I think for that amount of power, those red heads have had some major surgery. Good power from a red motor at reasonable revs too!
308 Engine combos and HP figures
#201
Posted 18 December 2017 - 10:17 AM
#202
Posted 18 December 2017 - 03:30 PM
Struggler should put up a clip of that angry sounding mofo' driving.
Those big cammed early headed 308's are what got me addicted to the beloved holden v8
Edited by gtrboyy, 18 December 2017 - 03:31 PM.
#203
Posted 19 December 2017 - 11:52 AM
And part of the reason my next build will be exactly that :-)
#204
Posted 19 December 2017 - 01:43 PM
Partly why want to eventually go back to manual v8's.
Mate had a brock with usual toploader & 9" with engine being 288 cam,ported red heads with torker added with 12:1 cr we didn't care how fast it was just sounded so good!
#205
Posted 20 December 2017 - 11:06 AM
Sounds like my VP Berlina. It is a 5 spd 355 with 520hp and sounds tuff as. Wouldn't be as quick down the strip as the SLR was but turns heads everywhere I take it. Last time I took it out I went to the fuel station to fuel up and a tuff as XW rolled up sounding cranky as. Then I started the VP to leave and everyone looked and pretty much said what the hell is in that. Love the sleeper look LOL...
#206
Posted 20 December 2017 - 03:02 PM
Loving the sound of my 355 with early port layout. Albeit Yella Terra dash 3's. The sound was also why I went for a manual car. It can raise the hair on the back of your neck, especially on downshifts when you are on it.
Not quite this good, but mine's a road car. (Turn sound up full for max enjoyment :-)
Here are my spec's(I know, not a 308)
355 crank, 11:1 compression, Crane CCH-314 cam (hydraulic flat tappet, 246 duration @ 50"), YT Dash-3 heads, un-ported(sadly), 4 into 1 ceramic coated extractors, 2 1/2" ceramic exhaust, x-pipe, stainless mufflers, 2 1/4" over the diff, ICE 2 step ignition, Hollley 750 DP ultra carby, TPower DP inlet manifold, 1" spacer. Dyno'd 460+ HP at 5900/6000 RPM. 3:08 Diff ratio, 5 speed TREMEC TKO. Can't hold full throttle in first due to traction..... have to be careful in second, can spin up tyres depending on road surface. Very drive-able but oh so much fun.
#207
Posted 21 December 2017 - 11:10 AM
Great HP figures using a hydraulic cam. Well done.
