ss dash removal
#1 _timbo_hatch_
Posted 29 November 2005 - 08:01 PM
Just started pulling the dash out of the ss.
Can't quite work out how the main part of the dash comes out.
I don't want to pull it too hard as i will break it.
Are there any screws holding it in from behind?
It feels as though the passenger side it free, but something is holding it in from the drivers side.
Any help and advice will be greatly appreciated.
Timbo
Posted 29 November 2005 - 08:06 PM
#3 _timbo_hatch_
Posted 29 November 2005 - 08:11 PM
still unsure
Posted 29 November 2005 - 08:26 PM
#5 _Yella SLuR_
Posted 29 November 2005 - 09:00 PM
Alternatively try lifting the dash and getting the bottom out first, then the top should drop down enough and slide out till you hit the steering wheel. For the next few minutes you'll look like an un-co while you try manoeuvre it around the steering wheel.
#6 _Flamenco_
Posted 30 November 2005 - 05:38 AM
Two next to the glovebox lid (need to open the glovebox to access),
Two behind the ashtray
Two for the heater controls (bolts),
Two on either side of the dash itself,
Then theres 5 or so screws underneath the lower dash that need removing...
You may find it easy to slide off the lower air ducts too.
Posted 30 November 2005 - 08:43 PM
I had complications with the choke and so on, on the lower panel but you won't have that in an SS. Make sure you've removed the screws on the side of the dash too.
If you can show us on a photo where it's not giving then I can probably tell you what the problem is.
#8 _timbo_hatch_
Posted 05 December 2005 - 11:38 AM
Cheers.. Timbo
#9 _Yella SLuR_
Posted 05 December 2005 - 02:09 PM
The steering wheel in the way is not a huge issue, even if you dropped the steering wheel as suggested, it would still be in the way. Just work around it.
Sorry, can just see problems happening here (i.e. breakages).
Edited by Yella SLuR, 05 December 2005 - 02:10 PM.
#10 _timbo_hatch_
Posted 05 December 2005 - 03:13 PM
Posted 05 December 2005 - 03:30 PM
Posted 06 December 2005 - 04:07 PM
Posted 07 December 2005 - 04:12 PM
Posted 08 December 2005 - 01:09 PM
IF you have problems with the Choke cable coming out, and it ain't just one of those simple twist ones that seem to be the original, there MAY be a nut on the inside of the dash, if that's the case, get a small mirror and stick it to the upper firewall sorta region, whichever shows you the best, get a SMALL torch and hold that and grab a small shifter, stick it all in through where the instrument panel would usually be and watch yourself undo the nut through the mirror. Note: this is a pain in the arse but it's the best/only way to get it out. Then you disconnect the choke cable from the carb and pull the HOLE thing through... then you can remove the lower panel of the dash. Remember to pull it up and out so it clears the steering column and make sure it's not stuck in the vents or anything, just do it easily.
If you have any troubles finding the problem, just pull it at the sides and see where it bends out, where it's hard against the metal then that's where the problem will be.
