308 Engine combos and HP figures
#51
_Mint_
Posted 13 September 2011 - 08:06 PM
#52
Posted 13 September 2011 - 08:21 PM
stock 308 crank all crack tested and balanced
l34 rods arp bolts
plus .30 trw forged pistons 10.5 to 1 comp
high energy pan
steel balancer
hei ignition
perry extractors single 3 inch with resonator only
bert jones 37-70 solid cam
torker manifold port matched
750 dp holley, blue pump holley
brookfield hand finished heads
rrockers 1.65 screw in studs l34 valves brown springs
very heavy steel flywheel -hv oil pump, 3core radiator, penrite oil 25w50
hand made clutch
toploader and 3.50 lsd 9 inch with steel hemisphere- 26 inch mickey t slicks it ran 12.7- went 13.0 on 13 inch circuit slicks
with a 60hp nitrous kit it went 11.715 at 117mph.
after getting a thrashing at the drags and driven everyday on the street a rebuild went like this-port matched exhaust-
hand finished dave baines a9l rods with 7/16 bolts-scattershield- redone hei system- 7/16 studs and new 7/16 rrockers-stock oilpump put in,
trw hand finished trw forged pistons- 2 holley blue pumps and 1/2 lines all thru, les heintz special clutch- 288 solid cam, flowed same red heads- with 4.56 gears went 12.4 then
the first run using nitrous killed the clutch on first attempt in c1990-91 at drags. tried to fix it but gave up racing after that.
john brookfield told me stock 308 had 140-160 hp, the l34 had 240 270 and the race cars l34s he did had around 340-360 in early 70s.
chev offroad thought mine had around 360 at flywheel plus 60hp nitrous kit added on. have some videos on vhs must find them all.
#53
Posted 14 September 2011 - 07:50 AM
#54
Posted 18 September 2011 - 01:56 PM
#55
Posted 19 September 2011 - 05:03 PM
#56
Posted 12 November 2011 - 02:49 PM
had it thrown on the rollers today made 148rwkw would have liked more on the way home gave it a bit of stick and noticed it was pining at wot probably should have checked the timing before i put it on hahai havent had my car dynoed yet but the lil 308 slap job goes alright
red 308 standard bore flat top high comp pistons crow 5603 cam i think
red pre pollution heads and manifold all matchported at home slightly tweaked quaddy shitbag extractors with twin 2 1/4 system bosch hei dizzy with summit 6al style ignition
with the old banjo and the 13s it ran a best of 14.7 @98mph with heaps of wheel spin having open centre and 205s
plannign to get back to the track as soon as i get some big wheels now its got a 9 inch 3.5gears truetrac
#57
Posted 13 November 2011 - 06:58 AM
Back in the day we would turn out heaps of flat top, HQ headed, standard stroke, Crane 286, Performer based combos. Depending on how much money you had you could also get big valves and roller rockers. Often we would rering the short, tidy up the standard valved heads, fit LT1 springs and a timing set, tweak the Q jet and slide in a 286 and these things would go really well for the minimal $$$ spent. People still remind me of these $1500 stormers today !
One of the 308's I built for myself back then used 327 lumpy top pistons and heavily cut heads. It ended up with almost 12:1 comp. The cam was a Crow grind, the same one Alan Grice used to set the top speed record at Mt Panarama in 1984. It was in my old Group C A9X when it was still road registered, 4.44 gears and a Super T10. Stuck with the Performer and an 850 Holley ! Well it had no torque at all and was hard to get going but once it got to about 4500rpm it would start to move and at 5500rpm it was singing ! Once they pulled the lead out of petrol it pinged like a demon and I had trouble keeping head gaskets in it. A customer ended up buying it (I have never heard a better sounding engine and it was the major selling point !) once I pulled the lumpy top pistons and fitted flat tops. I don't know where it ended up from there. I did have it on a chassis dyno but this was 18 odd years ago and I can't remember what it made. I do remember it was the highest HP from a stock stroke engine they had seen at the time. I later rebuilt the genuine L34 race engine that came with the car (it had a much smaller cam and flat tops) and it was a better mannered thing all round but had nowhere near the top end of the Grice combo.
These days I can't remember the last stoke stroke HQ 308 I did for a customer that wasn't a turbo engine. The cranks are so cheap and VN heads are everywhere. I beg those with VN heads to use a stroker crank to get the air flowing quicker.
The engine I did for my own VH SL/E is super low budget..... its a standard bore, dish top VP 304 short, honed, new rings and bearings. I used a pair of HQ heads that had the bowls throated by the machine shop and I blended them in by hand. Waggott 239 @ 050 single pattern solid, Performer and Q jet. The only new parts were the cam, lifters, gaskets, rings and bearings. Everything else was second hand. Exhaust is 1 5/8" tri Y and a single 2 1/2". Its a lot of fun with the T5 and sounds great but I haven't got it onto the dyno yet.
#58
Posted 13 November 2011 - 06:34 PM
Your first combo is similar to what I had before my current combo bar the flat top pistons and it produced 240RWHP. It really went well considering it was a totally stock bottom end. The new combo is just getting better and better as I get k's up on it. Can't wait to run it down the quarter. I now swear by the Crane 304 hydraulic, fantastic cam. The 286 was great too but no where near as much mid range power as the 304.
Hopefully others will continue to share their combos..
#59
Posted 20 November 2011 - 11:33 AM
recently been having some oil pressure issue`s. started with oil surge, my light blinked at me during an event, then during cold starts pressure would go up and down, for about 30 secs to a minute, never done this before.
tried mucking around with everything i can externally to no succes, bugger.
pulled engine apart, main bearings have been hurt. we think, difficuilt to be 100% sure, oil pickup gasket is at fault.
also found oil pump drive gear, after 700kays is stuffed.
we`v tried both type of oil pump drive gears, coated steel and bronze, both crap. yes i no bronze you have to replace periodically, but to be half to 2/3rds worn after 700km`s, some of our events you travel 1000km`s in a weekend.
so after lots of talks alot of research im biting the bullet, dry sump it is.
#60
Posted 23 January 2012 - 07:26 PM
Took the hatch in for a dyno run today after upgrading my carby from a 670 to a 770 Holley to see what was happening. I gained 8 RWHP but the fuel mixtures were hugely too rich. Running around 10-11:1 air fuel ratio. Will have to get it properly jetted and should pick up another 10 or so RWHP. Ended up with 273.4 RWHP. Anyway it is nearly at its potential which is good news. The standard fuel system seems to be keeping up too.
Cheers, Gerry
#61
Posted 23 January 2012 - 08:09 PM
#62
Posted 24 January 2012 - 11:14 AM
Dave at Gastune is re-jetting my hatch on his dyno tomorrow. His is an old school one. Will let you know what figurs I get off his too.
Edited by Redslur, 24 January 2012 - 11:15 AM.
#63
_V6 UC_
Posted 26 January 2012 - 12:08 AM
#64
Posted 26 January 2012 - 05:48 PM
Unfortunately I didn't get dyno figures yesterday. I asked him for them too but he said most of the tunning needed was in the low to mid range and he only ran it to 4800rpm on his dyno. The car goes really well now and seems to rev a lot more freely. I will take it back to the place I got the figures checked orignally to see if it made any diference to overall figures. At the end of the day it is now runing at its potential and that was the aim and the stock fuel system seems to be keeping up.
#65
_torrymatt_
Posted 08 February 2012 - 12:24 AM
Now im a thew weeks away from having her back on the road FINALLY!
New Engine combo:
Holden 308 40'' thou o/s
acl race flat tops
acl bearings/gaskets
full arp kit
standard crank
'X' rods
VN heads s/s valve 2.02/1.60 massively ported(flows 565hp on bench)
1.60 ratio yella terra platinum rockers
286 heatseeker hyd cam
h/e sump
jp performance std vol oil pump
harrop single plane high rise manifold
750 dp holley HP
holley blue fuel pump
Turbo 350 stage 2 shift kit/b&m 3000rpm stall
9'' 3.9 ratio, 28 spine axles
15''x8's rear and 15''x7's front using Mickey Thompson sportsman s/r street slicks on the back!
Not 100% on hp figures or 1/4 mile but if it didn't do 12's i would be disappointed!
#66
Posted 08 February 2012 - 06:55 AM
I am taking my hatch back to be rechecked on the dyno this afternoon after having the carby proffesionally rejetted. Be interesting to see if it makes a difference to overall HP figures. I will be hopefully running mine down the quarter in the next 2 months.
Cheers, Gerry
#67
Posted 08 February 2012 - 07:24 PM
The air fuel ratios are now spot on across the range running around 12.5:1 so the tuner did a top job. Anyone in Canberra after a good carby tuner I am happy to provide his details.
The car definitely goes harder now and since my fuel log upgrade and 3/8 fuel line mod from the fuel pump to the carby have seemed to sort out all fuel starvation proplems in the top end. I am a very happy camper.
Cheers, Gerry
#68
_Liam_
Posted 08 February 2012 - 07:45 PM
#69
Posted 08 February 2012 - 08:16 PM
He ran his RT E49 replica at the same time. Managed 223 RWHP which is rerally good for a 6 pac...
#70
_LH SLR 3300_
Posted 09 February 2012 - 04:55 PM
304 30"thou pistons, standard rods
Camtech solid cam
VN heads, Crane rockers
MSD ignition
Harrop dual plane manifold, 650HP Holley carb
Standard fuel line, standard mechanical pump
Tri-matic full manual valve body, 3000rpm convertor
Detroit locker 9" 3.7 gears
Pacemaker headers, dual 2 1/4" exhaust.
Has run a 12.5@109mph on 205x65x15 street tyres, planning to run it on radial slicks soon & hopefully better that time.
#71
Posted 09 February 2012 - 07:24 PM
#72
_ooLo31_
Posted 14 February 2012 - 10:36 AM
hi struggler just a quick question how do you avoid the valves hitting the lumpys ,im thinking about doing a similar comboThis is the first time I have seen this thread (was overseas all of Sept.)
#73
Posted 14 February 2012 - 03:18 PM
Valve to piston clearance wasn't a problem. I think I laid the lump back a bit to match the 308 valve angle but it wasn't too much.
Build it !
#74
_ooLo31_
Posted 14 February 2012 - 03:59 PM
thanks mate i,m looking at a couple of options but i dont want to go the 355 wayValve to piston clearance wasn't a problem. I think I laid the lump back a bit to match the 308 valve angle but it wasn't too much.
Build it !
#75
_AD_75_
Posted 15 February 2012 - 12:14 AM
Block: Red HT cast SL/R block 30 thou over fitted with HV oil pump and stock sump
pistons: Cast flat tops +30
rods: L34
Heads: Genuine L34 fitted with Crane roller rockers/retainers/guideplates/double valve springs
Cam: Crane Solid (cant remember exact grind but fairly big)
Carb: Holley 780vac sec with L34 HO style Velocity stack and L34 fuel pump. (wish i had a pic of the stack it was pretty cool looking and cant find one anywhere!)
Ignition: L34 twin point dizzy
Inlet Manifold: Performer
Exhaust: Full Genie dual 2.5 inch system (This system sounded great)
Gearbox: Ford Top Loader fitted with hurst indy shifter
Diff: Ford 9inch 2.72 and 3.7 LSD gearsets
The sad thing is i ripped this engine out of my L31 and sold it off to another guy with an aqua LH SL/R 5000 replica so i could fit a 350SBC because i wanted more power..we had no idea back in the day that the original HT engines would be sought after by L31 restorers or that real SL/R 5000s would go up in value so much..
Wont post my other 308s as they are strokers..
Edited by AD_75, 15 February 2012 - 12:23 AM.
