![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Front suspension
#26
Posted 09 September 2011 - 10:59 PM
thats what i had in mind.
i was going to delete the bushes and use rose joints for smooth operation, mcdonalds bros said they can do this.
its good to actually see how you have placed the shock, instead of just picturing it in my head.
i am allowed tubular arms under class rules, we can actually do alot of changes, the limiting factor is tyre size which is what dictates alot of total grip available.
i think if using available tubular arms and relocating the shock, this is very achieveable, should work well.
great work
#27
Posted 09 September 2011 - 11:23 PM
My setup if similar to the picture below although I am using different springs. It is still on the bench at the moment.
![Posted Image](http://www.marksworkshop.com.au/Pages/site%20project/New%20Folder/ssstoranaphotos%20002%20(60).jpg)
#28
_CHOPPER_
Posted 10 September 2011 - 11:15 AM
#29
Posted 10 September 2011 - 01:40 PM
i.e remove it completely from inside the spring
When they do airbag kits on cars like ours (and Cadillacs) they relocate the shock outboard
Would this help to give you more availability of shock and make tuning the front easier ?
#30
Posted 10 September 2011 - 03:52 PM
Mc Donald Bros are currently going through the process of getting their tubular arms engineered.
The engineer I am dealing with said he would only need a welding certificate for the Mc Donald Bros tubular arms.
Edited by ls2lxhatch, 10 September 2011 - 03:52 PM.
#31
Posted 11 September 2011 - 12:30 PM
#32
Posted 11 September 2011 - 12:36 PM
They are an enclosed bearing hub that bolts on with 3 bolts to the back of the strut
Nothing to do with a stub axle and in no way anything to do with a Torana
#33
_Viper_
Posted 11 September 2011 - 01:26 PM
#34
_CHOPPER_
Posted 11 September 2011 - 01:40 PM
#35
Posted 11 September 2011 - 01:48 PM
#36
Posted 11 September 2011 - 04:20 PM
A hub designed for a conversion
Hoppers has a local CNC guy spin their up
Lots of people are doing them as has previously been discussed in other threads
Commodores from VR onwards use a sealed bearing assy that bolts onto the bottom of the strut
They went away from replacable bearings
SO did Ford in AU series
Hence the lift off hat type rotor
#37
_Dan355_
Posted 13 September 2011 - 12:17 PM
Dan you can run 16 x 8 , if you quote the A9X as your base . Targa rules in C3 allow a 2 inch raise in diameter and width.
A9X- So the homologation papers shows 14x6?
- What is the wheel track that we need to stick to.
- are these the wheel hubs that are needed and is the price ok? http://www.ebay.com....=item27be2b16d5
- What is the part number for the Bilsteins?
- Do i need to lower my top control arms 25mm?
Thank you all for the information provided.
Regards
Dan
#38
Posted 13 September 2011 - 12:23 PM
I can supply them too if you want to get them local (same price)
#39
Posted 13 September 2011 - 06:27 PM
No homologatiion papers where asked for, Targa doesn't get down to that much detail, i showed a workshop manual.
I used the A9X track figures quoted on the forum when i was building the car, no one other than BJ has ever thrown a tape over it.
They are the hubs, but see Datto.
Now you have me. I'll need to get that for you when i'm back home.
Arguable based on who you talk too. I did, and it works for me.
#40
Posted 13 September 2011 - 07:24 PM
Dave ran 16's
Alloy hubs could be made Mark... if you know a machinest we can get a price
Or ask the German...I think he made his out of alloy
#41
Posted 13 September 2011 - 07:36 PM
The German also made suspension pivots bolts out of out of Alloy 7075 which raised doubts in my mind over the engineering of his alloy hubs.
Edited by ls2lxhatch, 13 September 2011 - 07:40 PM.
#42
_Dan355_
Posted 13 September 2011 - 09:50 PM
Yes Dan those hubs will do the job
Datto - sounds good i will come in and see you by the end of the week.Datto, can we get them in alloy, if so, i'll have a pair.
A9X - Thats interesting Mark i thought they would check that, so why dont you run bigger rubber?
- Hubs i will see Datto
- With the Bilsteins are they the ones Rory was talking about.Are they the ones for the Pajero or Bedford van (hard day memory fading)
- Sounds like i will drop them 25mm also.
Thanks for help gemts.
Dan
#43
Posted 14 September 2011 - 01:13 PM
I don't run the bigger rims because the car is easily capable of winning, ( the driver sucks! ) and if we do pull the top step on the podium, i don't want to have it taken away because of an 'inconsistency in interpreting the rules'.
The Bilsteins were not the ones Rory used. From memory he was using Koni's from a Pajero, springs from a Bedford.
Datto the A9X was not fitted with 15's from the factory. What they ran in Group C doesn't count, unfortunately.
#44
Posted 14 September 2011 - 05:17 PM
And they homologated 15's for Group C I thought
#45
Posted 14 September 2011 - 05:24 PM
Targa rules do not accept homologation for other categories.
Need to get together soon on the brakes for this munro
#46
Posted 14 September 2011 - 07:30 PM
#47
Posted 15 September 2011 - 08:53 AM
Damn FiFo !
#48
_Dan355_
Posted 17 September 2011 - 07:17 PM
You are correct,they did.
So in Targa West Mark and dave run under class 35D while the other A9X (Graeme) was in class 35C whats the difference?
#49
Posted 18 September 2011 - 01:37 PM
he had no doubt there ok for the time been, but long term racing no.
an alloy hub would be one of those components that are "lifed", after a certain race distance they are replaced regardless whether they pass an inspection.
this is why i was talked out of it.
food for thought.
#50
Posted 18 September 2011 - 02:48 PM
And yes they have a lifespan
Many race classes already use alloy hubs inc many speedway classes especially in US
You can buy off the shelf hubs there... cheap
But likely to be unsuitable for what we want
