMP ALT
POLISHED HOLLEY FUEL PUMP
GST
1 434 MSD 6AL D IGNITION
MSD BLASTER COIL
HYTACHI MINI STARTER
EDELBROCK AL/W/PUMP
SFI FLEX PLATE
#30 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 16 November 2011 - 10:35 PM
can someone please 100% confirm this statment about the th400 ....will i need tunnel mods if i go with a th400?
maybe th350 is the go...info would be appreciated.
cheers jones
#31 _UCV80_
_UCV80_
Posted 17 November 2011 - 07:02 AM
Im pretty certain no tunnel mods are required for the th400. It is big and is tight, would depend on crossmember used also.
Nice list of parts above, very nice.
Edited by UCV80, 17 November 2011 - 07:03 AM.
#32 _LXSS350_
_LXSS350_
Posted 17 November 2011 - 03:32 PM
Have had a T400 behind both an 308 and 350 in an LX hatch. Although the tunnel was full it didn't require any mods or hit/rub on the floorpan.
Edited by LXSS350, 17 November 2011 - 03:33 PM.
#33 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 17 November 2011 - 04:11 PM
sounds good guys cheers...as for the cross member i think i will be ordering one from the rod shop has anyone gone this combo? chev-th400-rod shop cross member-lx hatch, that could fill me in if they have had any troubles..
#34 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 24 November 2011 - 01:35 AM
well after weighing up all the options and listening to forum members (that have valuable advice) i have decided to go with a beefed up TH350 and 3000 stall, which i have now ordered via town & country transmissions in hammy hill.
i have also had a chat to fullnoise (as suggested) and he will be making me a custom set of extractors.
hopefuly have some pics to put up once the gear starts to arrive.
#35 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 21 December 2011 - 07:20 PM
Quick update brought the trans, it’s a th350 apparently good for 700hp here’s a pic
needs a good tidy up to get it up to standard (take all the little burrs off and give it a clean smooth paint job)
#36 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 21 December 2011 - 07:25 PM
motor also came off the dyno yesterday here's the vid and read out
http://s1085.photobu...W434-101928.mp4
looks like it may be turning up a little later than expected due to christmas being here but should land in australia end jan early feb 'fingers crossed'
Edited by jonesy, 21 December 2011 - 07:37 PM.
#37 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 21 December 2011 - 07:38 PM
can everyone see the vid or is there another way to post it?
#38 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 21 December 2011 - 07:54 PM
Saw the vid fine via the link, sounds tough Jonesy. I reckon it'll be alot of fun, hope you put some nice sticky rubber on the back!!
#39 Rob2408
Rob2408
  • 309 posts
  • Name:Rob
  • Car:1974 L32 SLR
Posted 21 December 2011 - 08:11 PM
Nice, Very Very Nice.....
#40 benno81
benno81
  • 709 posts
Posted 21 December 2011 - 08:31 PM
nice motor mate just got a chev for my 4 door 355 that pumps 550hp so close to yours
how much did you pay for your t350?
#41 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 21 December 2011 - 09:34 PM
around about $2800 with stall, he had the stall there on the self from another customer that did not pick it up after ordering it.
#42 _nos 598_
_nos 598_
Posted 22 December 2011 - 06:32 PM
i would be asking why it still is using a vacum modulator on the gearbox. A t350 to take 700 hp requires a fair bit of tlc and you need to ask what has been done to it and what aftermarket parts have been used. A well built t350 is a good combo in a Torana over a powerglide which seems to be the common fitment with a small block chev.
#43 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 23 December 2011 - 02:00 AM
i dont know alot about gearbox internals but thats what the guy who owns town and country automatics told me he also said if i can break it he can replace it as his rep is on the line.
this is what it reads on the invoice,
stage two shift kit, TCI deep pan, 36 element direct clutch drum, red eagle racing clutches, dual feed top clutch, 20,000km warranty
any experts out there know what it should handle?
will it handle what i have got?
#44 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 27 December 2011 - 05:12 PM
just going through some old stuff in the torana folder and thought some people might be interested to see this
#45 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 29 January 2012 - 02:57 PM
well after hunting around i have found a diff and i came at the right price and all that i was after.. it needed a bit of TLC but it has come up nice.
PS 1420mm from face to face.
housing paint strippedand sanded
little imperfections filled
i sand blasted and painted outside of centre and fitted with new over sized diff pinion yoke
disk brake backing plates ready for sand blasting
after old shoes removed and blasted
bit of primer
and the same with the calipers
bit of black
little clean up of bolts and rubbers
caliper going back together
backing plate has got new shoes
some paint on the housing
for some reason there was no breather on the housing so i put one on
pressed the new trailing arm rubbers in and fitted the centre
fitted calipers, backing plates facing forward as the clearance in the rear position was up to sh#t between the shock and caliper axles in and new rotors got them shaved on the inside to mactch the hq diameter
also heres a pic of the backing plates in the rear position
#46 ls2lxhatch
  • 5,332 posts
Posted 29 January 2012 - 03:07 PM
The only problem with mounting the callipers in the forward position is that the calliper gets in the way of the handbrake cable.
#47 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 29 January 2012 - 03:15 PM
still need to get my hands on new backing plate dust covers and get the park brake sorted..
#48 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 29 January 2012 - 03:17 PM
yer there is a couple of threads on this site about it and it looks like it can be done i just need to get to the wreckers to get some more parts
#49 ls2lxhatch
  • 5,332 posts
Posted 29 January 2012 - 05:19 PM
A few people have connected the handbrake cable with the callipers in the front position but personally I do not like the angle of the cable.
I had some backing plates modified to mount the calliper in roughly the 11 o'clock position. I am going to get some more made up in the next couple of weeks.
#50 _ass308_
_ass308_
Posted 30 January 2012 - 07:09 AM
hi jonsey
do u have a drain plug in the bottom of that dif ?.i couldnt tell from the pics.
