Trouble Fitting PBR 330mm brakes to unflared torrie
#1 _LS1 LX_
Posted 03 September 2011 - 05:59 PM
One prob that i have is i have bought a set of PBR 330mm big brake kit for the front of my torana. Having major dramas with the twin piston caliper clearance to the K frame and steering arms.Ive had to get another set of hubs made to bring my wheel in under the guards. so offsets are ok.
I guess it would be a lot easier with flares on and im still yet to swap stub axles over so the calipers are on the rear side of the wheel arch and try that. I still reakon they are not going to fit.
Has anyone successfully installed this size rotor and caliper on unflared guards and had no dramas with turning circles and clearances. Any PICS of the mods to fit the brakes would help a heap thanks
from adam
Posted 03 September 2011 - 06:11 PM
Incl letting us know what stubs you are using
#3 _Liam_
Posted 03 September 2011 - 06:39 PM
Hey there,
from adam
Where did you get the kit from?
Hoppers fit apparently, UPC's do not.
Caliper is meant to be to the rear.
Some people notch a hole in the Upper Control arm.
Posted 03 September 2011 - 08:17 PM
Edited by myss427, 03 September 2011 - 08:18 PM.
